4K XAVC solution- Downsize 4K XAVC to 1080p for editing
Postod lauralily520 » 06.07.2015 10:11
Summary: Look for best solution to play and edit 4K XAVC files on Mac or Windows? Follow below article, you will get tips to convert and downscale 4K XAVC to 1080p video for easier playing and editing.
More and more persons can access a pile of XAVC files(like from Sony PXW-X320, PXW-FS7, PXW-X500, Sony F55) and may want to play and edit XAVC on Mac or Windows PC. However, XAVC files especially 4K XAVC is not widely supported yet by many professional video editing programs like Final Cut Pro, iMovie, Avid Media Composer, Adobe After Effects, Adobe Premiere Pro, Sony Vegas, Pinnacle Studio, Windows Movie Maker. What’s more, many video players, portable devices can’t open and play 4K XAVC files successfully. To view and edit 4K XAVC easily, the necessary step is to downscale 4K XAVC to 1080p and convert XAVC to MOV, WMV or any more acceptable format.
The process seems to be much simple with the help of Brorsoft Video Converter for Mac(or Windows version). This program works as a professional XAVC converter that can downscale 4K to 1080p faultlessly. What’s more, it is capable of transcoding XAVC HD and XAVC 4K files to AVI/WMV/MPEG-2/MOV for playing on QuickTime, iTunes, iPad… or import XAVC files to iMovie/FCP/FCE/Avid/Premiere Pro/Sony Vegas/Pinnacle Studio/Windows Movie Maker for editing smoothly with the edit-friendly format like Apple ProRes, AIC, DNxHD, MPEG-2, etc. Now read on to get the step-by-step tutorial.
Guide of Converting/Downscaling 4K XAVC to 1080p
1. Add 4K XAVC files
Run the program you just set up. Drag and drop the 4K XAVC to the converter. You can also hit Add files button to import videos to the app. If you wanna combine XAVC files into one file, you can click the “Merge into one” box.
2. Choose output format
Click the "Format" drop down list to select MP4, MOV, MKV, AVI, etc format from "Common Video" as you want. Since this video converter also provides optimal profiles for kinds of editing programs and media devices, you can also select a proper format that best meets your needs.
3. Set Video Resolution at 1080p
Click "Settings" button; you can adjust video and audio settings, including codec, aspect ratio, bit rate, frame rate, sample rate, and audio channel. To down-convert 4K XAVC to 1080p, do remember adjusting video size to 1920*1080. That is the exact 108p.
Editing Tips before conversion:
The 4K XAVC Converter allows basic editing of your XAVC videos. Click "Trim" button to clip unwanted video parts. Click "Crop" button to crop unwanted video area. Click "Effect" to add effect to you video like adding watermark, adjust video image.
4. Start conversion
Click “Convert” button to start converting 4K XAVC to 1080p in a proper format as you need.
When the conversion is completed, click "Open" to fast locate the converted files. Now you can get the converted 4K XAVC files for playing, editing, sharing and more.
Related posts:
Embed and Play DVD movies in PowerPoint
Editing Sony a7R II XAVC S in Final Cut Pro 7/X
Downscaling 4K XAVC to 1080p video for editing
Editing Nikon Coolpix P900 MOV in iMovie 09/11
Play MKV/AVI/VOB files on Tesco Hudl 2, Hudl 3
Play MKV/MP4/VOB/MTS/ProRes/YouTube on PPT
Editing Sony α7R ii XAVC S files in Adobe Premiere Pro
Convert and insert DVD (ISO, IFO) to PowerPoint on Mac
Find the Solution to Rip DVD to iPad Air 2 on Windows/Mac
Apple TV 2015 Reviews: What to expect from the new Apple TV
Encode MTS/MPG/VOB/TiVo files to Play on Nvidia Shield Tablet
Source: Downscale 4K XAVC to 1080p for playback and editing
