Easily Import Sony PXW-X320 XAVC videos to Avid
Postod lauralily520 » 09.06.2015 10:49
The PXW-X320, part of the XDCAM HD422 family, is a high-performance SxS memory camcorder which inherits field-proven operability from the reputable PMW-320. It supports XAVC offering high quality content creation in the HD domain. After recording, users may wanna open Sony PXW-X320 XAVC in Avid directly, while, it's not so easy for XAVC users.
"I followed instructions on installing PDZK-MA2_v2.31_for Mac driver to make XAVC files editable in Avid with AMA. However, when I load the XAVC footage into the source monitor it says: CORE CONSISTENCY CHECK FAILURE. What's the problem? Thank you for any help!"
Although Avid plug-in can solve some people's confusion about importing XAVC to Avid MC for editing, it's not for all the cases. The simplest workaround I found on Google is to change Sony PXW-X320 XAVC to DNxHD with a powerful third party program if you are eager to get a fluent workflow.
Brorsoft Video Converter for Mac is the best Mac Sony XAVC to Avid DNxHD (*.MOV) Converter which can encode XAVC to Avid DNxHD (*.MOV) before importing to Avid Media Composer. Besides Avid, it also offers other optimized codecs for NLEs such as Apple ProRes for FCP, AIC for iMovie/FCE, MPEG02 for Premiere and so on. Now, download the software online and follow the guide below to start Sony PXW-X320 XAVC videos to Avid conversion.
How to Load Sony PXW-X320 XAVC videos to Avid
Step One: Run the top-rated Sony XAVC Converter in Mac. Click "Add" button to load the source Sony PXW-X320 XAVC files.
Step Two: Go to format column to choose "Avid Media Composer" > "Avid DNxHD(*.mov)" as output format for Avid.
Tips: If you'd like to customize advanced audio and video parameters like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sample rate, audio channels, pls turn to "Settings" page.
Step Three: Hit the convert button, it will start converting XAVC from Sony PXW-X320 for importing to Avid. Soon after the conversion, just click "Open" button to get the generated files for natively editing in Avid perfectly.
Read More:
How to Backup DVD/Blu-ray to USB Flash Drive
Editing XAVC S in Adobe Premiere Pro CS6/CC
MTS to Premeire Pro CC/CS6/CS6/CS4 Workflow
Editing with Canon XF205 footage ini FCP 6/7/X
Enjoy DVD, Blu-ray movies in H.265/HEVC format
Solve Windows Movie Maker Won't Play MKV Issue
Transcode Sony XDCAM to FCP X or FCP 6/7 on Mac
Add subtitles to AVI natively - Merging SRT with AVI files
H.264 in AE - Easily Work with H.264 files in After Effects
Watch/View Blu-ray/DVD movies onto Windows 8.1 Tablets
Add and Play AVI/VOB/MKV on Nexus 9 with friendly format
How to Successfully Play MKV in QuickTime on Mac/Win (Windows 10)?
Rip Blu ray/DVD to Sony PS4/PS3 and enjoy Blu-ray/DVD movies on PS3/PS4
Source:How to Edit Sony PXW-X320 XAVC files in Avid
Re: Easily Import Sony PXW-X320 XAVC videos to Avid
Postod Andyeric » 24.06.2015 11:08
Canon G7 X MP4 to Premiere Pro CC workflow on Yosrmite
Summay: Though Premiere Pro has announced the compatibility with MP4, people still have problems in importing MP4 to Premiere sometimes, such as "No sound or video when loading MP4 file into Premiere Pro CC?" This article aims to solve the above questions in two parts.
Source: Get Canon G7 X MP4 Work in Premiere Pro CC on Yosemite
"Hi, I shot a lot of H.264 MP4 videos of a wedding ceremony with my Canon G7 X camcorder. Now, I need to do some edit work in Adobe Premiere Pro CC on Mac Yosemite for providing wonderful visual effects and memorable moments for the couples. However, I was failed on the very first step. I even could not import MP4 files into Premiere Pro CC. What’s the problem? Thank you for any tip!"
H.264 is a delivery format that is not designed for editing. Some people experience no problem editing H.264 MP4 clips in Adobe Premiere Pro, while others are not so fortunate. After searching online, I got some tips on this issue. First, if you can play the file back through QuickTime 7. Simply open the file in QT 7 and go "File>>Save As… >>Save" as self-contained movie and it will now work for Premiere! Second, you can also have a try to simply rename the .mp4 extension to .mpg and expect it to work. I had tried two methods above. Although I could link the videos into Premiere finally, the video quality was totally damaged.
Of course, it's not what I want. If you are also looking for a frequent and simple solution to edit Canon G7 X MP4 files in Premiere Pro CC without quality loss, I highly recommend Pavtube HD Video Converter for Mac (Review) , it can convert Premiere unsupported MP4 to Premiere Pro CC supported MP4; Convert Premiere unsupported MP4 to Premiere compatible other video formats like MPEG-2, FLV, DV and more. And it applies to all kinds of Adobe Premiere including Adobe Premiere Pro CC, Adobe Premiere Pro CS3/ CS4/ CS5/ CS6, Adobe After Effects CC/CS6, Premiere Elements, etc.
Besides Premiere output, it also offers other professional codecs for NLEs including Apple ProRes for FCP, DNxHD mov for Avid Media Composer, DaVinci Resolve, AIC mov for iMovie/FCE, and etc. If you are Windows users, please turn to Pavtube HD Video Converter.
Slika Slika (Price: $35)
How to transcode Canon G7 X MP4 to work in Premiere Pro CC on Mac Yosemite?
Step 1: Install and launch Canon MP4 Converter, and then click "Add video" button to load G7 X MP4 files or directly drag the footage to the program.
Step 2: Choose output format. This video converter offers optimized format preset for Adobe Premiere. Just click "Format" menu firstly and then follow "Adobe Premiere/Sony Vegas" to set MPEG-2 (*.mpg) format.
Tips: If the default settings do not fit you requirement, you can click "Settings" icon to and enter "Profile Settings" panel to adjust video size, bit rate, frame rate, sample rate and audio channels.
Step 3: Finally hit the "Convert" button; the best MP4 converter will convert Canon G7 X MP4 files to MPEG-2 .mpg for Adobe Premiere Pro CC immediately.
Conclusion: When the conversion process shows in 100%, you can get the generated videos by clicking "Open" button for easier editing in Premiere Pro CC.
Further Reading:
Edit Sony Z100 4K XAVC in Sony Vegas 13
KMPlayer Cannot Work or Play MP4/H.264 MKV Videos? Fixed!
Windows Movie Maker Won't Import GoPro Hero 4 MP4 Files? Fixed!
How to Play Videos on PS4 via USB?
How to Stream TiVo to NAS for Playback via Xbox?
How to compress MOV file to MP4 on PC or iMac?
Decode H.265/HEVC to MKV, MP4, AVI, MOV, WMV, FLV on Mac Yosemite
Canon XA20 MTS/MP4 workflow in Sony Vegas, Avid, Premiere, Pinnacle, Cyberlink and WMM
Transcode MXF to MP4 with multiple audio tracks for playing and editing
Convert XAVC files to MOV, MKV, AVI, MPG, MP4, WMV, FLV
Convert BlackMagic ProRes to DNxHD MOV for Making Films
Import MP4 footage from Sony XDCAM EX into Final Cut Pro
Convert iMovie Files to MP4 on Mac OS X with Two Solutions
