Batch convert MKV/VOB/AVI to Nexus 7/Nexus 10
Postod lauralily520 » 17.06.2015 9:33
Summary: If you have trouble playing MKV, AVI, VOB on Nexus 7/Nexus 10, you're in the right place. This guide will tell you how to get Nexus 7/10 play MKV, AVI, VOB movies smoothly.
I made the leap and I bought an Android tablet, Google Nexus 10. What I did next is adding my video library on my PC to the tablet for playback on the go. However, I met troubles playing MKV, AVI, VOB videos on Nexus 10. Goggled the issue, I found there are many guys are stuck in the AVI/MKV/VOB to Nexus 7/10 incompatible issues. Before writing down this article, I’ve worked the solution. Now share the best way to play MKV/VOB/AVI on Nexus 7/Nexus 10 with all of you.
Method 1: Install Media Player for Nexus 7/Nexus 10
The first way that most people first consider is to install a video player for Nexus 7 or Nexus 10 tablet that can play AVI, MKV, VOB files. If you search online, you will find there are many free video players for Android in the market including MoboPlayer, MX Player and RockPlayer2.
Note: Although there are so many media players for Android, not all videos files can be played well. Many of them can’t play MKV files that contained DTS audio, Full HD 1080p or 4K Ultra HD videos on your device. What’s more, some apps will slow download your device.
Method 2: Convert MKV/VOB/AVI to Nexus 7/Nexus 10
The best way to play MKV, AVI, VOB movies on Nexus 7/10 is to change these videos to Nexus 7/10 compatible formats like MP4. To achieve it, you can use Brorsoft Video Converter.
This video converting tool supports batch conversion that can help you convert .vob, .avi, .mkv to Nexus 7, Nexus 10 with ultra-fast speed and zero quality loss. Plus, it supports setting relative output parameters as you want before start conversion. If you are Mac users, please turn to the equivalent Mac version Brorsoft Video Converter for Mac to transcode MKV/VOB/AVI files to Nexus 10, Nexus 7 and more Android devices on Mac OS X (Yosemite included). Once you download and install the video converter program, follow the steps below.
Step-by-Step Guide on converting AVI/MKV/VOB files on Nexus 7/10
Step 1. Add videos to converter
Run the Android video converter. Click the "Add Files" or "Add from Folder" button to load MKV, AVI, VOB video files for converting.
Step 2. Choose output format
Click "Format" bar, you can get optimized videos for your Nexus 7, Nexus 10 under "Android”. Just choose “Google Nexus 10 H.264 Video(*.mp4)" or “Google Nexus 7 H.264 Video(*.mp4)" as the output format.
Tip: If you don’t like the default settings, by clicking the Settings icon, you can adjust video and audio parameters like codec, bit rate, frame rate, sample rate, etc., in that way, you can take charge of the size and quality of the output files.
Step 3. Start conversion
As soon as all the above settings are completed, you can press “Convert” button to start converting VOB, AVI, MKV to Google Nexus 7 or Nexus 10 playable MP4 video. You can follow the conversion process via the pop-up windows.
After conversion is done, simply click "Completed" to back to main interface, and click "Open" button to find generated .mp4 videos. Afterwards, you can transfer the converted MKV/VOB/AVI clips into Nexus 7/Nexus 10 for playback with ease.
See also:
Tips for converting DNxHD to ProRes
Can't import XAVC S into FCP 7- A quick Fix
FFmpeg can't convert ProRes to MP4- Solution
Transfer ProRes to MP4 for Mac OS X (Yosmite)
Guide for Converting Video on Windows 8.1 with ease
How to convert videos on Windows 8.1 fast and easily
Transcode AVI to ProRes 422/444/422 HQ for FCP 6/7/X
Convert XAVC MXF to ProRes 422, 4444 for Final Cut Pro
Converting WMV/AVI/VOB/MKV for playback on HTC One M9+
Recover iPhone data caused by updating to iOS 8.3 from iTunes
Source:How to View AVI/MKV/VOB Movies on Nexus 10
Re: Batch convert MKV/VOB/AVI to Nexus 7/Nexus 10
Postod Andyeric » 18.06.2015 5:28
Cinemartin Cinec Alternatives: Encode H.265/HEVC on Windows 10/8.1/8/7/XP
Overview: In the following ariticle, besides Cinemartin Cinec, we are going to introduce you another H.265/HEVC encoder which can also has strong ability of working H.265/HEVC videos on Windows 8.1/8/7/XP.
Until now, with the latest H.265/HEVC codec released out, there are not so many devices that can input and output this kind of newest codec, no matter for digital camcorders or media devices. As I know that for now, the only two camcorders that can shoot this H.265/HEVC codec footage: Samsung NX1 and Samsung NX500. Due to this situation, we got some troubles in encoding H.265/HEVC videos on Windows 10/8.1/8/7/XP. Fortunately, we here can offer you two new H.265 encoders that can handle this job well.
Solutions: Cinemartin Cinec 3.X and Pavtube Video Converter 4.8.2.0(Both for Windows)
Scheme 1: Cinemartin Cinec H.265/HEVC encoder
Cinemartin Cinec is a multi video encoder transcoder, a video converter for windows that leads the film and cinema encoding tools. Cinec is the only converter that allows you to export to Prores, H.264 and H.265 on a Windows PC. Itself is the only one that allows users to encode to HEVC H.265* easily and for much less than what the few H265 existing encoders cost.
Main features we should know for mare details:
  • Brilliant and professional standards
  • Providing you with the latest codecs
  • Fastest, time saving, simple and easy of use
  • Almost any input and output
Converter includes several features not available on any other tool of its category on the market. On the professional way, it has been build with focus on broadcast, customers demanding the best quality within standards, cinematographers, video and vfx company, film restoration, distribution medias, TVs and more. It has been developed to be user friendly, as fast as possible or desired by user (as per his convenience), and providing the best outputs.
Source from: http://www.cinemartin.com/cinec/
Scheme 2. Pavtube H.265 Video Decoder and Encoder
Pavtube studio has recently upgraded this kind of Video Converter to the latest version 4.8.2.0 which is especially designed for H.265/HEVC codec on Windows 10/8.1/8/7/XP. Pavtube studio is a nice video converting brand which has been devoted in the video encoder/decoder area for a long time. So it has a good reputation on the related market.
More details on how to encode your H.265/HEVC videos on Windows PC. Let's take a close look below. You will find it's an easy operation job that all of us can handle it well.
Popular features you may be interested in well:
  • Various input and output video formats can be supported well
  • Easy operation and concise interface
  • Support the H.265/HEVC codec (version 4.8.2.0)
When you download this H.265 converting program, open the main interface, with "Add video" and "Add from folder", you can load your original files successfully. Then on the output list, you can find the 'H.265 Video' on the '"HD Video" item for output. Since we are going to encode the H.265 footage, we suggest you to choose some best ones especially for Windows operation. In "Common Video" button, "H.264 Video Baseline/Main/High Profile" can be the suitable output ones. From H.265 to H.264? See the screen shot below!
Optional function for advanced users: "Settings" and "Edit" on the main interface, here we can adjust our output videos with the style that we want. Of course we can skip this step and start our conversion work by clicking the button "Convert" there. For now, are you still worring about how to work your H.265/HEVC videos on Windows 10/8.1/8/7/XP? Come on! Top H.265/HEVC Encoder is offered here for all of you! Let's remove it!
Notes: If you have already owned the Pavtube Video Converter, just open the main interface and select the Help -> Update to upgrade to the latest version 4.8.2.0 for free.
More related:
Top 5 Best H.265 (HEVC) Codec Decoding and Encoding Tools
Upload H.265/HEVC Videos to YouTube or Vimeo
Convert H.264, MP4, MOV, AVI, MKV, FLV to H.265 video
Samsung NX500 4K H.265 to Premiere Pro CC workflow on Mac
Playback H.265/HEVC Files on Samsung PMS
Import H.265/HEVC Files to MX Player for Watching
Will the Xbox One/360 receive H.265 4K support? Not Yet!
Stream HEVC(H.265) 4K Videos to Apple TV 3/2/1
Stream H.265/HEVC 4K videos to Roku 3, 2, 1 for sharing
How to Transfer H.265 video to iTunes on PC
How to Play H.265/HEVC Files on VLC on Mac?
Edit Samsung NX1 H.265 Files in Avid Media Composer 7 on Mac
Encode/Decode Samsung NX1 H.265 Videos to WMM
Ingest NX500 4K H.265/HEVC to QuickTime for Playing
Source: http://handycameratips.jimdo.com/2014/12/30/encode-h-265-videos-on-windows/
