AVCHD to FCP X- Import TZ70 AVCHD to FCP X for Editing
Postod Andyeric » 25.05.2015 3:49
AVCHD to FCP X Conversion, TZ70AVCHD to FCP X Workflow
Panasonic Lumix TZ70 AVCHD can’t be imported to FCP X. Are you seeking to AVCHD to FCP X workflow to convert AVCHD to FCP X? Check the AVCHD to FCP X solutions which are available below right now!
Unveiled at CES 2015, Panasonic Lumix TZ70 is a super zoom camera which you can fit into your coat pocket. The shooting mode is of course AVCHD, which is a file-based format for the digital recording and playback of high-definition video. For many NLEs like FCP X, this AVCHD may not such friendly one. So is there any solution to import TZ70 AVCHD to FCP X for editing?
FCP X works well with AVCHD. It actually converts AVCHD to FCP X friendly format in the background to increase performance. However, you need to make sure you preserve the original file structure. Copy the whole card just as it is, onto your drive. Then from within the FCP X import window, navigate to the folder, and voila, you'll see the video clips and be able to import then as normal. That means in essence you will be duplicating your footage.
This was a pain for most uses. If you do have more time on your hands, you might consider converting TZ70 AVCHD to FCP X supported Apple ProRes directly using a program like Pavtube MTS/M2TS Converter for Mac. With it, you can effortlessly encode AVCHD MTS footage for smoothly importing and editing in various non-linear editing systems including FCP X.
Workflow to import TZ70 AVCHD to FCP X for editing:
Step 1: Connect your Lumix TZ70 camcorder to Mac via USB cable and find the AVCHD files from the camera folder. Then copy and transfer the AVCHD files from TZ70 to the Apple hard drive disk.
Step 2: Import TZ70 AVCHD files to Mac MTS Converter. Run it as the best MTS Converter, and click the "Add video" button to load AVCHD MTS videos. You may also directly drag and drop TZ70 AVCHD MTS videos to application UI for importing files.
Step 3: Click the "Format" option and navigate the mouse cursor to "Final Cut Pro >>Apple ProRes 422 (*.mov)" as output format. Apple ProRes 422 (*.mov) and Apple ProRes 422 (HQ) (*.mov) have higher qualities. Apple ProRes 422 (LT) (*.mov) and Apple ProRes 422 (Proxy) (*.mov) have smaller size. You can choose according to your requirement.
Step 4: To set the profile settings, please click the "Settings" button. General speaking, the default settings are just fine. Click the "Browse" button to browse and specify a destination folder to save the converted files.
Step 5: When everything is ready, click "Convert" to start converting AVCHD MTS to ProRes 422. This Mac MTS/M2TS Converter supports batch conversion so you may load multiple files and convert them at one time.
Conclusion: As AVCHD MTS to Apple ProRes 422 Mac video converter, it enables you to trim out unwanted part, crop out black bars, change aspect ratio from 4:3 to 16:9 and vice versa, rotate 90 degrees clockwise, anti-clockwise, add plug-in subtitles, apply special effect, and more. Now, you can import TZ70 AVCHD to FCP X without any hassles.
Further Reading:
How to Play MKV Files on Samsung Galaxy S6/S6 Edge?: How to watch MKV files on Samsung S5/S6 Edge will be a big problem for new users who just can't wait to have this wonder handset for a try.
How to Edit Fraps recorded files with FCP, Premiere, Avid on Mac?: Scratching your head to find a doable program to make Fraps footage compatible with FCP, Premiere, Avid and other NLEs for smooth editing?
Play AVCHD Videos with VLC and QuickTime on Yosemite: There are exactly some top issues appeared when you wanna import AVCHD videos to VLC media player and QuickTime on Yosemite for a playback.
From Blackmagic 4K to ProRes and DNxHD? Blackmagic Video Converter
Ingest H.265 Films to WDTV Live on Windows PC
