Sony PMW-RX50 Workflow within Premiere Pro CC/CS6
Postod lauralily520 » 23.05.2015 11:31
Summary: If you want to edit Sony PMW-RX50 XAVC recordings in Adobe Premiere Pro , a wise solution is to convert t Sony RX50 XAVC to MPEG-2 for using in Premiere Pro flawlessly.
As the successor to the PMW-50, Sony PMW-RX50 has a lot of attractive features, including dual SxS memory card slots offering dual simultaneous recordings, 1080 59.94/50P workflow support. Besides MPEG HD 420 35Mbps, MPEG IMX and DVCAM videos, the PMW-RX50 is able to play and record Full HD XAVC Intra and XAVC Long GOP for users. But, can Adobe Premiere Pro ingest XAVC recordings from Sony PMW-RX50? This article will give you some hints: how to import and edit Sony PMW-RX50 XAVC in Adobe Premiere flawlessly.
When transfer the Sony RX50 XAVC recordings to Premiere Pro, the result may let you down- won’t open and import the XAVC footage correctly. What caused the issues? Based on our testing, it may due to the high video resolution and the video codec incompatibility. To edit Sony PMW-RX50 XAVC in Premiere Pro CC/CS6/CS5 smoothly, a workaround is to transcode Sony XAVC to Adobe Premiere Pro more editable format.
With a professional XAVC S converter- Brorsoft Video Converter for Mac, you can get the work done easily. This software is able to convert XAVC files from Sony PMW-RX50 to Adobe Premiere Pro fully compatible format and keep original quality at the mean while. It can also export ProRes for Final Cut Pro, Apple InterMedaite Codec(AIC) for iMovie/FCE, DNxHD for Avid Media Composer and more NLE systems for native editing. Windows users can get Brorsoft Video Converter. Download the software and follow the guide to finish the conversion task.
How to Convert and Import Sony PMW-RX50 XAVC to Premiere Pro
Step 1. Install the XAVC Converter Mac program and run it. Drag the XAVC files to the software. Or you can also click “Add” button on the top of the main interface to import video to the program.
Step 2. Choose output format. This video converter offers optimized format preset for Adobe Premiere. Just click “Format” menu firstly and then follow “Adobe Premiere/Sony Vegas” to set MPG format. MOV(AVC), WMV(VC-1) are also the proper choice.
Tip: If the default settings do not fit you requirement, you can click “Settings” icon to and enter “Profile Settings” panel to adjust video size, bit rate, frame rate, sample rate and audio channels.
Step 3. Finally hit the Convert button; it will convert Sony PMW-RX50 XAVC to MPEG-2 for Adobe Premiere Pro on Mac immediately.
When the conversion process shows in 100% with the top XAVC to MPEG-2 Converter Mac, you can get the resulted videos from output folder easily for easier editing in Premier Pro CS3/CS4/CS5/CS6/CC.
More Guides:
How to convert and import VOB files to iMovie11/10/09
Editing Canon C100 MTS in Premiere Pro CC/CS6
Import Canon Vixia HF G10/G20 AVCHD files to Edit in Avid
Imoprot AVI files to Pinnacle Studio for Editing
Fast Rip Blu-ray ISO files to MP4 in easiest way
Import Sony F3 XDCAM EX MP4 files to Premiere Pro CC/CS6/CS5
Is it possible to edit DJI Inspire 1 4K files in FCP X/7
Convert MKV files to Edit in Avid Media Composer 5/5.5/6/6.5/7
Solve FCP 7/X won't Import MTS files from NEX-FS700R
Edit Sony DSC-WX500 in FCP 7, FCP X(Yosemite)
Import MPG/MPEG File for Final Cut Pro, FCP X Editing
Can't Edit Sony FDR-AXP35 XAVC S Files in Final Cut Pro?
How to Import Sony PDW-HD1550 XAVC to Final Cut Pro 7/X
Edit Sony RX50 with Premiere Pro CS4/CS5/CS6/CC
How to use PMW-RX50 footage in Final Cut Pro 7, FCP X
Transcode Sony DSC-WX500 XAVC-S files to Adobe Premiere Pro CC/CS6
[url=http://jacktellyoutipsformovies.jigsy.com/entries/4k-video-editing-software/tutorial-aims-to-solve-adobe-premiere-cc-cs-won’t-import-xavc-s-files-from-sony-axp35-]Solve Adobe Premiere CC/CS won’t import XAVC S files from Sony AXP35[/url]
Re: Sony PMW-RX50 Workflow within Premiere Pro CC/CS6
Postod Andyeric » 23.06.2015 11:16
More Guides:
