Rip and convert Blu-ray to Surface 3 video format
Postod lauralily520 » 30.06.2015 9:33
The problem comes up when you got a Surface 3: how to watch Blu-ray movies on Surface 3 tablet? Since Surface 3 doesn't support playing Blu-ray movies as other Surface tablets(Surface RT/Pro), you need to convert Blu-ray to video files that are supported by Surface 3 and then transfer the video files to your Windows 8.1 tablet for playback. Looking for a reliable way to do that? Now you're in the right place, here we' show you how to rip and convert Blu-ray to Surface 3 in just a few mouse clicks.
Of course, first you need to get a Blu-ray ripping program? Puzzle at which one to select? Here Brorsoft Blu-ray Ripper is highly recommended to help you easily get your work done. With it, you can fast convert Blu-ray to Surface 3 supported video formats like MP4 and other popular video formats like MOV, MKV, FLV, MPG, WMV, etc. What’s more, you can freely select your preferred subtitles and audio track and even tweak the video settings. If you're a Mac user, simply get Brorsoft Blu-ray Ripper for Mac, which lets you rip Blu-ray movies to Surface 3 tablet on Mac OS X. Now just download the right version according to your needs and check out the steps below.
How to convert DVD to Surface 3 easily
Step 1. Insert your Blu-ray disc into your BD drive, run the Blu-ray Ripper for Surface 3 and click "BD/DVD disc" icon to load your Blu-ray movies. As you can see, you can preview the loaded Blu-ray files in the right preview window and select Blu-ray audio track/subtitle. DVD disc, DVD folder, ISO/IFO files are supported as well.
Step 2. To play Blu-ray movies on Surface 3, you can select an output format for Surface tablet. Click on the pull down menu of "Format", and select "Windows > Microsoft Surface Windows RT/Pro H.264 Video (*.mp4)" as target format. The output videos could fit on Surface 3 perfectly. If you want, you can then click "Settings" to adjust the video parameters manually.
Tips: By clicking “Edit”, you can personalize your video as you like such as trimming the video to get the very part you want, adding some watermarks to mark your video, applying some movie effects to make a difference for your movies and so on.
Step 3. Finally, click Start on the main interface to start converting your Blu-ray movies to Surface 3 playable video files. When the conversion finishes, click Open to get the ripped videos and then put them to your Surface 3 tablet for enjoy on-the-go.
See more:
How to rip Blu-ray to Microsoft Surface 3
How to convert DVD to Surface 3 tablet easily
Play and Watch AVI , WMV on Kindle Fire HDX 7
Smoothly Playing AVI/WMV on Kindle Fire HDX
Converting TS videos to edit in Avid Media Composer
How to import muxed MPEG-1 and MPEG-2 to iMovie
Edit AJA Cion 4k video clips in iMovie, FCE, Avid MC
Edit Nikon D7200 video files in Windows Movie Maker
Selectively Recover iPhone(iPhone 6/6 Plus/5S/4S) Lost Notes
Selectively recover data caused by updating to iOS 8.3 from iCloud
How to Convert AEE S71 4K/HD MP4 to AVI for Pinnacle Studio
Source: Play Blu-ray Movies on Surface 3
Re: Rip and convert Blu-ray to Surface 3 video format
Postod lauralily520 » 02.07.2015 11:01
[size="4"]Now we recommend the best DVD to Surface 3 Ripper for Mac which can help you convert the DVD movies to Surface 3 on Windows 8.1 quickly with the best output video quality. With the help of DVD to Surface 3 Ripper, you can watch DVD movies on Surface 3 with the optimal video quality anytime, anywhere.[/size]
The Surface 3, the newest hybrid from Microsoft, packs the hallmarks of Surface Pro 3 into a thinner and lighter device. Microsoft is killing Windows RT with the Surface 3, which will ship running Windows 8.1 with the promise of Windows 10 upgradability later this summer.
Question: " I like watching movies, and I have some DVD discs. Recently, I bought the Surface 3, watching HD movies on it is amazing. So, is there any way to play DVD movies on Surface 3. Any software recommend ?"
The best program we can recommend for ripping Blu-ray to Surface 3 is Brorsoft DVD Ripper . It has Microsoft Surface-ready output modes, which means that you can effortlessly get Blu-ray movies playable on Surface 3in several clicks with fast ripping speed and high output video quality. It also has outputs for all the other Surface models, as well as the Surface Pro 3, Surface RT and Surface 2. If you're using a Mac and want to copy Blu-ray movies toSurface 3 on Mac OS X (Mavericks and Yosemite included), you can turn to it equivalent Mac version Brorsoft DVD Riper for Mac. Just download the right version and follow the step-by-step guides to achieve your goal smoothly.
Download DVD to Surface 3 Converter:
Slika Slika (Note: Click here for OS X 10.5)
Note that the guide below uses DVD Ripper windows version screenshots. If you want to put DVD movies on Surface tablet on Mac, the method is almost the same. You just need to download the right version according your computer's operating system.
1. Add DVD files
After downloading, install and run the DVD to Surface 3 converter, and then click "DISC" icon to load movies from DVD discs. ISO files, IFO files or DVD folder (DVD folders files name appear like "Video_TS") is also supported.
2. Choose output format
Click "Format" bar, you can get optimized videos for your surface under "Windows > Microsoft Surface Windows RT/Pro H.264 Video (*.mp4)". The output videos could fit on your device perfectly. If you like, you can click "Settings" to change the video encoder, resolution, frame rate, etc. as you wish.
3. Start DVD to Microsoft Surface 3 conversion
After all the above settings, simply click "Convert" button to start converting DVD to Surface 3 MP4 videos.
Once the conversion is finished, you can click "Open" to find the result .MP4 files ready to be transferred into Surface 3 for great enjoyment.
Read More Guides:
How to Rip and Copy DVD to iTunes
How to Rip DVD with the right subtitles
How to Edit iPhone videos in Premiere Pro?
Easy way to play DVD on Microsoft Surface 3
Top 10 Best Video Player Apps in 2015 for Android http://www.brorsoft.cn/rip-dvd/dvd-to-samsung-galaxy-s6-and-s6-edge.html
How to Make iPhone videos editable in Premiere Pro
How to Convert DVD to DLNA supported video formats
Transfer DivX Plus HD (MKV) files to your Sony PS3, PS4
Source: How to convert DVD to Surface 3 tablet easily
Postod lauralily520 » 09.07.2015 10:14
Summary: This article will teach you how to open and play Blu-ray disc movies on Apple TV 1/2/3 with best Blu-ray to Apple TV Ripper.
Although people are now ditching the old ways of home entertainment – broadcast TV and physical media – in favour of downloads and streaming services, they may have a sizeable collection of Blu-ray movies, gathering dust in their cases and gobbling up valuable shelf space. If you are interested in ripping Blu-ray movies to a hard drive, where you can access them any time via an Apple TV or similar device, this tutorial will give you some effective tips on how to converting Blu-ray discs into Apple TV.
Apple TV is a digital media receiver created by Apple Inc., which is designed to access M4V/MP4/MOV digital content from the iOS devices, or any Mac OS X or Windows-based computer running to a high-definition widescreen television. In order to play Blu-ray movies on Apple TV, you need a piece of Blu-ray Ripping software to help you.
Among plenty of Blu-ray ripping tools in the market, I hereby recommend the best-in-class one, which is named Brorsoft Blu-ray Ripper for Mac. With it, you can rip and convert commercial Blu-ray Discs (Blu-ray H264, MPEG, VC1) for freely playback on Apple TV 1/2/3 without problem. Moreover, it also can deal with DVD disc to portable devices formats for playing including iPad, iPhone, Kindle, Nexus, Samsung Tab .etc. If you are a PC user, Brorsoft Blu-ray Ripper Windows version is your first choice. Now, download the software on computer and follow below guide to start Blu-ray to Apple TV conversion.
Preparation:
1. Mac Computer (Yosemite included)
2. Apple TV&Widescreen television
3. Mac Blu-ray Driver
How to Rip Blu-ray movies to Apple TV on Mac
Step 1: Run the Ripper and import Blu-ray movie, ISO, IFO from drive to the tool, you also can load DVDs, DVD IFO/ISO to it.
Step 2: Click on Format > Apple TV. From the drop down menu, select the proper output format. Here, Apple TV Dolby Digital Pass-through (*.m4v) is recommended. The profile Apple TV 3 is specially designed for 1080p Full-HD quality with Dolby Digital 5.1 Surround Sound.
Tip: You can adjust codec, aspect ratio, bit rate, frame rate, sample rate and audio channel in the "Settings" page according to your needs and optimize the output file quality.
Step 3: Tap "Convert" button; it will convert Blu-ray movie to M4V for Apple TV immediately.
After conversion, you can get the output M4V file via "Open" panel for your Apple TV effortlessly. Now you can play Blu-ray movies on Apple TV without any issue.
Read More:
How to Play DVD ISO image on Mac
Play MKV HD videos on iPad Mini 2/3/4
Transferring Blu-ray movies to Apple TV 1/2/3
Best Way to Import MKV to iPad Mini for Enjoying
Edit Ikegami HDS-V10 MXF in Premiere Pro CC/CS6/CS5
Best ISO Converter for Playing DVD ISO files on Mac OS X
Edit Sony PDW-F350 footages in Premiere Pro CC, CS6,CS5
Edit Sony PDW-700 MXF files in FCP 6, FCP 7/X with OS X
Copy iPhone Voice Memos to Save on Your Computer Playing
Source: Transfer Blu-ray movies to ATV for Watching
