Play Sony Handycam AVCHD MTS video on QuickTime player
Postod Andyeric » 30.06.2015 10:35
Overview: And as a Mac user, you might have also come across some down situation: these Sony Handycam MTS videos are unplayable on QuickTime, the native media player on Mac. So what's next step? Convert MTS to QuickTime compatible formats like MOV. Read on.
Hot Search: MTS Column | Sony Column | FCP Column | MTS Playback slow motion problem
Sony Handycam camcorders provide us great ways to record our most unforgettable moments, but for many Sony Handycam owners, most of them have a headache of playing Sony Handycam MTS files with QuickTime. Apple QuickTime movie is stored in the format of Apple QuickTime (.mov, .qt) which is a file format for storing and playing back movies with sound. Though developed and supported primarily by Apple Computer, the format of Apple QuickTime isn't limited to Macintosh operating systems.
Pavtube MTS/M2TS Converter for Mac offers an easy way to convert Sony Handycam MTS to MOV for playback on Mac. With it, you will be able to import Sony Handycam AVCHD MTS videos to your QuickTime for playback with best quality, fastest converting speed, excellent A/V sync and so on. Besides, by converting Sony AVCHD to MOV, you can transfer the generated files to your iPhone, iPad, Apple TV 3, etc to play with ease.
See also: Top 5 Best MTS/M2TS Converter for Mac Review
Step through: Converting Sony Handycam MTS to QuickTime MOV
Step 1. Run Pavtube Mac Sony MTS to MOV Converter. Click "Add file" or "Add from folder" button, browse to the footages from Sony Handycam and load them to the converter.
See also: How to Join Sony 3D MTS files on Mac
Step 2. Select the items to be converted, and click on "Format" bar to set a QuickTime format in template.
Click on the drop-down list of "Format", and follow "Common Video"> "MOV-QuickTime (*.mov)" or "Common Video" > "H.264 Video (*.mp4)".
To retain the HD video quality, you can select "HD Video"> "H.264 HD Video (*.mp4)".
Step 3. Click the "Settings" button and set proper video/ audio parameters. You can reset set the video size, bitrate and fame rate. If you would like to use default settings, simply skip this step.
Step 4. Click the "Browse" button next to the Output File Name field and select a location on your HDD for the output video file.
Step 5. Click the "Convert" button to start conversion. After conversion you can click the "Open" button to locate converted video files. As the converted mov format is compatible with mac, you can view Sony Handycam on Mac QuickTime freely.
See also:
Edit PJ810 AVCHD Files in Premiere Pro CC
Import Panasonic HC-X900/X800 1080/60p MTS to iPhoto 8/9/11 for editing
No Audio when Editing MTS files in Adobe Premiere Pro CC
Convert Sony Handycam MTS to Quicktime MOV for Playback
Working with Canon HF G25 MTS footage on FCE 4/iMovie
Import Sony FS700 AVCHD to Premiere Pro and Burn AVCHD to DVD on Mac
Encode Sony HDR-MV1 MTS to MOV, AVI, MPG, MP4 on PC/Mac
Working with Canon Legria HF20/HF200 MTS (AVCHD) Videos on Mac
Sony Nex-6 and FCP(X) workflowSony PJ260V MTS to iMovie AIC Transcoding
Import Canon HF G30 AVCHD to Premiere Pro CS6 and After Effects CS6
How to edit Sony 3D MTS in Final Cut Pro 6/7
Encode AVCHD MTS/M2TS footages to Sony Vegas Pro 12 Editing
Play AVCHD Videos with VLC on Yosemite
Source: Playback MTS on QuickTime
