A solution to editing Sony PXW-X70 XAVC in FCP X
Postod lauralily520 » 26.06.2015 11:07
Summary: If you are puzzled by the problem that your XAVC files from Sony PXW-X70 can not be edited in Final Cut Pro, here we offer you the best workaround to solve the Sony PXW-X70 XAVC to FCP X incompatible issue.
I have recorded many 1080P videos with Sony PXW-X70 camera, and the recordings are in XAVC Long format. Now I would like to import these XAVC files to Final Cut Pro X to create a short film. What I want is to edit Sony PXW-X70 XAVC in FCP X natively on Mac, but I always encounter importing problems. So any solution can help me import Sony PXW-X70 XAVC into FCP X natively?
I’ve researched the web and it turns out some results. Some guys recommend to download and install the XAVC Plug-in for Apple (PDZK-LT2) provided by Sony, which provides support for XAVC files shot on Sony SxS card, allowing viewing and editing capability in Final Cut Pro X(10.0.8 or higher). I’ve tried it, but still can’t get my XAVC clips from Sony PXW-X70 to FCP correctly. Alternatively, since Final Cut Pro does not have native editing support for XAVC footage, you can transcode XAVC to Prores codec, which has been designed to work especially well as high-quality, high performance editing codecs for Final Cut Pro(no matter FCP X or FCP 6/7). With the help of Brorsoft Video Converter for Mac, a professional Mac XAVC converter, I got my problem resolved.
With it, I can effortlessly transcode Sony PXW-X70 XAVC files to Apple ProRes - ensuring maximum editing quality and efficiency when working with Final Cut Pro X as well as FCP 6 or FCP 7. The conversion is darn easy to be finished with only three clicks without loss of video quality. If you are also stuck in the trouble, just download the program and check out the easy steps to convert and import Sony PXW-X70 XAVC videos to FCP X without any troubles.
Converting Sony PXW-X70 XAVC to ProRes for editing in FCP X
Step 1. Install the XAVC converter program on Mac and run it. Drag the XAVC files to the software. Or you can also click “Add” button on the top of the main interface to import video to the program. It supports batch conversion and joining multiple video clips into one file.
Step 2. Click the “Format” bar and select Final Cut Pro> Apple PreRes 422(*.mov) as output format. This format is specially designed for FCP, so that you can edit your original Sony PXW-X70 XAVC clips in Final Cut Pro perfectly.
Step 3.(otpinal) Adjust the video and parameters, including the Bitrate of Video and Audio, Audio, Video Size, Sample Rate, Frame Rate, Audio Channels, etc., by clicking the Settings button on the main interface.
Step 4. Click the “Convert” icon under the preview window; it will start converting XAVC to ProRes MOV for FCP X on Mac.
After the conversion, launch Final Cut Pro, choose File > Import > Files…, and browse to where you save the converted XAVC clips to. Now you can start editing Sony PXW-X70 XAVC video in Final Cut Pro X or FCP 7/6 without any problem.
Additional Tips:
This XAVC to FCP Converter can also help you to encode XAVC video to iMovie, Adobe, FCE, Avid, etc. You just need to choose a proper video format like “iMovie and Final Cut Express -> Apple InterMediate Codec (AIC) (*.mov)” in the second step. For Avid Media Composer, choose “Avid Media Composer > Avid DNxHD(*.mov)” as output; For Adobe Premiere Pro, choose Adobe Premiere/Sony Vegas> MPEG-2(*.mpg) as output.
See also:
Backup iPhone 5 data to my new iPhone 6 plus
Downscale 4K MP4/MOV/MXF for iMovie editing
Convert DVD movies (ISO, IFO) on OS X El Capitan
Edit 4K Ultra HD Videos for Mac FCP/iMovie/Premiere
Edit Sony PXW-X70 4K XAVC/1080p AVCHD in FCP X
Import 4K MXF/MOV/MP4 files to iMovie on Mac OS X 10.10
Import XAVC S files from Sony A7R II to Premiere Pro CC7/CS6/CS5
Source: Will Final Cut Pro X support XAVC files from Sony PXW-X70
Re: A solution to editing Sony PXW-X70 XAVC in FCP X
Postod Andyeric » 30.06.2015 10:05
Related:
Postod lauralily520 » 02.07.2015 10:39
Sony RX10 II Announced – Records UHD 4K video in XAVC S format
Sony Announced its RX10 successor , the camera comes with new 20.2 MP, 1″ Exmor RS BSI CMOS stacked CMOS image sensor with a DRAM chip, with the help of newly developed tech the camera can capture more sharp images with improved color and contrast ratio, when the DRAM chip is integrated into the Bionz .
UHD 4K video is supported up to 30 fps in XAVC S format thanks to a high-speed front-end LSI which processes the data with full pixel readout with no line skipping or pixel binning. The XAVC S format allows for high-bitrate shooting up to 100 Mbps. A built-in stereo microphone and an external mic jack are provided as is a headphone jack from audio monitoring. Professional features such as full manual exposure control and uncompressed off-camera recording are also supported.
However, We usually saw FCP 7 users encounter importing issues when attempting to edit XAVC S in Final Cut Pro 7.
Q1: I Want to buy Sony RX10 mark ii. It can shoot video with AVCHD but wanted to check the better encoder XAVC-S. I'm working with FCP 7 and it does not recognize the XAVC-S file (although I can still play the file with QT - a bit strange. I guess I'm missing something here...).
Q2: I want to import Sony A7R II footage to FCP 7. My question is it possible to work XAVC S files in FCP 7 natively and how to do?
Normally, we would like to adopt Final Cut Pro to edit some XAVC S footage from Sony AS100V, Sony a7s, Sony AX33, Sony a7ii, Sony X1000V, Sony RX100 IV etc. in order to get better videos or more wonderful video files. Well, Final Cut Pro X might not support XAVC S format. In this case, to smoothly edit Sony RX10 MK II XAVC-S in Final Cut Pro 7, the easy workaround is to convert XAVC S to ProRes MOV which is the best codecs with best results when working with Final Cut Pro.
Converting Sony RX10 II XAVC S to Apple ProRes for Final Cut Pro 7
The quick workaround is to use the easy-to-use yet professional app Brorosft Video Converter for Mac which can be used as a XAVC S to ProRes Converter under OS X(including Yosemite and Mavericks). With it, you can effortlessly transcode XAVC S files to ProRes 422 encoded MOV for Final Cut Pro 7 and it works well and converts flawlessly. Meanwhile, the Mac Video Conversion tool can create files compatible with various non-linear editing systems like Avid Media Composer, FCE, FCP X, iMovie, and Adobe Premiere Pro and more. Below is how.
Read More: XAVC S to iMovie | XAVC S to Adobe Premiere | XAVC S to Avid
1: Load XAVC S to the converter
You can directly drag and drop the XAVC S files to the software, or click "Add" or "Add From Folder" to locate the XAVC S clips into the converter.
2. Choose output format
Press "Format" option and navigate the mouse cursor to choose "Format > Final Cut Pro > Apple ProRes 422 (*.mov)" as the best codec for FCP 7on Mac.
Tips: You can click “settings” button in the main interface to customize the output video’s parameters, such as resolution, frame rate, etc.
3. Start XAVC S to Final Cut Pro conversion
Click the big "Convert" button at the bottom right corner, this Mac XAVC S converter will start to transcode Sony RX10 II XAVC S to ProRes for FCP 7! Once the conversion completes, you are free to use RX10 Mark II XAVC S files in FCP!
Additional Tips:
If you have problems playing, editing, converting or sharing XAVC, XAVC S or other 4K ultra HD videos on Mac/Windows, please enter "4K Workflow Column" to get the solutions.
More Topics:
Transcode C500 to Final Cut Pro (FCP X/7/6)
Tips working Sony HDR-MV1 MP4 in iMovie
Edit and Transfer Nikon 1 V3 MOV files in FCP 7/X
Transcode 4K H.265 from Samsung NX1 to FCP X/7
Make Sony HDR-MV1 footage and Sony Vegas Friendly
Can Sony Vegas Pro import Nikon D7200 videos natively
Edit Sony RX10 II/RX100 IV 4K XAVC S in Premiere Pro
Transfer DivX Plus HD (MKV) files to your Sony PS3, PS4
Convert Nikon D72000 MOV shooting to Sony Vegas for editing?
Edit Sony RX10 Mk II in After Effects CC/CS6/CS5/CS4 Smoothly
Convert Panasonic HC-VX870 4K footage for Editing in Premiere Pro
Source: Import UHD 4K xavc s files from Sony RX10 MK II to FCP 7
