Transcode TS files to DNxHD for Avid Media Composer
Postod lauralily520 » 30.06.2015 10:02
Summary: Trouble importing .TS files to Avid Media Composer? Here you will find the best solution to edit TS recordings with Avid MC.
I have some TS recordings and usually the recorded files can be uploaded to my PC. Sometimes the recordings need to be edited, but importing these TS files to Avid Media Composer is impossible. What I need to do is to convert the TS files to a file format that can be imported to Avid MC. On Avid official website, it recommends DNxHD codec for editing. So if you also want to get Avid Media Composer work perfectly with TS videos, the easy workaround is to convert TS to DNxHD mov.
Well, TS files are "transport stream". It's a very specific encoding that must be done. It's usually an H.264 essence inside an MPEG-2 TS container. To convert TS files to Avid, a professional TS file converter is needed indeed. Brorsoft Video Converter for Mac can be the great help in this task.
With it, you can effortlessly transcode TS files to DNxHD encoded MOV for Avid Media Composer 5/5.5/6/7, and it works well and converts flawlessly. Meanwhile, the Mac video conversion tool can create files compatible with various non-linear editing systems like FCP, FCE, iMovie, and Adobe Premiere Pro, etc. If you are running on Windows, get Brorsoft Video Converter. Now just download the program and achieve your goal smoothly.
Guide: Converting TS videos to edit in Avid Media Composer
1. Click Add button to load the TS files you want to convert for Avid MC. Or simply drag your videos to the left item bar for converting. Batch conversion is supported so you can add many files at a time to save the conversion time.
2. Click Format preset and choose Avid Media Composer -> Avid DNxHD (*.mov)” as the best video format for editing TS video in Avid as well as good video quality.
3. Adjust the video and audio parameters, including the Bitrate of Video&Audio, Video Size, Sample Rate, Frame Rate, Audio Channels, etc., by clicking the Settings button on the main interface for getting the best quality.
4. Click the convert button to start transcoding TS for Avid Media Composer.
After the process completes, click “Open” button to find the generated videos, and then you can transfer the TS recordings to Avid Media Composer 4/5/6/7 easily and quickly.
More Guides:
How to rip Blu-ray to Microsoft Surface 3
How to Edit iPhone videos in Premiere Pro?
Easy way to play DVD on Microsoft Surface 3
Downscale 4K MP4/MOV/MXF for iMovie editing
Canon C100 AVCHD to Adobe Premiere Pro workflow
Edit AJA Cion 4k video clips in iMovie, FCE, Avid MC
How to import muxed MPEG-1 and MPEG-2 to iMovie
Import AJA Cion 4k videos to Edit in Adobe Premiere Pro
Editing Nikon D7200 MOV clips in Windows Movie Maker
Converting MediaPortal TS for Editing in FCP, iMovie/FCE
Will Final Cut Pro X support XAVC files from Sony PXW-X70
How to Convert AEE S71 4K/HD MP4 to AVI for Pinnacle Studio
Enable Premiere CC to ingest XDCAM MXF from Sony PDW-700
Source:Converting TS videos to edit in Avid Media Composer
Re: Transcode TS files to DNxHD for Avid Media Composer
Postod Andyeric » 03.07.2015 4:44
Play Canon T6s/760D MP4 videos on VLC/QuickTime
Summary: Tips and tricks for importing Canon T6s/760D MP4 files to VLC and QuickTime for playing and enjoying. Learn details.
EOS Rebel T6s/760D is a new model in Canon's DSLR. Users can record Full HD MP4 files with it. But there are some problems such as not showing the video, unsupported file type when playing and enjoying Canon T6s/760D MP4 videos. You cannot import recordings from Canon T6s/760D to VLC or QuickTime for playing. Is there any quick fix for the problems with Canon T6s and VLC/QuickTime?
VLC does play MP4 files, but it has strict limitations: VLC Media Player is only compatible with MPEG-4 ASP, DivX 4/5/6, XviD, 3ivX D4 and H.264 / MPEG-4 AVC. However, MP4 is a multimedia container format with many kinds of video and audio codec. If your MP4 file contains a VLC unsupported audio or video codec, VLC won't play it. In this case, we will encounter the following symptoms when we play MP4 files in VLC:
Question 1: "I'll get to about 1 hour and 50 minutes of a 3 hour long .mp4 video and the video will just stop, and it happens to all the videos I've downloaded."
Question 2: "I am a fan of VLC so use it on most machines to play MP4 videos from my NAS. Tonight it has just stopped displaying the video."
Question 3: "VLC will not play certain mp4 h264 files. Some H.264 files work, others don't."
How to solve "VLC/QuickTime not playing MP4" Issue? Pavtube Video Converter for Mac is specially designed for solving the VLC/QuickTime MP4 issue like "Does VLC/QuickTime play MP4? Can VLC/QuickTime play MP4? VLC/QuickTime is not playing MP4? VLC/QuickTime won't play MP4? How to play MP4 on VLC/QuickTime smoothly?" With this powerful MP4 to VLC/QuickTime Converter, it becomes easier to play all kinds of MP4 on VLC/QuickTime and you will never encounter the above problems. If you are Windows users, the Windows Guide can help you.
P.S Here you can choose more Video Converter for Mac softwares by viewing the Reviews.
Now, download and install the program from the website or click the free trial icon:
How to transcode Canon T6s/760D MP4 videos for playing on VLC or QuickTime?
Step 1: Then, launch the best MP4 Mac video converter and load your original MP4 files in with "Add video" or "Add from folder". Directly drag files in is available.
Step 2: Choose the right output format for VLC. As we mentioned above, we would like to introduce you to select the "HD Video>>H.264 HD Video (*.mp4)" as your best choice. Surely you can choose other suitable ones as you like.
Tips: For QuickTime, choose "Common Video>>MOV-QuickTime (*.mov)".
Step 3: The built-in editing function provided by Mac Video Converter is something worth trying. To trim the video, add artistic effects, adjust audio, add watermark, customize video parameters and so on. You can get the work done splendidly. Of course, if you don't think it's a necessary to do, you can skip it and move onto the next step directly.
Tips: You can also go to the "Settings" to set the parameters for your videos.
Step 4: Click the "Convert" button on the main interface if you have done all the preparation work. This is the workflow that we need to convert T6s/760D MP4 to VLC/QuickTime best accepted format.
Conclusion: OK, everything is ready, and you can instantly play your Canon T6s/760D camcorder captured MP4 files on VLC/QuickTime. By the way, we have promoted money saving bundles & deals activity. It really saves a lot! Why not take a look and have a try about high quality products with attractive price?
Further Reading:
Compress Sony FDR AX-100 4K XAVC S Files with Wondershare Alternative
Edit Sony Z100 4K XAVC in Sony Vegas 13
Import Ikegami GFCAM HDS-V10/HDN-X10 MXF to Aperture 3
Convert AJ-PX800 P2 MXF to MOV with no Quality Loss
Two Ways to Convert MKV to iTunes for Adding Videos
How to Get AVCHD MTS Workflow with DaVinci Resolve (Lite)?
Encode Tivo to MPEG-2 for Premiere Pro CC on Yosemite
MP4 video can be used perfectly in Premiere Pro CC
Help you import MKV to VLC Media Play
Share XAVC on YouTube/Vimeo/Facebook on Mac
Decode H.265 to Prores 422 for FCP X Editing
Source: http://pc-mac-compatibility-issues.blogspot.com/2015/03/play-t6s-mp4-on-vlc-quicktime.html
