Import Panasonic HC-VX870 4K to Premiere Pro CC
Postod Andyeric » 03.06.2015 9:37
Edit HC-VX870 AVCHD/MP4 to Premiere Pro CC on Mac
If you are Panasonic HC-VX870 users, you may have this question: "Can I import Panasonic HC-VX870 AVCHD MP4 files to Premiere Pro CC on Mac OS X Yosemite or Windows 8.1/8? I want to edit Panasonic VX870 files via Premiere Pro CC, but the program isn't smoothly."
If you are shooting with a Panasonic VX870 camera, you will find it is able to record 1080p AVCHD and MP4 footage, which Premiere Pro CC cannot recognize as import. To be able to import Panasonic VX870 AVCHD MP4 to Premiere Pro CC for editing, format conversion is inevitable. This post displays the best way to convert VX870 AVCHD MP4 footage to Premiere Pro CC editable files in detail.
Adobe Premiere Pro is a timeline-based video editing software application. It is part of the Adobe Creative Suite, a suite of graphic design, video editing and web development programs. This editing software supports a wide variety of video and audio file formats. H.264 MOV and MPEG-2 MPG video are the best video formats for Premiere.
While Panasonic VX870 users still have troubles when importing those 1080P recordings with AVCHD MP4 file extension to the latest Premiere Pro CC for editing. What to do if you need import VX870 AVCHD MP4 files to Premiere Pro CC? For loading and editing VX870 AVCHD MP4 in Premiere Pro CC (CS6/5.5/5/4) without any problem, here we recommend using Pavtube HD Video Converter for Mac to convert VX870 AVCHD MP4 files to Premiere Pro CC supported video format, such as converting VX870 AVCHD MP4 to MPEG-2 .mpg.
Tips: Pavtube HD Video Converter is provided for Windows version.
How to edit Panasonic VX870 AVCHD MP4 files in Premiere Pro CC?
Step 1: Install and launch VX870 AVCHD Converter, and then click "Add video" button to load VX870 AVCHD MP4 files or directly drag the footage to the program.
Step 2: Choose output format. This video converter offers optimized format preset for Adobe Premiere. Just click "Format" menu firstly and then follow "Adobe Premiere/Sony Vegas" to set MPEG-2 (*.mpg) format.
Step 3: If the default settings do not fit you requirement, you can click "Settings" icon to and enter "Profile Settings" panel to adjust video size, bit rate, frame rate, sample rate and audio channels.
Step 4: Finally hit the "Convert" button; the best AVCHD MP4 converter will convert Panasonic VX870 AVCHD MP4 files to MPEG-2 .mpg for Adobe Premiere Pro CC immediately.
Conclusion: When the conversion process shows in 100%, you can get the generated videos from output folder easily for easier editing in Premier Pro CC.
Further Reading:
Edit GoPro Hero4 4K Videos in FCP
Edit Alpha 77 Mark II AVCHD in Premiere Pro
Import DJI Phantom 2 Vision+ Video to FCP 7 for Editing
Import Pentax K-3 II Videos to FCP X for Natively Editing
Rewrap MKV to ProRes 422/4444/LT/Proxy for FCP
Convert MXF to MPEG-1/MPEG-2/MPEG-4 on Mac/PC
Convert 3D M2TS to SBS/Red-cyan MP4 for Sharing
Import H.265/HEVC Files to MX Player for Watching
Edit Alpha 77 Mark II AVCHD MTS in Avid MC on Yosemite
Workflow of PXW-X70 XAVC MXF to AE CC on Mac OS X
Source: http://niceconverter.blogspot.com/2015/06/premiere-pro-cc-wont-import-panasonic.html
