iPad Air/iPad Air 2/3 MPG/MPEG Video Playback Tips
Postod lauralily520 » 21.05.2015 10:57
[size="4"]Is there any easy way to convert MPG/MPEG video files to iPad Air, iPad Air 2/3, so that you can enjoy the movies wherever you go?We can tell you the answer is yes. The key to the problem is iPad Air Video Convert for Mac OS X (Yosemite included) and Windows (Windows 8.1 and Windows 10 included). Read the folloing pages, get your problem solved.[/size]
As you know, we can easily enjoy some movies files on iPad Air/iPad Air 2/3 from iTunes. Well, ever tried to add some personal videos from your computer hard drive to iPad Air? It’s a wise choice in fact to get much fun, but the only issue is that some video files like MPG, MPEG can’t be supported by iPad Air directly.
The reason you cannot view MPG or MPEG videos on iPad Air is simple: the default and downloaded player on iPad Air cannot find a suitable decoder for the file. Currently iPad Air only support limited videos in .m4v, .mp4, and .mov file formats. Obviously, neither MPG nor MPEG files (MPEG-1 or MPEG-2) is compatible with the iPad Air. So convert MPG/MPEG to iPad Air is becoming necessary.
If you want to convert and watch your MPG/MPEG videos on iPad Air, you will need the MPG to iPad Air Converter– Brorosft Video Converter can help you do this. The program is very ease to use and produce excellent results for the iPad Air. Conversion speed seems fine and the converted videos look decent on iPad as original. Apart from encoding MPG, MPEG to iPad Air, it also can aid you to batch convert kinds of 720p, 1080p HD videos in various formats like MKV, FLV, AVI, MTS, WMV, TiVo, MXF, VOB, etc. The equivalent Mac version is Mac Video Converter for iPad Air. Just get the right one according to your situation.
How to: Convert and Put MPG/MPEG files to iPad Air with best video quality
1. Load MPG, MPEG files
Run the video converter for iPad Air. Click "Add File" to load one or multiple .mpg file(s) into the program.
2. Set video format for iPad Air
Hit the menu bar of "Format", choose "iPad" category and find the optimal video format for iPad Air. “iPad HD Video(*.mp4)” is recommended here. You can also choose MOV, MP4, M4V format from Common Video.
Tip: If the preset video/audio parameters can’t meet your needs, just click Settings icon to adjust the video bitrate, codec, frame rate, audio sample rate, audio channel, etc.
3. Start the conversion process
Hit the big Convert bar to start the MPG/MPEG conversion for iPad Air. The conversion time mainly depends on your source video file size.
After getting the converted movies files, you can transfer the converted MPG or MPEG files to iPad Air via iTunes. If you don’t know how to put and play video on iPad Air, just follow the steps to realize it:
1) Make sure you have install iTunes. If not, you can free download iTunes. And launch it.
2) Connect iPad Air to Mac/PC.
3) Choose “File – > Add File to Library…”
4) Drag the .mp4 file you want to the iPad Air icon.
So there you have it. Pretty simple. Now you can start watching MPG/MPEG movies on new iPad Air anywhere you want them. Enjoy!
More topics:
Play DVDs on Surface Hub in HD quality
Import 4K MP4/MOV from DJI inspire 1 to AE
Import MTS to Avid MC for Editing MTS in Avid
Get a MPEG Streamclip Alternative under Yosemite
Converting VOB to MP4 for viewing on Android gadget
Convert DVD movies to Asus Transformer Infinity TF700
Editing DJI inspire 4k MP4/MOV files in Final Cut Pro X/7
Rip Blu-ray and DVD movies to Chromebook 2 in H.264 MP4
Easiest Way to Play AVI Video on PlayStation Vita PCH-2000
Editing AVCHD footage in MTS, M2T, M2TS file format in FCP
Edit FLV files in Final Cut Pro 7, FCP X on Mac (Yosemite & Mavericks)
Enable iPad Air to play HD MKV/AVCHD MTS/M2TS/DVD/Blu-ray Movies Directly
Source: View MPG/MPEG movies on iPad Air/iPad Air 2/3
Re: iPad Air/iPad Air 2/3 MPG/MPEG
Postod Andyeric » 21.05.2015 11:09
Edit FDR-AXP33 4K XAVC in Sony Vegas Pro 13 with Original Quality
I was troubled by the issue- Sony Vegas Pro 13 not seeing 4K XAVC codec. Do you have such experience likewise? If you have got some 4K XAVC files from Sony FDR-AX33, you would probably come across the problem. Let’s look at the XAVC to Sony Vegas Pro 13 importing issues in detail.
"I placed an order on the website for Sony FDR-AX33. I learnt that this camcorder could record videos at 4K with XAVC codec. Although I have not received my camcorder, I am wondering does Sony Vegas Pro 13 support 4K XAVC videos."
"Is there anyone having an issue getting Sony Vegas Pro 13 to accept the 4K XAVC clips from Sony FDR-AX33? Why do the Sony camera divisions and SCS not work together to ensure that their own NLE can accept their own camera footage when a camera is released. It's crazy."
Although Sony states that the Vegas 13/12 supports native XAVC editing, we find it's not easy to edit XAVC in Sony Vegas Pro 13/12/11. To ingest 4K XAVC to Sony Vegas Pro 13 perfectly, Pavtube Video Converter is highly recommended to convert 4K XAVC to Sony Vegas Pro 13 native format-MPG. It’s a best 4K XAVC Converter on Windows 8.1/8 and does a good job in converting 4K XAVC files to Sony Vegas Pro 13 most compatible format with least quality loss. Plus, it supports encoding camera shootings in different formats to video editing software compatible file types to meet your different needs.
Tips: For Mac users, you can get the Pavtube Video Converter for Mac.
Encoding FDR-AX33 4K XAVC to Sony Vegas Pro 13:
Step 1: Run the best 4K XAVC to Sony Vegas Pro 13 Converter, and click the "Add video" button to load 4K XAVC videos from Sony FDR-AX33. If you want to load several files at one time, "Add from folder" button is available.
Step 2: Click "Format" bar to determine output format. Follow "Adobe Premiere/Sony Vegas" and select "MPEG-2(*.mpg)" as the output format. Besides, you can also choose WMV (VC-1) (*.wmv) if you want to get a relatively smaller output file.
Step 3: Adjust video and audio parameters, including the bit rate of video and audio, the codec of video and audio, video size, sample rate, frame rate, audio channels, etc., in the Profile Settings by hitting "Settings" button.
Step 4: Click "Convert" button to start encoding Sony FDR-AX33 4K XAVC files to MPG for importing to Sony Vegas Pro 13.
Conclusion: When the conversion task is finished, click "Open" button to get the exported files and then import the converted AX33 footage into Sony Vegas Pro 13 to do further editing without hassle. In addition, money saving bundles and deals is good news for you! Enjoy!
Further Reading:
Top 3 Best XAVC/XAVC S Video Converter for Mac: XAVC is pretty much new while the existing NLE may not handle it very well. Some XAVC/XAVC S video converters can help us get rid of these troubles.
H.265 vs XAVC vs H.264 high profile output: For many person who just touch the electronic world, the thing which makes them very confused is that the difference, the advantages and disadvantages among those codecs.
How to Store and Stream Movies with Plex for Beginners?: Plex organizes all of your personal media so you can enjoy it no matter where you are. Here are several important steps to store and stream videos, music, movies with Plex in your home.
Best Free Online Programs to Convert MOV to MP4
Upload Canon XC10 4K MXF to YouTube/Vimeo/Facebook on Mac
