Tips for editing VOB files in Windows Movie Maker smoothly
Postod lauralily520 » 19.06.2015 10:56
Summary: In this guide, you can get to know the easy method to convert VOB files to Windows Movie Maker friendly format for playing, editing easily.
As known to all, the latest Windows 7 and Windows 8 can play DVD .vob files properly. However, you can't edit VOB video with Windows Movie Maker. VOB is not supported by Windows Movie Maker and early Windows system. To import VOB to Windows Movie Maker for working beautifully, the easy solution is to convert VOB to WMV, the best format for Windows Movie Maker.
One of the tricky things about conversion is how good of quality you want it to have. If you wanna a lossless VOB to Windows Movie Maker conversion, a professional VOB file converter is required. Brorsoft Video Converter is just the right tool for you. It helps you effortlessly convert VOB files to Windows Movie Mkaer compatible .wmv with high quality, no matter your VOB files are ripped from your DVD discs, or downloaded online. After converted, you can easily import the converted WMV files to Windows Movie Maker for editing without hassle. Besides, this video converter also supports converting VOB/AVI/WMV/MKV/MPG as well as 4K videos for using in Sony Vegas Pro, Adobe Premiere Pro, Avid Media Composer, Pinnacle Studio and more NLEs(Get more Video and Audio Tips).
Convert VOB to Windows Movie Make step by step
1. Add VOB files
After installation of the best VOB to Windows Movie Maker converter run it and you'll see the program interface shown as below. Then import VOB files to the program by dragging and dropping, or by clicking the "Add Files" button to locate and load VOB files.
2. Choose WMV as output format
Press the Format box and select HD Video > WMV HD(*.wmv) on the dropdown menu as output format. Besides, you can also choose Divx HD(*.avi) as output if there is no .wmv codec installed on your PC.
Tip:. If you need to change the codec, resolution, frame rate and other settings, just click the "Settings" option at the bottom right corner.
3. Start converting VOB to WMV
The final step is to click the "Convert" button and all the added VOB files will be converted to WMV format for Windows Movie Maker.
After the conversion, find your converted video clips in the destination folder ("Open") and now you can play or edit the converted VOB videos with most Windows Movie Maker perfectly.
More Guides:
FFmpeg can't convert ProRes to MP4- Solution
How to convert VOB for Windows Movie Maker
Transfer ProRes to MP4 for Mac OS X (Yosmite)
Encode AVI videos to AIC .mov for iMovie editing
Guide: How to convert and import AVI files to iMovie
Editing Panasonic HC-X920 AVCHD in FCP 7, FCP X
How to convert and import MXF files to Davinci Resolve
Convert MXF videos to DaVinci Resolve acceptable format
How to rip Blu-ray/DVD movies to Oneplus One/Two in clicks
Recover iPhone data caused by updating to iOS 8.3 from iTunes
Converting WMV/AVI/VOB/MKV for playback on HTC One M9+
Getting Sony A7R II Media (4K XAVC S/AVCHD/MP4) into FCP 7/X
Source: Transfer VOB files to WMV for importing to Windows Movie Maker
Re: Tips for editing VOB files in Windows Movie Maker smooth
Postod Andyeric » 24.06.2015 8:58
Upload AS200V XAVC S to YouTube or Burn to DVD
Viewing through the Sony HDR-AS200V XAVC S forums online, we can find so many issues related to XAVC S about how to upload XAVC S to YouTube, how to burn XAVC S to DVD and etc. Read this guide below, XAVC S to YouTube workflow is provided as well as XAVC S to DVD.
"The versatile Sony AS200V Full HD Action Cam is designed to go wherever you do - whether on a mountain expedition or just for a walk in the park. So you will be very excited that you can share attractive videos shoot with AS200V to your friends or on website because it records your excellent time. It features a water-resistant design and simple one-button operation. Video is recorded to a separately available microSD card, with the option for MP4 and professional XAVC S compression.
For sharing with friends or uploading to the website, you must be probably choosing the platform of YouTube as for it is a video-sharing website on which users can upload, share, and view videos. It is a great resource. Learn from YouTube official website, since only FLV, AVI, MPEG, MPA and etc. can be supported by YouTube very well, how can we upload XAVC S to YouTube? If an XAVC S video converter is needed, what should we do to convert XAVC S to YouTube?
"Equally, for keeping good moments and memories, we can burn these XAVC S videos to DVD, sooner you will find it should be a time consuming job or impossible. To be frank, you must be disappointed for DVD can’t accept XAVC S format. As two headache problems have been put forward above, what solutions can we take? To get the work done, you can depend on Pavtube XAVC S Video Converter". With it, no matter for uploading XAVC S to YouTube or burning XAVC S to DVD, it can deal with it smoothly.
Tips on how to upload AS200V XAVC S to YouTube or burn to DVD:
Step 1:After downloading and installing, launch the XAVC S Video Converter. Open the main interface and choose the "Add video" button to load your XAVC S files captured by Sony AS200V. For the multiple video clips we can hit the "Add from folder" button.
Step 2:Click the "Format" drop-down list, and choose the corresponding output format for YouTube. We would like to introduce you to select "Flash Video>>FLV H.264 (*.flv)".
Step 3:Most of you guys must have the desire of a further editing with your output videos, right? On the main interface, "Edit" is waiting for you. "Trim" to decide where to start and where to end, "Crop" to cut some unwanted clips, "Subtitles" to add some explanations to your audience.
Step 4:Click "Convert" button and start XAVC S videos conversion. After conversion, you can get the converted files by clicking "Open" button. Now, you can upload the generated AS200V XAVC S to YouTube smoothly.
Conclusion:With this XAVC S Video Converter, you can choose "Common Video>>MPEG-2 Video (*.mpg)" in step 2 for burning XAVC S to DVD. Other operations are all the same. Besides, the newly released Pavtube DVD Creator "lets you burn any kind of video sources to playable DVD. With its simple wizard-style user interface and powerful editing features, DVD authoring and burning can't be easier.
Further Reading:
source: http://bestvideoking.blogspot.com/2015/ ... o-dvd.html
