Import Sony Alpha 7 MTS in Premiere Pro, After Effects
Postod Andyeric » 24.06.2015 9:13
Smoothly Edit Sony Alpha 7 MTS in Premiere Pro, After Effects
Summary: Facing the issue that you can't load MTS files from Sony Alpha 7 into Premiere Pro and After Effects? In this article, we will give you the tips how to import and edit AVCHD MTS files in Premiere/AE on Mac without problems.
Source: Import MTS to Adobe Premiere/After Effects
Sony's unveiling of its latest cameras, the Alpha 7 and 7R. Mirrorless and relatively compact, just like the company's NEX series, these new Alpha shooters are built around the same sort of full-frame sensor you'd find in pro DSLRs like the Nikon D800 or Canon 6D. The cheaper Alpha 7 makes do with just 24 megapixels, but it also has a hybrid autofocus system that combines phase-detect and contrast-detect AF for even faster operation.
Hot Search: Sony FDR AX-100 | Sony Alpha 7R | Sony Alpha a7II | Sony F5/F55 | Sony HDR-PJ275 | Sony NEX-5R | Sony FDR-AX1 | Sony Alpha NEX-6 | Sony Alpha 77 Mark II | Sony HX90V
I get a sample of Sony Alpha 7 now, if I drop a .mts file from my sony camera into Prem Pro, it shows video but no sound? If I drop it into CS5.5 the sound works and it need time for rending. I have downloaded an updated version of Prem Pro from Adobe today. And still it won't handle mts files? I can't understand why it is so hard to find a solution to this problem. Has Any one got a solution that works?
According to our experience and other user's feedback, their Premiere Pro and After Effects still can't support Sony AVCHD well. Due to the video codec problem, they can not smoothy import .MTS from Sony Alpha 7 to Adobe Premiere and After Effects. To help these people out, I've tried every means to look for a really effective way. Accordingly, hereby I can wait to share this good news with you. This article will focus on this problem…
The best solution I found is to convert Sony Alpha 7 mts to Premiere/AE compatible .MOV format first. In this case, you need to use a 3rd party convert to Sony .mts files into mov which is full suppported by Premiere/AE. Pavtube MTS/M2TS Converter for Mac is the one I choose. Easy convert AVCHD .mts from Sony Alpha 7 MTS to mov files, which will fast import into Premiere Pro/After Effects for editing. As for video quality, at least I cannot distinguish any loss by naked eyes. (See also Top 3D MTS/M2TS Converter for Mac Review)
Steps to transcode Sony Alpha 7 MTS for Adobe Premiere/After Effects on Mac
Tips: If you are Windows users, refer to the guide: "Import AVCHD to Premiere" and "Import MTS to After Effects"
Step 1. Free download Pavtube Sony AVCHD Converter for Mac. Install and launch. Click "Add" or "Add from folder" to import your .mts files from Sony Alpha 7.
Step 2. Click format bar to choose the output format, you can click and choose "MOV (AVC) (*.mov)" as output format under Adobe Premiere/Sony Vegas catalogue for editing in Adobe Premiere and After Effects.
Step 3. You can click "Settings" button to adjust the resolution, bitrate, etc.
Step 4. Click "Convert" button to start to convert Sony Alpha 7 MTS to Adobe Premiere/AE editable format, just follow the steps above and have a try.
After converting, you can freely import the converted video files into Adobe Premiere/After Effects. Just start up, follow File > Import > File…
In this way, you can easily and fast ingest your Sony Alpha 7 MTS videos in Adobe Premiere/After Effects on Mac smoothly with no issues.
Read More Guides:
Convert DSLR Videos to ProRes for KiPro Devices
Merge MXF Files for Using in Magix Video Pro X
Edit Sony XDCAM HD422 Files in Final Cut Pro X
Batch Convert MOV Files to Premiere Pro for Editing
Edit Sony (MPEG2 SD) Videos in Pinnacle for uploading & burning
Import Canon XF305 MXF to FCP 7 for further editing
Import Panasonic AG-DVX200 4K to iMovie/FCE for Editing
How to Get PSF AVCHD Files to Progressive?
Import Ikegami HDS-V10 MXF to Windows Movie Maker
Sony HDV to QuickTime Import Issues on Mac
Convert Raspberry Pi H.264 Recordings to FCP X
Convert MXF to MPEG-4 for Viewing on PC
Effortless convert Sony PJ780/PJ790V AVCHD on Windows
Solution to work with Sony PJ780/PJ790V mts files in iMovie
Convert Sony/Canon/Panasonic MTS to YouTube/Google/Myspace
