Import DJI Inspire 4K videos to Adobe Premiere
Postod lauralily520 » 18.05.2015 8:20
DJI Inspire camera can shoot up to 4K video with MOV/MP4 format and capture 12 megapixel photos. The lens consists of 9 separate elements, including an aspherical element, for extreme clarity, while Adobe DNG RAW support gives you the power to make every shot a masterpiece. After recording, users may wanna import these outstanding 4K videos into Premiere for editing. While it seems that Premiere can not support DJI Inspire 4K video files well.
"I am doing some inspire 1 4K video editing, I see my desktop is very powerful, however, when I palyback the video in Premiere, it's very choppy, and not easy to do the editting.Does any pros have any idea on 4K in Premiere workflow? Much appreciated!!"
Literally, the latest version Premiere Pro CS6, CC7 has the ability to handle 4K files without much problem, but it is extremely hardware intensive owing to the codec issue and resolution. To solve the problem, you need to convert DJI Inspire 4K videos to MPEG-2 for Premiere Pro as primary delivery format. With the help of Brorsoft Video Converter for Mac, you can easliy achieve the goal.
In general, you can effortlessly encode DJI Inspire 4K MP4/MOV footage for smoothly importing and editing in various non-linear editing systems (NLEs), including Adobe Premiere Pro, Avid Media Composer,Final Cut Pro, iMovie, FCE and more. Besides, DJI Inspire clips, it also can deal with other video formats such as MKV, MTS, MXF, FLV .etc. If you are a PC user and willing to transfer DJI Inspire 4K files to Premiere, Brorsoft Video Converter Windows version is your first choice. Now, download the software on computer and follow the guide below to start conversion.
How to Convert DJI Inspire 4K videos to MPEG-2 for Premiere
Step 1: Click "Add" button on the top of the main interface to load original DJI Inspire 4K videos to the program. Or you can simply drag&drop the videos to the software.
Step 2: Go to "Format" pull down list to select Adobe Premiere/Sony Vegas> MPEG-2(*.mpg) as the best video format for Premiere Pro. WMV, MOV formats in this column are the good choices as well.
Tip: Click the "Settings" button, you are able to enter the "Profile Settings" panel to adjust video and audio parameters for the converted files, including video size, bit rate, frame rate and more.
Step 3: Tap the Convert button to start transcoding DJI Inspire 4K MP4/MOV to MPEG-2 for Adobe Premiere Pro.
Once the process completes, you can find the generated videos via "Open" button. Now, it is easy for you to transfer the encoded 4Kvideos to Premiere for further editing.
Read More:
How to Import 4K video to Final Cut Pro 6/7/X
Import MTS to Avid MC for Editing MTS in Avid
[url=file:///D:/Maxthon2/Plugin/Html2UBB/brorsoft.com/how-to/edit-4k-video-in-adobe-premiere-pro.html]Import and Edit 4K video with Adobe Premiere Pro[/url]
Sony FDR-AXP35 4K XAVC S to iMovie workflow
Get a MPEG Streamclip Alternative under Yosemite
Workflow for Working 4K footage in Sony Vegas Pro
Resize DJI Inspire 4K files to 1080p for easily editing
Play and Edit iPhone videos on Windows Movie Maker
Converting VOB to MP4 for viewing on Android gadget
Editing Nikon 1 V2/D5100/D3100/D800 MOV in Premiere
How to import Tivo videos to iTunes for Easy Playback on iPhone/iPad
Edit FLV files in Final Cut Pro 7, FCP X on Mac (Yosemite & Mavericks)
Source:Convert DJI Inspire 4K video files to Adobe Premiere friendly formats
Re: Import DJI Inspire 4K videos to Adobe Premiere
Postod Andyeric » 22.05.2015 4:16
Edit and Play AS200V XAVC S Videos on Mac Yosemite
It's not strange that you are trapped in editing and playing XAVC S on Mac Yosemite. Especially, if you got a Sony HDR-AS200V camcorder, you may probably on the way to find the best solution to encode and decode XAVC S videos captured by it. Luckily, you can find the useful information in this article.
As the successor of HDR-AS100V, the new model HDR-AS200V enhanced HD video performance with upgraded stabilization and image quality. Scope of movie shooting is expanded through newly added manual settings and Loop Recording. This in-camera feature Highlight Movie Maker added post shooting enjoyment by producing a short highlight movie with background music immediately at the shooting venue. What a fantastic thing that we can edit and play AS200V XAVC S videos on Mac Yosemite!
Sony announced that it had expanded XAVC to the consumer market with the release of XAVC S. XAVC S supports resolutions up to 3840 × 2160, uses MP4 as the container format, and uses either AAC or LPCM for the audio. As example used in Sony HDR-AS200V, it's wonderful to catch beautiful and high definition scenes with this incredible camcorder! When we want to edit and play attractive XAVC S videos shoot by AS200V, how to? How to encode XAVC S videos? What about decoding XAVC S videos?
Having a lot of XAVC S videos at hand, there are various usages for you. For instance, you can edit XAVC S in FCP X/7/6, iMovie/FCE, Premiere, Avid and so on. On the other hand, you can play XAVC S videos on media player like QuickTime on Mac Yosemite, too. No matter for what, first of all, you need to depend on a Mac XAVC S Video Converter so that you can use to work the conversion job well. Pavtube XAVC S Video Converter for Mac, being specially developed to convert AS200V XAVC S videos to common video format for NLEs and players with no quality loss, is highly recommended here.
Steps on how to edit and play AS200V XAVC S videos on Mac Yosemite:
Step 1: Download and install the program from the website or click the free trial icon. Then, launch the best Mac XAVC S Video Converter and load your original XAVC S files in with "Add video" or "Add from folder". Directly drag files in is available.
Step 2: Choose the right output format for editing and playing XAVC S videos on Mac Yosemite. As we mentioned above, taking edit XVAC S in FCP as an example, we would like to introduce you to select the "Final Cut Pro>>Apple ProRes 422 (*.mov)" as your best choice. Apple ProRes 422 (*.mov) and Apple ProRes 422 (HQ) (*.mov) have higher qualities. Apple ProRes 422 (LT) (*.mov) and Apple ProRes 422 (Proxy) (*.mov) have smaller sizes. For other editing software and media player, you can choose the corresponding output format thanks to the preset.
Step 3: The built-in editing function provided by Mac XAVC S Video Converter is something worth trying. To trim the video, add artistic effects, adjust audio, add watermark, customize video parameters and so on. You can get the work done splendidly. Of course, if you don't think it's a necessary to do, you can skip it and move onto the next step directly.
Step 4: Click the "Convert" button on the main interface if you have done all the preparation work and this is the last step to encode and decode XAVC S videos.
Conclusion: OK, everything is ready, and you can instantly edit and play AS200V XAVC S videos on Mac Yosemite. By the way, we have promoted money saving bundles & deals activity. It really saves a lot! Why not take a look and have a try about high quality products with attractive price?
Further Reading:
Mac MXF Workflow - 2015 Top 5 Best MXF Converters for Mac: MXF is a file format for the exchange of programmer material between servers, tape streamers and to digital archives.
How to Add MKV, AVI, Xvid, Divx, FLV, Flac, WAV Files to iTunes on Mac?: Let me start by saying that iTunes is probably not the best media management project. But it is the best integrated on the Mac OS X.
What is Xperia Z3 supported format? Which is Best Video Converter for Xperia Z3: Xperia Z3 is the most refined version of Sony's smart phones yet. A major change in the design is that it is more compact than Xperia Z2.
Import Samsung NX500 to Avid Media Composer on Mac
[url=Best MXF Converter for Mac Review | Convert MXF on Mac Guide]http://mxfworld.jimdo.com/mxf-converter-review/[/url]
