How to import XAVC S to Premiere Pro CC/CS6/CS5/CS4
Postod lauralily520 » 05.06.2015 11:05
I’ve used Adobe Premiere Pro CS6 for one year to create short film. Now I'm looking for some tips regarding post workflow and getting XAVC S into Adobe Premiere Pro CS6. I got some XAVC S footage from Sony FDR-AX33, when it comes to view, load and edit XAVC S in Premiere Pro CS6, there are a few issues I can’t figured out even updated to Premiere Pro CC.
As some guys recommend online, in order to import XAVC S flies into Premiere Pro for smooth editing, it would be better update Premiere program to the latest version. I’ve tried the trial version of Premiere Pro CC, same result- can’t get XAVC S viewed in timeline. Alternatively, another solution is to get third-party software like Brorsoft Video Converter for Mac to convert XAVC S to Premiere Pro natively supported format like MPEG-2. It will save the issues.
Overall, the program is the best XAVC S converter under Mac OS X(Yosemite, Mavericks included). With it, you can effortlessly transcode XAVC S to MPEG-2 or MOV, which will create a Premiere Pro friendly file format keeping the original quality. Besides Premiere, this software can also export DNxHD for Avid, ProRes for FCP, AIC for iMovie/FCE and more NLE systems for native editing. For Windows users, you can turn to Video Converter. Just get the right version according to your computer's OS and follow the step-by-step guide below to convert XAVC S videos to Adobe Premiere Pro easily.
How to convert XAVC S to MPEG-2 for Premiere Pro CS4/CS5/CS6/CC
Step 1: Load source XAVC S files
Launch the XAVC S Converter on your Mac, and you can either click "Add" button to import xavc s files, or directly drag and drop the files into this program.
Step 2: Select output format
To import XAVC S files to Adobe PP, you can follow Adobe Premiere/Sony Vegas column and select MPEG-2 (*.mpg) as output format.
Tip: If the default settings do not fit you requirement, you can click “Settings” icon to and enter "Profile Settings" panel to adjust video size, bit rate, frame rate, sample rate and audio channels.
Step 3: Start XAVC S conversion
Finally, press the convert button; it will start to transcode XAVC S files to MPEG-2 for Adobe After Effects CS6 as well as CC, CS5, CS4 immediately. When the conversion is finished, you can click "Open" button to get the resulted videos.
Additional Tips:
This powerful XAVC S to Adobe Premiere Converter not only can help you convert XAVC S to Premiere, but also enables anyone with XAVC or XAVC S files to use in any non-linear editor like After Effects, Final Cut Pro, iMovie, FCE, Avid Media Composer, etc as long as transcode XAVC S to a recognizable format.
More Topics:
Easy way to copy DVD, Blu-ray movies to PS3
How to Backup DVD/Blu-ray to USB Flash Drive
Retrieve deleted message on iPhone 6/iPhone 6 Plus
Enjoy DVD, Blu-ray movies in H.265/HEVC format
Accidentally deleted contact on iPhone 6/iPhone 6 Plus
4k video clips from Panasonic DMC-G7 to FCP Workflow
Transfer DivX Plus HD (MKV) files to your Sony PS3, PS4
Converting Video_TS files to AIC .mov for iMovie and FCE
Watch/View Blu-ray/DVD movies onto Windows 8.1 Tablets
Add and Play AVI/VOB/MKV on Nexus 9 with friendly format
Editing Panasonic DMC-G7 4K video in FCP/Premiere/Avid MC
Edit Panasonic DMC-G7 4k video to Premiere Pro CC 7/CS6/CS5/CS4
Get Avid MC (5.5/6.0/6.5/7) Work with Panasonic DMC-G7 4K MP4, 1080p AVCHD
Source: Editing XAVC S in Adobe Premiere Pro CS6/CC
Re: How to import XAVC S to Premiere Pro CC/CS6/CS5/CS4
Postod Andyeric » 24.06.2015 11:02
H.265 Converter- Encode/Decode H.265 to MKV, MP4, AVI, MOV, WMV, FLV on Mac Yosemite
Summary: As the newest codec and with features of smaller size and higher quality, H.265/HEVC has become more and more popular in our video codec area. What brought to us was the related questions. What's the true meaning of H.265/HEVC? How could we convert, edit or play H.265/HEVC videos? Is there any best methods provided for us to handle the H.265 encode and decode workflow well?
Q1: What is H.265/HEVC?
High Efficiency Video Coding (HEVC) is the latest generation video compression standard developed by the ISO/IEC Moving Picture Experts Group and ITU-T Video Coding Experts Group, through their Joint Collaborative Team on Video Coding. HEVC is also known as ISO/IEC 23008-2 MPEG-H Part 2 and ITU-T H.265. HEVC provides superior video quality and up to twice the data compression as the previous standard (H.264/MPEG-4 AVC). HEVC can support 8K Ultra High Definition video, with a picture size up to 8192×4320 pixels.
Q2: What's the difference between H.265 and the previous standard H.264?
H.264 has been a huge success. It's a flexible codec standard that's used by streaming services, satellite providers, and for Blu-ray discs. It's scaled remarkably well since it was first proposed and is capable of handling 3D, 48-60 fps encodes, and even 4K. The Blu-ray disc standard doesn't currently include provisions for some of these technologies, but the H.264 codec itself is capable of handling them.
However, while it can handle these types of encodes, it can't do so while simultaneously keeping file sizes low. A new standard is necessary to push file/stream sizes back down while driving next-generation adoption, and that's where H.265 comes in. It's designed to utilize substantially less bandwidth thanks to advanced encoding techniques and a more sophisticated encode/decode model.
Q3: How to encode/decode H.265/HEVC to MKV, MP4, AVI, MOV, WMV, FLV on Mac Yosemite?
After testing countless freeware and commercial software, considering the ease of use and lossless quality, we would recommend Pavtube Video Converter for Mac to you which is an all-in-one H.265 Converter. As upgraded to the latest version 4.8.5.0, this Mac Video Converter can definitely support H.265 encoder/decoder very well. Moreover, it can encode/decode H.265 to MKV, MP4, AVI, MOV, WMV, FLV on Mac Yosemite with fast speed, easy operation and quality maintained.
Specific guide on how to encode/decode H.265 to MKV, MP4, AVI, MOV, WMV, FLV on Mac Yosemite:
Step 1: Run the upgraded Mac Video Converter, and click the "Add video" button to load your original H.265 recordings. If you want to load several files at one time, "Add from folder" button is available. Besides, you can also drag and drop the files to the main interface directly.
Step 2: When you launch the program and load your H.265 files in , then we can choose the suitable output formats. To convert H.265 to MKV, you can choose "HD Video>>MKV HD Video (*.mkv)". To convert H.265 to MP4, you can choose "HD Video>>H.264 HD Video (*.mp4)". To convert H.265 to AVI, you can choose "HD Video>>AVI HD Video (*.avi)". To convert H.265 to MOV, you can choose "HD Video>>H.264 HD Video (*.mov)". To convert H.265 to WMV, you can choose "HD Video>>WMV HD (*.wmv)". To convert H.265 to FLV, you can choose "Flash Video>>FLV H.264 (*.flv)".
Step 4: When everything is ready, you can take a preview by hitting "Play" button. If you are satisfied with the final result, you can click "Convert" button to finish the conversion work.
Conclusion: When the conversion is done, you can click "Open" to get your generated files. Now, you can use them for editing, playing, uploading, sharing and all you want. Good news for everyone! All of us can get 40% discount off before May, 1st, 2015. Come on! Why not seize the chance and take a close look at the event?
Further Reading:
[list=none][*]How to Upload H.265/HEVC Videos to YouTube or Vimeo?: Many users who use some latest H.265 cameras like Samsung NX 1 would complain that "My attempts at uploading H.265 videos to YouTube fail during processing."[*]Top 5 Best H.265 (HEVC) Codec Decoding and Encoding Tools: While it has not be accepted by most media players or NLEs yet so today here in this page, we would like to introduce you some best H.265/HEVC encoder and decoder to help us to work well with this new H.265/HEVC.[*]Top 5 Best Video Converter for Mac Reviewed 2015: When you are doing to watch some videos on Mac, have you met the trouble of ‘Error message' appeared on the screen?[/list]
2015 Mother's Day is coming! What would you like to send to your mother to make this year's festival unforgettable? A bundle of flowers or a bottle of her favorite perfume as usual? What do you think of the idea of buying a tech-type gift of this year's Mother's Day? To record some precious moments we stay with mother, Pavtube Studio here offers us a big promotion! All video converters we can enjoy a coupon during the celebration!
Promotion Plan A:
On Mother's Day, May 10th, all users can enjoy 40% off discount for all video products in Pavtube Studio! Just write down 'What do you want to say to your mother' under the promotion page is okay!
Promotion Plan B (For all Facebok users):
During May 7th to May 14th, if Facebook users 'Follow' our Pavtube official account and 'Like', all of us can enjoy a big 50% off discountof the strongest tool---Pavtube HD Video Converter for Windows / Mac! With all video conversion works well, this program has a good reputation online.
Source: http://bestvideoking.blogspot.com/2015/ ... n-mac.html
