Importing H.265 footage into Premiere Pro CC/CS6/CS5
Postod lauralily520 » 12.06.2015 9:44
Summary: Does Premiere Pro have H.265 codec support? The answer is no. To edit H.265 in Premiere Pro CC/CS6, the easy workaround is to transcode H.265 to a more editing-friendly format, such an Adobe Premiere's MPEG-2. Here is the simple how-to.
Searching through the Adobe forum, you would find lots of threads that related to H.265 and Premiere Pro issue. Many guys are eager to know will Adobe Premiere Pro(CC) support direct import and editing of H.265 footage? Frustratingly, as far as we know, currently Adobe Premiere Pro lacks the support for H.265/HEVC codec. To work H.265 in Premiere Pro smoothly, a quick solution is to convert H.265 to Adobe Premiere Pro most compatible format no matter on Mac or Windows.
H.265(HEVC), a highly compressed format, is not easy for editing in Adobe Premiere Pro, even the latest Premiere Pro CC. Well, if you make the recordings editable before taking to the program, the incompatible error won’t happen any more. As far as I know, MPEG-2(.mpg) is the best format for Adobe Premiere Pro. Here you can download and apply Brorsoft Video Converter for Mac to achieve the goal in a fast way.
This professional H.265 converter is the solid tool to help users convert the H.265 footage like from Samsung NX1, NX500 to Adobe Premiere Pro without quality loss. It also offers the optimal profiles for Final Cut Pro, iMovie, Avid Media Composer, Adobe Premiere Elements and more. If you want to decode H.265 to Adobe Premiere on Windows, please get Brorsoft Video Converter. Download the program to start convert H.265 for Adobe Premiere Pro.
Read More: H.265 vs H.264 | H.265 to iMovie | Play H.265 using VLC
How to convert H.265 video to Premiere Pro CC/CS6/CS5
Step 1. Add H.265 files
Install and run the best H.265 to Premiere Pro converter and transfer your 4K H.265 recordings to the program no matter directly from a camera or from hard drive.
Step 2. Set output format
Click "Format" menu firstly and then follow "Adobe Premiere/Sony Vegas" to set MPEG-2 as the output format.
Step 3. Profile Settings
In case the default settings do not fit your requirement, you can click "Settings" button and enter "Profile Settings" panel to adjust video size, bit rate, frame rate, sample rate and audio channels. This H.265 converter app can maintain original 4K resolution for you if you need or downscale 4K to 1080p.
Step 4. Start converting H.265 to MPG
Click the "Convert" button; it would start transcoding H.265 to MPEG-2 for Premiere Pro immediately. After conversion, tap "Open" icon in the main interface to locate result video. Launch Adobe program to import converted H.265 footage to Adobe Premiere Pro CC/CS6/CS5 with easy editing.
Additional Tips:
Besides Adobe PP, this H.265 converter for Mac can also support converting H.265 files to Final Cut Pro, iMovie, Avid Media Composer, etc NLEs. What’s more, if you want to play H.265 videos in iTunes, QuickTime, VLC Media Player, this program is also the right app to help you convert and generate the optimal formats. Just choose a proper output format in the second step.
More topics:
How to add H.265 video files to iTunes
Workflow for 4K files in Adobe After Effects
How to Get iMovie Work With H.265/HEVC Footage
Workflow for Importing AJA Cion 4K video to FCP 7/6
H.264 in AE - Easily Work with H.264 files in After Effects
How to view MKV/AVI/VOB video files on Android device
Edit AJA Cion 4k videos in Adobe Premiere Pro CS6/CS5/CS4
[url=file:///D:/Maxthon2/Plugin/Html2UBB/How%20to%20Convert%20Samsung%20NX500/NX1%204K%20H.265%20to%20H.264%20.MP4]How to Convert Samsung NX500/NX1 4K H.265 to H.264 .MP4[/url]
Convert VOB to Android and Play VOB on Android Tablet/Phone
Convert Samsung NX500 H.265/HEVC files to Adobe Premiere Pro
Source:How to convert H.265 video to Premiere Pro CC/CS6/CS5
Re: Importing H.265 footage into Premiere Pro CC/CS6/CS5
Postod Andyeric » 24.06.2015 10:59
H.265 Converter- Encode/Decode H.265 to MKV, MP4, AVI, MOV, WMV, FLV on Mac Yosemite
Summary: As the newest codec and with features of smaller size and higher quality, H.265/HEVC has become more and more popular in our video codec area. What brought to us was the related questions. What's the true meaning of H.265/HEVC? How could we convert, edit or play H.265/HEVC videos? Is there any best methods provided for us to handle the H.265 encode and decode workflow well?
Q1: What is H.265/HEVC?
High Efficiency Video Coding (HEVC) is the latest generation video compression standard developed by the ISO/IEC Moving Picture Experts Group and ITU-T Video Coding Experts Group, through their Joint Collaborative Team on Video Coding. HEVC is also known as ISO/IEC 23008-2 MPEG-H Part 2 and ITU-T H.265. HEVC provides superior video quality and up to twice the data compression as the previous standard (H.264/MPEG-4 AVC). HEVC can support 8K Ultra High Definition video, with a picture size up to 8192×4320 pixels.
Q2: What's the difference between H.265 and the previous standard H.264?
H.264 has been a huge success. It's a flexible codec standard that's used by streaming services, satellite providers, and for Blu-ray discs. It's scaled remarkably well since it was first proposed and is capable of handling 3D, 48-60 fps encodes, and even 4K. The Blu-ray disc standard doesn't currently include provisions for some of these technologies, but the H.264 codec itself is capable of handling them.
However, while it can handle these types of encodes, it can't do so while simultaneously keeping file sizes low. A new standard is necessary to push file/stream sizes back down while driving next-generation adoption, and that's where H.265 comes in. It's designed to utilize substantially less bandwidth thanks to advanced encoding techniques and a more sophisticated encode/decode model.
Q3: How to encode/decode H.265/HEVC to MKV, MP4, AVI, MOV, WMV, FLV on Mac Yosemite?
After testing countless freeware and commercial software, considering the ease of use and lossless quality, we would recommend Pavtube Video Converter for Mac to you which is an all-in-one H.265 Converter. As upgraded to the latest version 4.8.5.0, this Mac Video Converter can definitely support H.265 encoder/decoder very well. Moreover, it can encode/decode H.265 to MKV, MP4, AVI, MOV, WMV, FLV on Mac Yosemite with fast speed, easy operation and quality maintained.
Specific guide on how to encode/decode H.265 to MKV, MP4, AVI, MOV, WMV, FLV on Mac Yosemite:
Step 1: Run the upgraded Mac Video Converter, and click the "Add video" button to load your original H.265 recordings. If you want to load several files at one time, "Add from folder" button is available. Besides, you can also drag and drop the files to the main interface directly.
Step 2: When you launch the program and load your H.265 files in , then we can choose the suitable output formats. To convert H.265 to MKV, you can choose "HD Video>>MKV HD Video (*.mkv)". To convert H.265 to MP4, you can choose "HD Video>>H.264 HD Video (*.mp4)". To convert H.265 to AVI, you can choose "HD Video>>AVI HD Video (*.avi)". To convert H.265 to MOV, you can choose "HD Video>>H.264 HD Video (*.mov)". To convert H.265 to WMV, you can choose "HD Video>>WMV HD (*.wmv)". To convert H.265 to FLV, you can choose "Flash Video>>FLV H.264 (*.flv)".
Step 4: When everything is ready, you can take a preview by hitting "Play" button. If you are satisfied with the final result, you can click "Convert" button to finish the conversion work.
Conclusion: When the conversion is done, you can click "Open" to get your generated files. Now, you can use them for editing, playing, uploading, sharing and all you want. Good news for everyone! All of us can get 40% discount off before May, 1st, 2015. Come on! Why not seize the chance and take a close look at the event?
Further Reading:
[list=none][*]How to Upload H.265/HEVC Videos to YouTube or Vimeo?: Many users who use some latest H.265 cameras like Samsung NX 1 would complain that "My attempts at uploading H.265 videos to YouTube fail during processing."[*]Top 5 Best H.265 (HEVC) Codec Decoding and Encoding Tools: While it has not be accepted by most media players or NLEs yet so today here in this page, we would like to introduce you some best H.265/HEVC encoder and decoder to help us to work well with this new H.265/HEVC.[*]Top 5 Best Video Converter for Mac Reviewed 2015: When you are doing to watch some videos on Mac, have you met the trouble of ‘Error message' appeared on the screen?[/list]
2015 Mother's Day is coming! What would you like to send to your mother to make this year's festival unforgettable? A bundle of flowers or a bottle of her favorite perfume as usual? What do you think of the idea of buying a tech-type gift of this year's Mother's Day? To record some precious moments we stay with mother, Pavtube Studio here offers us a big promotion! All video converters we can enjoy a coupon during the celebration!
Promotion Plan A:
On Mother's Day, May 10th, all users can enjoy 40% off discount for all video products in Pavtube Studio! Just write down 'What do you want to say to your mother' under the promotion page is okay!
Promotion Plan B (For all Facebok users):
During May 7th to May 14th, if Facebook users 'Follow' our Pavtube official account and 'Like', all of us can enjoy a big 50% off discountof the strongest tool---Pavtube HD Video Converter for Windows / Mac! With all video conversion works well, this program has a good reputation online.
Source: http://bestvideoking.blogspot.com/2015/ ... n-mac.html
