VRO and FCP Workflow - VRO to Apple ProRes for FCP X
Postod Andyeric » 03.06.2015 9:12
VRO and FCP X Workflow - Encode VRO to Apple ProRes for FCP X
Sumary: Maybe you have a Panasonic or Sony camcorder or Samsung DVD recorder and record some videos. If you want to edit them in Final Cut Pro X on Mac, there must be some issues because VRO files aren't supported by FCP X.
Source: http://camcordervideoshare.altervista.org/blog/edit-vro-from-canon-dc100-in-final-cut-pro-67x/
VRO has been a very hot video format all the time since it was created by DVD video recorders. Its full name is Variable Ratio Oiler and is a special format used for DVD recording to shoot video and audio data onto the DVD in real time. It features in supporting very high quality videos. There are countless camcorders in the market supporting VRO shooting, for example, Canon DC100. The problem is how we should do to free convert Canon DC100 VRO to ProRes 422 for Final Cut Pro 6/7/X.
Apple ProRes 422 is a standard-definition and high-definition lossy video compression format developed by Apple Inc. for use in post production. It was introduced in 2007 with Final Cut Studio 2 and is comparable to Avid's DNxHD codec which has the same purpose and uses similar bit rates. Both are DCT basedintra-frame-only codecs, and are therefore simpler to decode than distribution oriented formats like H.264. FCP 6/7, FCP X is Mac based editing software which supports transcoding VRO videos to Apple ProRes for further editing.
Tips: FCP supported video formats
So the program you need is a great Pavtube Video Converter for Mac which will convert VRO to Apple ProRes 422/4444 for editing with Final Cut Pro X/7/6 on Mac with best video and audio quality, perfect video and audio synchronization, and nearly all the video formats are supported, including MKV, MVI, VOB, F4V, SWF, AVI, WMV, MOV, M4V, FLV, AVCHD, MTS, M2TS, MXF, Canon camcorder recordings, Sony/Panasonic recordings, etc.
Some specific steps of converting and editing VRO recordings with FCP X are allowed here:
Step 1: After downloading and installing, launch the project. Open the main interface and choose the "Add video" to load your VRO files in. For the multiple video clips we can hit the "Add from folder" button.
Step 2: Click the "Format" bar to get the drop-down menu and you can get "Final Cut Pro>>Apple ProRes codec", including ProRes 422, ProRes 422 (HQ), ProRes 422 (LT), ProRes 422 (Proxy) and ProRes 4444. Choose the proper one you want. Here, we suggest you to choose Apple ProRes 422 .mov as the best output format.
Step 3: Most of you guys must have the desire of a further editing with your output videos, right? On the main interface, "Edit" is waiting for you. "Trim" to decide where to start and where to end, "Crop" to cut some unwanted clips, "Subtitles" to add some explanations to your audience.
Step 4: Before converting, you can watch the video in the preview window. If you are satisfied with the result, it's not too late to hit the "Convert" button.
Conclusion: After converting, you can get the generated files by clicking "Open" button. Now, you can edit VRO files in FCP X flawlessly. It's easy and it's indeed of great convenience, right?
Further Reading:
Import OBS FLV Videos to FCP 7/6 on Mac OS X
MXF to FCP X not working on Mac Yosemite? A possible fix!
Import Pentax K-3 II Videos to FCP X for Natively Editing
Convert Ikegami HDS-V10 MXF to ProRes for FCP Editing
Upload Final Cut Pro projects to YouTube or Vimeo
Edit Samsung NX1 H.265/HEVC Video on FCP X on Mac
Samsung NX500 H.265 to FCP X Workflow on Mac Yosemite
PowerShot G3 X Video Clips to FCP X/7 Import Issues
Working AX30 4K XAVC S Files with FCP 7/X
Edit Samsung NX1 H.265 Files in FCP 7 on Mac Yosemite
Good News! Pavtube Bundles Dealsare coming! If you want to import/preserve/mix multi-track MXF in MKV/MP4/MOV formats, get multi-track Apple Prores MOV for further editing in Final Cut Pro (X), the following bundled software is your best choice:
