How to Insert DVD into PowerPoint on Mac for Playing
Postod lauralily520 » 03.07.2015 10:44
Summary: Want to present a DVD in PowerPoint slide, but don’t know how to? This article will teach you how to convert and insert DVD to PowerPoint easily under Mac OS X.
Do any of you know how or if it is possible to add and play a DVD movie in PowerPoint? In most cases, embedding DVD in PowerPoint will end in failure. That’s because PowerPoint is not compatible with DVD and it only embeds few video formats including ASF, AVI, MPEG, and WMV. Is there something can be done to successfully play DVD in PowerPoint? Of course, there is. In this article I will quickly walk you through how to insert DVD into PowerPoint on Mac with ease.
To embed DVD in PowerPoint means inserting a DVD clip physically into an application so that it can play within the presentation. Since PowerPoint doesn’t support DVD format, in order to insert the DVD movie to PowerPoint, you can convert DVD to PowerPoint supported video formats first and then insert the converted videos to your presentation. In this way, you can realize inserting DVD to PowerPoint presentation. The following guide will show you how to convert DVD to PowerPoint supported format and how to successfully insert and embed DVD in PowerPoint.
First download and install Brorsoft DVD Ripper for Mac.
Overall, this DVD ripping program enables you to rip and convert DVD to all popular video formats .wmv, .avi, .mp4, .mpg, etc and even extract audio from DVD movies under Mac OS X(Yosemite and Mavericks included). Besides, the built-in video editor allows you to trim, crop, add watermarks, etc. to get the very part and effect you want. If you want to insert video files from DVD to PowerPoint on Windows, please turn to the equivalent Windows version – DVD Ripper.
Step-by-step guide:
1. Add DVD files
Launch the Mac DVD ripping program. Then click "Load DVD" to import the DVD files you want to convert. DVD Folders, ISO and IFO files are also supported. To select the subtitles you like, simply click Subtitle and select the one you prefer.
2. Choose an output format
Click Format bar and choose your desired format. To embed DVD to PowerPoint, you can choose WMV or AVI format from Common Video profile list.
Tip: Edit your DVD files(Optional)
You can click Edit to trim, crop the DVD so as to get the part you want or add some special effect on your movie.
3. Begin DVD to PowerPoint format conversion
Click "Convert" to start the conversion. Just a few minutes later, you will get the converted video. You'd better keep of all the files in a folder for later use.
4. Insert DVD to PowerPoint
Open PowerPoint and start a new presentation. Immediately name and save the presentation into the same folder as you placed the video clips. As you create your PPT presentation, when you get to the slide in which you want to insert a video do the following:
On the menu bar, select Insert > Movies and Sounds > Movie from File. Done! In this way, you can play DVD in PowerPoint.
More Guides:
Play MKV/MP4/VOB/MTS/ProRes/YouTube on PPT
Solution to Open H.264 MP4 files in Sony Movie Studio
Convert MP4 to Sony Movie Studio without quality loss
Importing Sony a7II XAVC S to Avid Media Composer
Import Sony HDR-MV1 MP4 files to Sony Movie Studio
Convert and insert DVD (ISO, IFO) to PowerPoint on Mac
Transfer DivX Plus HD (MKV) files to your Sony PS3, PS4
Sony a7II XAVC S to Avid Media Composer Best Workflow
Edit Canon C100/C100 MK II MTS files in Sony Movie Studio
Edit Canon PowerShot SX600 HS mp4 files in Sony Movie Studio
Source: Embed and Play DVD movies in PowerPoint
Re: How to Insert DVD into PowerPoint on Mac for Playing
Postod lauralily520 » 09.07.2015 10:46
Summary: This article will tell you how to convert DVD ISO to QuickTime MOV so that you can play DVD ISO image on Mac freely.
Normally ISO is being used to replicate existing BD/DVD discs, transfer those discs over the network to other location and burn back to BD/DVD which then would be an identical replica of the original disc. However, playing DVD ISO on Mac is not so easy. Sometimes when you try to playback DVD ISO image files on Mac with the default DVD Player, you might come across some problems, especially when the ISO image files are region coded. For Mac users, they can look for and download an ISO tool to mount and enjoy the ISO, so do for Windows users. In this aricle, we will offer a more convenient way to play DVD ISO on Mac.
As we all know, the most compatible video format for Mac is QuickTime MOV. Since DVD ISO image is not supported by Mac well, then we can convert DVD ISO to MOV so that Mac can recognize and afford. To do so, a powerful DVD converter is needed. There are a lot of DVD tools online for users to choose. According to users feedback and our own testing, we highly recommend Brorsoft DVD Ripper for Mac to you which can be defined as one of the best DVD ripping tools on the market.
In general, it is an ideal tool to help you encode DVD, DVD ISO, DVD VIDEO_TS folder to Mac compatible video formats e.g. .mov, .mp4, .m4v on Mac OS X (Yosemite included) with high quality. Moreover, it also supplies many portable devices output formats such as iPad, iPhone, Samsung Tab, Kindle and so on so that you can enjoy DVD movie anywhere anytime. With its built-in editor, you can crop, trim the DVD movies before conversion. Just download it and follow the step-by-step guide to transcode DVD ISO to Mac.
How to Rip DVD ISO to Mac compatible video formats
1. Install and launch the program, then click "Load" button to import the DVD ISO files. DVD disc, DVD folder and DVD IFO files are also supported.
2. Since Mac supports MOV, MP4, M4V format, you can click Format bar and choose any of the three from Common Video as the output file format.
Tips: If you want to customize the output video quality, you can go to the "Settings" page to set video resolution, frame rate, bit rate, codec, etc.
3. After all settings, tap "Convert" button to start DVD ISO to Mac conversion.
When the conversion finished, go to "Open" panel to locate the encoded file on your Mac. Then, you can play or share DVD ISO movies on Mac at ease with high quality.
Read More:
How to Play DVD ISO image on Mac
Play MKV HD videos on iPad Mini 2/3/4
Transfer Blu-ray movies to ATV for Watching
Transferring Blu-ray movies to Apple TV 1/2/3
Best Way to Import MKV to iPad Mini for Enjoying
Solution to Open and Edit MP4 files in Sony Movie Studio
Edit Ikegami HDS-V10 MXF in Premiere Pro CC/CS6/CS5
Edit Sony PDW-F350 footages in Premiere Pro CC, CS6,CS5
Edit Sony PDW-700 MXF files in FCP 6, FCP 7/X with OS X
Copy iPhone Voice Memos to Save on Your Computer Playing
Source: Best ISO Converter for Playing DVD ISO files on Mac OS X
