Import Panasonic HVX2000A MXF Files to Avid MC for Editing
Postod Andyeric » 21.05.2015 11:16
MXF to Avid MC Conversion--MXF Files and Avid MC Workflow
Here is a quick tutorial that aims to simplify the Panasonic HVX2000A MXF files and Avid MC workflow. If you are planning to import MXF to Avid MC or edit MXF in Avid MC, just follow the tutorial about MXF to Avid MC conversion now.
Avid Media Composer is a popular video editing software on windows and Mac, many people use it as a mainly software to edit camcorder or camera recorded videos. But, different cameras record videos in different video formats, such as H.264 MOV, MTS, M2TS, MXF and etc. When importing and editing these videos in Avid Media Composer, users always encounter video and audio problems, as the Avid Media Composer doesn’t support HD videos well due to the codec. The following part will show you the easy way to import Panasonic HVX2000A camcorder recorded MXF files to Avid Media Composer.
If you have a Panasonic HVX2000A camcorder, you may want to edit Panasonic HVX2000A MXF files in Avid Media Composer, though latest Avid MC 7 added many new features, but it can't support HVX2000A MXF footages well, you will encounter importing and editing problems. Look at a typical Panasonic HVX2000A MXF to Avid Media Composer issue:
"I have a Panasonic HVX2000A that records MXF video format, now I would like to import these projects to Avid MC for editing. But it doesn’t work. Can anyone recommend some software which can help me import these MXF files to Avid MC smoothly?"
The similar problems may occur in many Panasonic camcorders like AJ-HPX3000, AG-HPX250, AJ-HPX2000, AJ-HPX3700, AJ-HPM200, AJ-HPX2700 and more. In order to edit your Panasonic MXF footage in Avid MC smoothly, you should convert MXF to Avid MC most compatible format i.e. DNxHD, which is best supported by Avid. Pavtube MXF Converter for Mac is best choice to get the work done. This MXF Converter for Mac is the solid tool to help users make MXF transcoding on Mac. It offers the optimal preset profiles for Avid Media Composer, FCP, Adobe Premiere Pro, iMovie, FCE and more. And there is no need to worry about the quality loss.
Below is the simple guide about how to import Panasonic HVX2000A MXF files to Avid MC for editing.
Step 1: Backup your MXF files from Panasonic HVX2000A to hard drive. Install and launch MXF Video Converter for Mac. Drag and drop MXF files to the software. You can import multiple files at once thanks to "Add from folder" button.
Step 2: Click the drop-down list in the format line to get the format box. Then choose "Avid Media Composer>>Avid DNxHD (*.mov)" as output format.
Step 3: Do some simple edit work.
De-interlace: By default the MXF Video Converter for Mac will apply de-interlacing facility to some clips that are interlaced. Just click "Edit" to enter the video editor, switch to "Effect" tab, and check the "Deinterlacing" box.
Trim: Basically, video hosting sites restrict video clips to be in certain file size and length. For example, YouTube stated that "videos can be up to 2GB in size and 10 minutes long". You can trim the video to desired length with this MXF Video Converter for Mac. Simply click "Edit" menu>>"Trim" tab and set start and end time point.
Merge: To join multiple videos together, just select them in file list, and tick off the checkbox "Merge into one file" on the main interface.
Step 4: You can preview to check the final result. Once you are satisfied with it, click the "Convert" button to start converting Panasonic MXF files to Avid DNxHD MOV for editing in Avid MC flawlessly. It will take you a little while.
Conclusion: Once the conversion process shows in 100%, click "Open" to get the output videos. Now, you can import Panasonic HVX2000A MXF files to Avid MC for editing without issues.
Further Reading:
Convert P2 MXF to Apple ProRes 422 on Mac for Final Cut Pro: These days I've been trying to figure out how to get Final Cut Pro 7 to recognize my MXF recordings, but there is no-go.
How to Add Music, Video files to iTunes Library from Mac?: iTunes is great for managing your music/video/movie library and your iOS device. But it can be a little tricky when trying to add media files to your iTunes library.
Best DSLR Cameras Available to Buy in 2015: Confused in choosing the best suitable DSLR camera as your favorite to record movies to make our life more colorful? You have come to the right place!
Import H.265 to iTunes on Mac OS X
[url=MXF to FCP X not working on Mac Yosemite? A possible fix!]http://mxfworld.jimdo.com/mxf-to-fcp-x/[/url]
http://mxfworld.jimdo.com/mxf-to-premiere/
