Tips for working Sony AXP35 4K footage in iMovie
Postod lauralily520 » 18.05.2015 9:40
Sony reinforces its commitment to 4K video with the announcement of a new 4K camcorder FDR-AXP35. The new Handycam FDR-AXP35 supports the efficient XAVC S recording with 4K resolution. Whereas, XAVC S codec is a new one, it is not widely supported. If we want to import and edit the 4K XAVC-S files from Sony FDR-AXP35 into iMovie, the result may let you down- iMovie won’t open Sony AXP35 4K footage correctly.
To get rid of the issues, one possible solution is to transcode Sony FDR-AXP35 4K video to iMovie more “edit” friendly codec. Now I share the guide with you how to convert XAVC S footage to iMovie friendly format using Brorsoft Video Converter for Mac – one of the best XAVC S Converter for Mac(Yosemite, Mavericks incluede).
It does a good job in converting Sony AXP35 XAVC S files to iMovie most compatible format Apple InterMediate Codec .mov with least quality loss. Plus, it supports encoding camera shootings in different formats (H.264 MOV, MTS/M2TS, MP4, MXF, XAVC, XAVC S, etc.) to video editing software compatible file types, i.e. MPEG-2 for Premiere Pro, DNxHD for Avid Media Composer, ProRes for Final Cut Pro to meet your different needs.
Encoding Sony AXP35 XAVC S files to AIC .mov for iMovie
Step 1: Run the best XAVC S to iMovie Converter, and click the “Add” button to load .xvac s videos from Sony FDR-AXP35.
Step 2: Hit the Format box to select the specially designed video codec for editing in iMovie: iMovie/FCE --> Apple InterMediate Codec(AIC) (*.mov).
Step 3. Adjust video and audio parameters, including the Bitrate of Video and Audio, the Codec of Video and Audio, Video Size, Sample Rate, Frame Rate, Audio Channels, etc., in the Profile Settings.
Step 4. Click “Convert” button to start encoding Sony AXP35 XAVC S to AIC .mov for importing to iMovie.
When the conversion task is finished, click “Open” button to get the exported files and then import the converted Sony FDR-AXP35 footage into iMovie to do further editing without hassle.
More Guides:
Import MTS to Avid MC for Editing MTS in Avid
Get a MPEG Streamclip Alternative under Yosemite
Resize DJI Inspire 4K files to 1080p for easily editing
Converting VOB to MP4 for viewing on Android gadget
How to Import Sony A7S XAVC S to Avid MC for Editing
iPhone videos (H.264) not working in Sony Vegas- Solution
Downscale Blackmagic URSA 4K to 1080p for editing in FCP 7
Import Blackmagic Ursa 4K footage to Premiere Pro CC/CS6/CS5
How to Import Sony HDR-AS100V XAVC S to Adobe Premiere Pro
Convert DJI Inspire 4K video files to Adobe Premiere friendly formats
How to import Sony FDR-AX1 XAVC S to Adobe Premiere Pro CC/CS6
Edit FLV files in Final Cut Pro 7, FCP X on Mac (Yosemite & Mavericks)
Source: Sony FDR-AXP35 4K XAVC S to iMovie workflow
Re: Tips for working Sony AXP35 4K footage in iMovie
Postod Andyeric » 22.05.2015 4:13
Edit and Play AS200V XAVC S Videos on Mac Yosemite
It's not strange that you are trapped in editing and playing XAVC S on Mac Yosemite. Especially, if you got a Sony HDR-AS200V camcorder, you may probably on the way to find the best solution to encode and decode XAVC S videos captured by it. Luckily, you can find the useful information in this article.
As the successor of HDR-AS100V, the new model HDR-AS200V enhanced HD video performance with upgraded stabilization and image quality. Scope of movie shooting is expanded through newly added manual settings and Loop Recording. This in-camera feature Highlight Movie Maker added post shooting enjoyment by producing a short highlight movie with background music immediately at the shooting venue. What a fantastic thing that we can edit and play AS200V XAVC S videos on Mac Yosemite!
Sony announced that it had expanded XAVC to the consumer market with the release of XAVC S. XAVC S supports resolutions up to 3840 × 2160, uses MP4 as the container format, and uses either AAC or LPCM for the audio. As example used in Sony HDR-AS200V, it's wonderful to catch beautiful and high definition scenes with this incredible camcorder! When we want to edit and play attractive XAVC S videos shoot by AS200V, how to? How to encode XAVC S videos? What about decoding XAVC S videos?
Having a lot of XAVC S videos at hand, there are various usages for you. For instance, you can edit XAVC S in FCP X/7/6, iMovie/FCE, Premiere, Avid and so on. On the other hand, you can play XAVC S videos on media player like QuickTime on Mac Yosemite, too. No matter for what, first of all, you need to depend on a Mac XAVC S Video Converter so that you can use to work the conversion job well. Pavtube XAVC S Video Converter for Mac, being specially developed to convert AS200V XAVC S videos to common video format for NLEs and players with no quality loss, is highly recommended here.
Steps on how to edit and play AS200V XAVC S videos on Mac Yosemite:
Step 1: Download and install the program from the website or click the free trial icon. Then, launch the best Mac XAVC S Video Converter and load your original XAVC S files in with "Add video" or "Add from folder". Directly drag files in is available.
Step 2: Choose the right output format for editing and playing XAVC S videos on Mac Yosemite. As we mentioned above, taking edit XVAC S in FCP as an example, we would like to introduce you to select the "Final Cut Pro>>Apple ProRes 422 (*.mov)" as your best choice. Apple ProRes 422 (*.mov) and Apple ProRes 422 (HQ) (*.mov) have higher qualities. Apple ProRes 422 (LT) (*.mov) and Apple ProRes 422 (Proxy) (*.mov) have smaller sizes. For other editing software and media player, you can choose the corresponding output format thanks to the preset.
Step 3: The built-in editing function provided by Mac XAVC S Video Converter is something worth trying. To trim the video, add artistic effects, adjust audio, add watermark, customize video parameters and so on. You can get the work done splendidly. Of course, if you don't think it's a necessary to do, you can skip it and move onto the next step directly.
Step 4: Click the "Convert" button on the main interface if you have done all the preparation work and this is the last step to encode and decode XAVC S videos.
Conclusion: OK, everything is ready, and you can instantly edit and play AS200V XAVC S videos on Mac Yosemite. By the way, we have promoted money saving bundles & deals activity. It really saves a lot! Why not take a look and have a try about high quality products with attractive price?
Further Reading:
Mac MXF Workflow - 2015 Top 5 Best MXF Converters for Mac: MXF is a file format for the exchange of programmer material between servers, tape streamers and to digital archives.
How to Add MKV, AVI, Xvid, Divx, FLV, Flac, WAV Files to iTunes on Mac?: Let me start by saying that iTunes is probably not the best media management project. But it is the best integrated on the Mac OS X.
What is Xperia Z3 supported format? Which is Best Video Converter for Xperia Z3: Xperia Z3 is the most refined version of Sony's smart phones yet. A major change in the design is that it is more compact than Xperia Z2.
Import Samsung NX500 to Avid Media Composer on Mac
[url=Best MXF Converter for Mac Review | Convert MXF on Mac Guide]http://mxfworld.jimdo.com/mxf-converter-review/[/url]
