How to edit DVD Video_TS in iMovie on Mac OS X
Postod lauralily520 » 01.06.2015 10:56
Video_TS files are used to store the disc files, including video objects files, disc information files, etc. It's not that difficult to play these Video_TS files. But if you want to import Video_TS to iMovie for editing, you will need to convert Video_TS to a standard video file like MOV for iMovie. In this article, you will lenar how to convert Video_TS to iMovie compatible MOV files.
To encode DVD Video_TS to iMovie, you need the assistant of a Video_TS to MOV converter. Here we strongly recommend Brorsoft DVD Ripper for Mac to you. With it, you can quickly and easily change Video_TS to MOV for editing in iMovie with least quality loss. Besides Video_TS folder, it also allows you to convert ISO image file, DVD to iMovie on Mac OS X(Yosemite, Mavericks). And you can customize your video files with the built-in free video editor. Now download the software and follow the guide below to get MOV video files from Video_TS folders for using in iMovie with ease.
How to convert Video_TS folder to iMovie on Mac
1. Add Video_TS folder
Run the program and click "Load DVD" to select and load the Video_TS folder to the program. As you can see, added files will be displayed on the left source pane and can be previewed on the right preview window.
2. Select output format
Click format bar to choose the format for output. For editing Video_TS files in iMovie on Mac, you can choose iMovie and Final Cut Express -> Apple InterMediate Codec (AIC)(*.mov), it's best for iMovie editing. If necessary, you can click "Settings" to adjust video encoders, bit rate, frame rate, etc.
3. Start converting Video_TS to iMovie
When all the settings are OK, tap Convert button to start the Video_TS to AIC .mov conversion. After the conversion, you can click "Open " to get the converted MOV videos. Launch iMovie, choose File > Import > Movies…, to import the converted Video_TS into iMovie.
Related posts:
How to copy DVD files to USB Flash Drive
Top One Best Blu-ray Ripping Program Review
Convert VOB to H.264 MP4 for Galaxy Note 3
Edit TS with iMovie 11/10/09 in AIC MOV format
Bringing OBS FLV into Sony Vegas Pro 13/12/11
Transfer MKV videos to PS3 for entertainment
How to move DVD movies to Windows 8.1 tablets
Playing Blu-ray, DVD movies on Sony Xperia Z1/Z2/Z3
Edit Sony PJ260VE 1080p AVCHD in iMovie 11/09/08 on Mac
Sony PXW-X200 XAVC Workflow with Avid Media Composer
How to Import ALEXA Mini 4K to Premiere Pro CC/CS6/CS5/CS4
Transcoding 4K MP4 files from Panasonic HC-VX870 to Premiere Pro
Converting Nikon/Canon Digital SLRs H.264 recordings to FCP on Mac
Source: How can I load Video_TS files into iMovie
