Import 4k XAVC to Sony Vegas with Original Quality
Postod Andyeric » 21.05.2015 11:21
Edit FDR-AXP33 4K XAVC in Sony Vegas Pro 13 with Original Quality
I was troubled by the issue- Sony Vegas Pro 13 not seeing 4K XAVC codec. Do you have such experience likewise? If you have got some 4K XAVC files from Sony FDR-AX33, you would probably come across the problem. Let’s look at the XAVC to Sony Vegas Pro 13 importing issues in detail.
"I placed an order on the website for Sony FDR-AX33. I learnt that this camcorder could record videos at 4K with XAVC codec. Although I have not received my camcorder, I am wondering does Sony Vegas Pro 13 support 4K XAVC videos."
"Is there anyone having an issue getting Sony Vegas Pro 13 to accept the 4K XAVC clips from Sony FDR-AX33? Why do the Sony camera divisions and SCS not work together to ensure that their own NLE can accept their own camera footage when a camera is released. It's crazy."
Although Sony states that the Vegas 13/12 supports native XAVC editing, we find it's not easy to edit XAVC in Sony Vegas Pro 13/12/11. To ingest 4K XAVC to Sony Vegas Pro 13 perfectly, Pavtube Video Converter is highly recommended to convert 4K XAVC to Sony Vegas Pro 13 native format-MPG. It’s a best 4K XAVC Converter on Windows 8.1/8 and does a good job in converting 4K XAVC files to Sony Vegas Pro 13 most compatible format with least quality loss. Plus, it supports encoding camera shootings in different formats to video editing software compatible file types to meet your different needs.
Tips: For Mac users, you can get the Pavtube Video Converter for Mac.
Encoding FDR-AX33 4K XAVC to Sony Vegas Pro 13:
Step 1: Run the best 4K XAVC to Sony Vegas Pro 13 Converter, and click the "Add video" button to load 4K XAVC videos from Sony FDR-AX33. If you want to load several files at one time, "Add from folder" button is available.
Step 2: Click "Format" bar to determine output format. Follow "Adobe Premiere/Sony Vegas" and select "MPEG-2(*.mpg)" as the output format. Besides, you can also choose WMV (VC-1) (*.wmv) if you want to get a relatively smaller output file.
Step 3: Adjust video and audio parameters, including the bit rate of video and audio, the codec of video and audio, video size, sample rate, frame rate, audio channels, etc., in the Profile Settings by hitting "Settings" button.
Step 4: Click "Convert" button to start encoding Sony FDR-AX33 4K XAVC files to MPG for importing to Sony Vegas Pro 13.
Conclusion: When the conversion task is finished, click "Open" button to get the exported files and then import the converted AX33 footage into Sony Vegas Pro 13 to do further editing without hassle. In addition, money saving bundles and deals is good news for you! Enjoy!
Further Reading:
Top 3 Best XAVC/XAVC S Video Converter for Mac: XAVC is pretty much new while the existing NLE may not handle it very well. Some XAVC/XAVC S video converters can help us get rid of these troubles.
H.265 vs XAVC vs H.264 high profile output: For many person who just touch the electronic world, the thing which makes them very confused is that the difference, the advantages and disadvantages among those codecs.
How to Store and Stream Movies with Plex for Beginners?: Plex organizes all of your personal media so you can enjoy it no matter where you are. Here are several important steps to store and stream videos, music, movies with Plex in your home.
Best Free Online Programs to Convert MOV to MP4
Upload Canon XC10 4K MXF to YouTube/Vimeo/Facebook on Mac
