Open Sony HDR-PJ670 AVCHD MTS Clips in FCP 6/7
Postod Andyeric » 05.06.2015 8:26
Import Sony PJ670 AVCHD .mts to Final Cut Pro 7/6
Summary: While trying to import and transfer Sony HDR-PJ670 AVCHD videos into FCP, get an error message? This article will teach you how to edit Sony HDR-PJ670 MTS footage in FCP 6/7 without any issue.
Source: Open Sony HDR-PJ670 AVCHD MTS Clips in FCP 6/7
The Sony HDR-PJ670 HD Handycam with Built-In Projector and 32GB Internal Memory records XAVC S codec at up to 50 Mb/s recording at 24, 25, 30, 50, and 60 fps. It also features dual recording, which lets you simultaneously capture both high-quality AVCHD and web-optimized MP4 files. Many users may choose AVCHD as recording format for easily editing and playing. However, they still meet problems while transferring Sony HDR-PJ670 AVCHD clips to FCP.
"I chose AVCHD as recording formats of Sony HDR-PJ670 and thought that kind of format should be more compatible than XAVC S. However, the fact is that FCP refused all of clips. Is FCP 6/7 compatible with MTS videos on earth?"
It's a pity that currently 1080/60p AVCHD footage from Sony HDR-PJ670 is a very non-standard format that cannot be accepted by Final Cut Pro 6/7 or FCP X. If you are the Sony HDR-PJ670 user and want to get AVCHD into FCP X/7/6 without issue, you need to change Sony HDR-PJ670 AVCHD to Apple ProRes, the most friendly codec for FCP.
Here we recommend you the best AVCHD to ProRes Converter- Pavtube MTS/M2TS Converter for Mac. Its great performance and all the FCP compatible formats included (Apple ProRes 422, Apple ProRes 422 HQ, Apple ProRes 422 LT, Apple ProRes 422 Proxy, Apple ProRes 4444) make it easier for you to import and edit Sony HDR-PJ670 AVCHD clips in FCP 6/7. Besides FCP, it offers other optimized outputs including Premiere, iMovie, FCE, Avid Media Composer and etc. Now, download the software on Mac and follow the guide below to start conversion.
Amazon Download: http://www.amazon.com/Pavtube-MTS-M2TS-Converter-Download/dp/B00QIE3U0Y
Cnet Download: http://download.cnet.com/Pavtube-MTS-M2TS-Converter/3000-2194_4-76177029.html
Open Sony HDR-PJ670 AVCHD MTS clips in FCP 6/7.
Step 1: Click the "Add Video" button or "Add from folder" icon on the main interface to import Sony HDR-PJ670 MTS files after downloading and installing this Mac MTS/M2TS Converter. Drag and drop files are also available. When the files are loaded to the program, you can view them from the Preview window. Simply select an item and click the "Play" button. When the video is playing, you may take snapshoot when it plays to your favorable frame by clicking the "Snapshoot" button.
Step 2: Click format column and choose best video format for FCP 6/7. Just click and choose "Final Cut Pro>>Apple ProRes 422 (*.mov)" as output format for this profile and it is native format for FCP. If you have the requirement to edit videos in other programs, you can choose according to your need.
Tips: Apple ProRes 422 (*.mov) and Apple ProRes 422 (HQ) (*.mov) have higher qualities. Apple ProRes 422 (LT) (*.mov) and Apple ProRes 422 (Proxy) (*.mov) have smaller size. You can choose according to your requirement.
Step 3: To set the profile settings, please click the "Settings" button. General speaking, the default settings are just fine. Click the "Browse" button to browse and specify a destination folder to save the converted files.
Step 4: When everything is ready, click "Convert" to start converting MTS to ProRes 422. This Mac MTS/M2TS Converter supports batch conversion so you may load multiple files and convert them at one time.
Conclusion: As MTS to Apple ProRes 422 Mac video converter, it enables you to trim out unwanted part, crop out black bars, change aspect ratio from 4:3 to 16:9 and vice versa, rotate 90 degrees clockwise, anti-clockwise, add plug-in subtitles, apply special effect, and more. If you want to merge several clips into a whole one, "Merge into one file" can help you to realize it. Try it for free now!
Further Reading:
Upload AVCHD MTS/M2TS Videos to Youtube/Vimeo on Mac
Fix Apple TV 3 Error While Opening MP4 File?
How to Play Windows Media Player (WMV) Files on Your Mac OS X?
Need Tips on Importing MTS to Corel VideoStudio Pro X7?
Import MTS Clips from Canon C100 to Final Cut Pro on Mac
Compress MTS to MP4 with Handbrake/Free MTS/M2TS Converter
Import AVCHD MTS Files to FCP, Premiere Pro on Mac
How to Get AVCHD MTS Workflow with DaVinci Resolve (Lite)
Import AVCHD MTS/M2TS to Windows Movie Maker for editing
Play MTS on Smart TV (Windows and Mac Solutions)
Convert Sony Handycam MTS to Quicktime MOV for Playback
