Workflow to Import Nikon D7200 MOV to Premiere Pro CC
Postod Andyeric » 03.06.2015 8:50
Resolve Nikon D7200 H.264 to Premiere Pro CC Importing issues
Summary: This guide will talk about the Nikon D7200 H.264 MOV to Premiere Pro CC incompatibility issues. If you are facing the issues importing MOV to Premiere Pro CC, just get the easy solution here.
Hot search: H.265 to Premiere Pro CC | MTS to Premiere Pro CC|XAVC to Premiere Pro CC|MP4 to Premiere Pro CC | MKV to Premiere Pro CC | MXF to Premiere Pro CC
The Nikon D7200 is new to the Nikon's DSLR and it surpassed all my expectations. It can record footage with H.264 codec and save the files in MOV container format. However, I usually saw the Nikon DSLR users encounter importing issues when attempting to edit Nikon D7200 H.264 MOV in Premiere Pro CC like import it slowly, and couldn't edit videos smoothly. So, here comes the question: can we import Nikon D7200 H.264 MOV to Premiere Pro CC directly without any hassle?
H.264 MOV delivers stunning picture quality, but it not an ideal editing format for Premiere Pro CC. So you'll get crashed or other issues. Based on other users' feedback, I've got to know that it's hard to import Nikon D7200 H.264 MOV to Premiere Pro CC flawlessly. That's because Nikon footage is highly compressed with H.264 codec, which is unacceptable by various non-linear editing systems (NLEs) like Premiere Pro CC. To edit Nikon D7200 H.264 MOV in Premiere Pro CC smoothly, the best solution is to convert MOV to Premiere Pro CC best accepted format MPEG-2, which ensures maximum editing quality and efficiency.
The quick solution for the problem likewise is to use Pavtube Pavtube HD Video Converter for Mac. With this top Mac Nikon MOV to Premiere Pro CC Converter, you can import MOV to PPro CC correctly and saving the rendering time. (2015 Top 5 Best Mac HD Video Converter Review for Camcorder Lovers)
How to edit Panasonic VX870 AVCHD MP4 files in Premiere Pro CC?
Here are the steps for you to import Nikon D7200 H.264 MOV to Premiere Pro CC:
Step 1: Install and launch the HD MOV to Premiere Pro CC Video Converter on your Mac, and then click "Add video" button to browse to H.264 MOV footage or directly drag the footage from your D7200 to the program. Thanks to "Add from folder", you can load several H.264 MOV files at once.
Step 2: Click the "Format" bar to select output format. Choose "Adobe Premiere/Sony Vegas>>MPEG-2 (*.mpg)" for editing raw H.264 MOV in Premiere Pro CC with natively supported video codec.
Step 3: Tap "Settings" to choose or customize the output parameters, adjust the resolution, bit rate as you want. Usually the higher bit rate you choose, the better video quality will be. And you can click the pencil-like icon on the top to open Video Editor—it will help you to trim, crop, add subtitles or edit audio of the source file before conversion.
Step 4: Back to the main interface and click "Convert" on the bottom right corner, it will pop up a conversion progress window with all the tasks. Click "Options" button and there is a "Convert" item in it, running processes can be changed. You are allowed to convert up to 4 files simultaneously here and the rest will be queued up. After the conversion, click "Open output folder" to quick locate the converted video.
Conclusion: Now you are able to import generated Nikon D7200 H.264 MOV to Premiere Pro CC without any hassles. Launch Premiere on your Mac, refer to the transfer of importing H.264 MOV to Premiere Pro CC and enjoy on the go!
Further Reading:
Move Final Cut Pro X Videos to Premiere Pro CC
Ingest Samsung NX1 H.265 Videos to Sony Vegas Pro 13/12/11
Issues: Samsung NX1 H.265 Videos to After Effects CC
Transcode Canon 5D Mark III MOV to iMovie AIC for Editing
Import Nikon H.264 MOV to iMovie for Editing and Playing
Import MP4/H.264 to After Effects CC/CS6/CS5 without Rewrapping
Import Canon C300 MXF to Sony Vegas, Pinnacle Studio, Adobe After Effects
Workflow on MPEG-4/H.264 Footage to Final Cut Pro X
Convert MXF to MPEG-1/MPEG-2/MPEG-4 on Mac/PC
Source: http://niceconverter.blogspot.com/2015/06/workflow-to-import-nikon-d7200-h264-mov.html
