Converting Sony PDW-HD1550 XAVC to Final Cut Pro 7/X
Postod lauralily520 » 22.05.2015 9:55
Q: “When I opened FCP 7 on Mac, the XAVC recording from Sony PDW-HD1550 cannot be recognized. Can Final Cut Pro support XAVC files?”
I've seen this asked in various places however nobody from Apple has addressed the issue. Sony PDW-HD1550, a half-rack-size disc recorder which supports recording MPEG HD422 and XAVC Intra HD format. When users got some XAVC files, most of them would like to import these XAVC recording from Sony PDW-HD1550 into FCP 7/X or other editing programs for further editing. But the problem is, the latest high definition XAVC video format introduced by Sony is not supported well by Final Cut Pro. To import Sony PDW-HD1550 XAVC to Final Cut Pro X or FCP 6/7 for editing smoothly, the easy workaround is to rewrap and convert XAVC to Apple ProRes, which ensures maximum editing quality and efficiency when working with Final Cut Pro. It’s a great way to achieve your goal.
How to Convert Sony PDW-HD1550 XAVC to ProRes MOV for Final Cut Pro X/7
The quick workaround is to use the easy-to-use yet professional app Brorsoft Video Converter for Mac which can be used as an ideal Sony XAVC Converter under OS X Snow Leopard (10.6), Lion (10.7), Mountain Lion (10.8), Mavericks(10.9), Yosemite(10.10). With it, you can effortlessly transcode PDW-HD1550 XAVC to ProRes 422, ProRes 422 HQ, ProRes 422 Proxy, ProRes 4444 for Final Cut Pro 6/7/X losslessly. Below is how.
Note: If you are also a FCP X user, before you try to do the conversion, don’t forget to make sure that you have installed the Apple ProRes Codec manually since the FCP X asks users to install it by themselves.
Step 1: Load XAVC recordings
Run the XAVC to FCP Converter you just set up. Drag and drop the XAVC files to the Converter. You can also hit Add files button to import videos to the app.
Step 2: Select output format
You just need to go to Final Cut Pro column by choosing "Apple ProRes 422 (*.mov)" as best video format for editing Sony XAVC in Final Cut Pro as well as good video quality.
1. You can click "settings" button in the main interface to customize the output video’s parameters, such as resolution, frame rate, etc.
2. By clicking “Edit” button, you can trim, crop the video, or add watermark and adjust effect to the videos which you will convert.
Step 3: Start Converting XAVC to ProRes
Now click "Convert" and let it go. The Mac XAVC Converter supports batch conversion, so if you have lots of XAVC files to convert, check 'Shut down computer after conversion', and you can go away without keeping an eye on it.
When the conversion is done, you can find the output files by clicking "Open" button on the main interface, then you can transfer the Sony PDW-HD1550 XAVC files to Final Cut Pro X or FCP 7 to edit with ease.
Additional Tips:
This XAVC to ProRes Converter can also help you to transcode Sony XAVC, XAVC S to Adobe Premiere Pro, iMovie, FCE, Avid Media Composer with the optimal presets MPEG-2, Apple InterMediate Codec, DNxHD. Just select a proper format in the 2nd step.
See also:
How to Import XAVC Files to Adobe Premiere Pro
How to import Sony PXW-FS7 XAVC files to iMovie
How to work Sony PMW-RX50 XAVC in FCP 7/FCP X
Solve FCP 7/X won't Import MTS files from NEX-FS700R
How to Import Sony PXW-X500 XAVC to Adobe Premiere Pro
How to work Sony PMW-RX50 XAVC in Premiere Pro CC/CS6
Convert MKV files to Edit in Avid Media Composer 5/5.5/6/6.5/7
Import MPEG HD422 50 Mbps recording on Sony PMW-200 to Avid MC
Import Panasonic DMC-ZS30/TZ40 to Mac FCP/iMovie/FCE editing on Mac
Canon EOS C300 MXF Video Converter for Final Cut Pro on Mac (Yosemite)
Source: Importing Sony PDW-HD1550 XAVC to FCP 7/X
Re: Converting Sony PDW-HD1550 XAVC to Final Cut Pro 7/X
Postod Andyeric » 23.06.2015 11:11
More Guides:
