How to Transfer Blu-ray disc on Surface Hub
Postod lauralily520 » 24.06.2015 9:36
Summary: Wanna know how to play Blu-ray movies on Surface Hub Tablet? Read this guide and get the best solution for enjoying Blu-ray movies on Surface Hub.
Microsoft has revealed the latest device in its Surface family of products-Surface Hub, a large-screen touch panel powered by Windows 10.
The device features a 4K display, multi-touch capabilities that recognize up to 100 touch points, digital inking, integrated cameras, sensors and microphones. For movie lover, there is no doubt that it is an ideal portable device to enjoy Blu-ray movies. This article will teach you how to play Blu-ray movies on Surface Hub.
Obviously, the Surface Hub does not have the specific hardware needed to insert Blu-Ray discs, and this is reportedly one of the reasons why Microsoft didn't include software to play physical media discs in Windows 10. Thus, you need to select a good Blu-Ray ripping tool to rip Blu-ray movies into MP4 so that you can enjoy Blu-ray movies on Surface Hub without any issue.
Brorsoft Blu-ray Ripper is such a tool that can completely achieve the goal. It can rip all most all protected Blu-ray and DVD discs/floder/ISO/IFO image files to any formats you need, such as MP4, MOV, AVI, WMV, FLV, MPG, etc so that you can transfer and enjoy on Surface Hub, Surface 3 tablet, Surface Pro 3, Android/Apple/Windows 10/8 tablet, or other playable devices. If you are a Mac user, pls turn to Brorsoft Blu-ray Ripper for Mac. Now download the software on computer and follow the guide below to start conversion.
How to Stream Blu-ray movies to Surface Hub
Step 1. Launch Blu-ray Ripper on your Windows or Mac computer, insert Blu-ray to your BD-ROM and then click disc button to add the source BD.
Step 2. Tap on the "Format" bar to select "HD Video-H.264 HD Video(*.mp4)" as the output file format for streaming 1080p HD video on Surface Hub Tablet with lossless quality.
Step 3. After you choose the output format, you can set output parameters by clicking the "Settings" button including resolution, bitrate, codec, frame rate .etc
Step 4. Hit Convert to start ripping Blu-ray discs to Microsoft Surface Hub at free will. After that, you can get the encoded movies under "Open" panel.
How to transfer converted Blu-ray video to Surface Hub Tablet
1. Copy files onto a USB flash drive or memory card on your other computer.
2. Insert the USB flash drive or memory card into Surface.
3. Tap or click the notification that appears in the upper-right corner of the screen.
4. Tap or click Open folder to view files or Import photos and videos.
File Explorer opens.
5. Select the files or folders you want to add to Surface. Tap or click Home, and then tap or click Copy to.
6. Select a location. For example, choose Documents if the flash drive or memory card contains documents.
Related Guides:
Convert/Import Blu-ray to Avid Media Composer
Encode AVI videos to AIC .mov for iMovie editing
Top 10 Best Video Player Apps in 2015 for Android
How to Make iPhone videos editable in Premiere Pro
Simply Copy Blu-ray movies to Surface Hub for playing
How to Play MKV/AVI/VOB/MOV on Nokia N1 Tablet
How to convert and import MXF files to Davinci Resolve
AVI to QuickTime - How to Play AVI in QuickTime Mac
Transcode 4K MXF/MOV/MP4 to DNxHD for Avid MC
Import Sony a7R II 4k xavc s files to Windows Movie Maker
Natively Edit Sony PDW-700 XDCAM MXF in Premiere CC
Transfer VOB files to WMV for importing to Windows Movie Maker
Source: Watch and View Blu-ray movies on Surface Hub Tablet
