Encode Sony WX500 XAVC S to MPEG-2 for Premiere Pro CC/CS
Postod Andyeric » 01.06.2015 4:33
Overview:
"As far as I know the latest XAVC S high-speed format introduced by Sony WX500 is still not supported well by Premiere Pro CC so far. If you want import XAVC S into Premiere Pro CC? This article will show you the XAVC S to Premiere Pro CC workflow on Mac."
Why our users love Sony WX500 camera so much?
Like the HX90, the WX500 is designed to meet the requirements of novice photographers and offers a collection of automatic shooting options, but there are also exposure modes to suit more experienced photographers: shutter priority, aperture priority and manual. Videos, however, can be shot in Full-HD at 8 bit and 4:2:0 at up to 50Mbps in AVCHD, MP4 or the new XAVC S format at 50/60p.
Causes of XAVC S files cannot be suitable for Premiere Pro CC/CS?
Granted, Premiere Pro CC/CS can handle (usually) 4K XAVC S files without much problem, but it is extremely hardware intensive. Thankfully you probably don't have to buy a new computer, but you do need to convert XAVC S to Adobe Premiere Pro using MPEG-2 (1080p) as primary delivery format (Native support formats by Adobe Premiere). As same as the issues appeared in other NLEs like FCP, iMovie, FCE, After Effects, Avid Media Composer, etc., so let's find the solutions below:
Any good professional converting tools can offered to us?
For me, of course, I don't like convert my source videos, because the quality loss (even you can't tell from your eyes), but if you have been driven crazy by this problem, then you may like to have a try. What I've tried is to convert XAVC S to MPEG-2 for Premiere Pro CC/CS with the help of Pavtube Video Converter for Mac. For Windows users, Pavtube Video Converter is the alternative choice. Since Windows and Mac version have upgraded to 4.8.5.1, it can also encode/decode H.265/HEVC videos on the latest Windows 10 and Mac Yosemite 10.10 so nicely.
How to convert WX500 XAVC S to MPEG-2 for Premiere Pro CC/CS editing?
Step 1: Launch the corresponding version as the best XAVC S to Premiere Pro Converter, and click the "Add video" or "Add from folder" button to load your source files from your backup folder.
Step 2: To import WX500 XAVC S files to Adobe Premiere Pro, you can hit the "Format" bar and follow "Adobe Premiere/Sony Vegas" column and select "MPEG-2 (*.mpg)" as output format.
Step 3: If the default settings do not fit your needs, you can click "Settings" button to adjust audio and video parameters as you like.
Step 4: Finally, click "Convert" button and your XAVC S files from Sony WX500 will be converted to MPEG-2 files and later are ready to be imported to Premiere Pro CC/CS for editing.
Conclusion: When everything is done, you can click "Open" button to get the generated files. Now, you can enjoy editing WX500 XAVC S files in Premiere Pro CC/CS flawlessly.
More Adobe Premiere Tips:
Premiere CC + MXF: MXF to Premiere Pro CC import fails on Mac
Edit Samsung NX1 H.265 in Premiere Pro CC on Mac Yosemite
Import M-JPEG .AVI files into Premiere Pro CS6?
No Audio when Editing MTS files in Adobe Premiere Pro CC?
MTS and Premiere Elements workflow
Import FCP 7 Projects to Premiere Pro CC on Mac
Import Sony XAVC MXF to Premiere Pro CC on Mac Yosemite
Import Alpha 77 Mark II AVCHD to Premiere Pro
How to Import TS Files to Premiere Pro CC on Mac?
JVC 4K Videos Workflows with After Effects CC/CS6 on Windows/Mac
Source: http://handycameratips.jimdo.com/2015/05/13/convert-xavc-s-to-mpeg-2-for-premiere/
