MXF to workflow3/Premiere Elements Workflow
Postod Andyeric » 25.05.2015 3:55
Edit XC10 XF-AVC 4K MXF in Aperture 3/Premiere Elements
Have interests in editing Canon XC10 XF-AVC 4K MXF in Aperture 3/Premiere Elements for sharing? That's exactly an awesome idea! But do you know the best video codec of Aperture 3/Premiere Elements for editing? If not, you may get some troubles there.
What's new with this latest Canon 4K camcorder? Why we need to convert the MXF files for editing in Aperture 3/Premiere Elements? Well, Canon XC10 is a very hot camcorder on the market now and a lot of users choose to buy this excellent camcorder. It is a new camcorder with 4K internal video recording, which is aimed at beginners and semi-professionals who would want to upgrade to shooting 4K video without spending the big bucks for it.
Frankly speaking, as the latest Canon 4K camcorder that attracts videographers' attention, this Canon XC10 AVC brings us the higher image quality with the flexible operations. It delivers enhanced workflows across various stages of the production process, from shooting to editing. While as we often mentioned, as the incompatible one, MXF cannot be one of the best supported video formats no matter for Aperture 3 or Premiere Elements. What's more? You may also have encountered incompatible issues when you want to upload MXF files to YouTube for sharing, import MXF to QuickTime for playing, stream MXF to Sony Vegas for editing.
With the unsupported output formats or with some other incompatible operations, it seems not strange that we will meet some related issues when adding XC10 XF-AVC 4K MXF files to Aperture 3/Premiere Elements, right? In this case, for the purpose of converting 4K MXF and considering the ease of use and lossless quality, we highly recommend the Pavtube MXF Converter for Mac to have a try.
Step by step on how to edit XC10 XF-AVC 4K MXF in Aperture 3/Premiere Elements:
Step 1: Download Mac MXF Converter, and follow the prompts to install the program. When the installation is complete, the best XC10 XF-AVC 4K MXF Converter will launch automatically.
Step 2: Click "Add video" button to load Canon XC10 XF-AVC 4K MXF files or directly drag the files into file list. By default, the files are selected. You can delete files which you don't want to import to.
Step 3: Click "Format" bar to determine output format. For best image quality, click the format bar and choose "Final Cut Pro>>Apple ProRes 422 (*.mov)" as output format for editing XC10 XF-AVC 4K MXF in Aperture 3.
Tips: Equally, click the format bar and choose "Adobe Premiere/Sony Vegas>>MPEG-2 (*.mpg)" as output format for editing XC10 XF-AVC 4K MXF in Premiere Elements.
Step 4: Click "Settings" button to customize the output video and audio settings by yourself. But if you are not good at it, you'd better use the default parameters, they will ensure you a good balance between file size and image quality basically. You can change the resolution, bit rate, frame rate as you need.
Step 5: You can preview to check the final result. Once you are satisfied with it, click the "Convert" button to start converting Canon XC10 XF-AVC 4K MXF for editing in Aperture 3/Premiere Elements flawlessly. It will take you a little while.
Conclusion: Once the conversion process is complete, you can click "Open Folder" button to get the generated files for editing XC10 XF-AVC 4K MXF in Aperture 3/Premiere Elements with optimum performance. Let's have a try!
Further Reading:
How to Play MKV, AVI, VOB, FLV, WMV on Google Nexus 6/9?: Google Nexus 6 or Nexus 9 cannot play HD videos such as MKV, AVI, VOB, FLV, and WMV for both of them have limited supported video formats.
Convert Panasonic AJ-HPX2700 P2 MXF to Avid/Premiere/Sony Vegas Pro: If you indeed meet issues of converting and importing Panasonic AJ-HPX2700 P2 MXF files for editing in Avid, Premiere Pro and Sony Vegas Pro, let's together learn some P2 MXF workflow.
No Sound on Playing MKV Files on Gear VR? Solved!: Any issues there when importing MKV files to Gear VR for enjoying at home? No more worries about watching 3D MKV movies on Gear VR if you read this guide carefully.
Windows H.265/HEVC Decoder and Encoder Review
GoPro Video Plays Troubles with Plex—How to Solve?
Upload Sony PMW 300K1 Footage to Youtube/Vimeo/Facebook
