Convert Sony 3D MTS to SBS 3D MP4/MKV Playback
Postod lauralily520 » 14.05.2015 10:52
If you have got a 3D camcorder and recorded lots of 3D AVCHD MTS files, how about watching the recorded 3D videos on 3D TV?
“I am looking for a workable Sony 3D MTS Converter for the purpose of ripping Sony 3D AVCHD files to side-by-side 3D MP4 or MKV so that I could play them as a SBS 3D movie on my 3D TV.(Just got my self a LG 55″ LED 3D TV.) The reason I opt for the SBS is I can not use the other mode because otherwise the reader of the LG says unsupported format. I’m new to 3D, so I am wondering if it is possible to convert my 3D MTS files to 3D movie in side by side mode. If it is possible, is there a way? Would you please do me a favor to recommend an easy-to-use program?”
In this case, we recommend you a quick workaround to transcode 3D AVCHD MTS files to a proper format for easy playback or editing with Brorsoft 3D MTS Converter. This professional 3D MTS Converter has the full capacity to transcode or convert all the 3D mts files to Side-by-Side 3D videos in a bevy of formats, including MKV, MP4, AVI, WMV, MOV. What's more, the creating SBS 3D videos could be left/right or top/bottom videos. Of course, it also supports 2D AVCHD MTS files as source media. Furthermore, the built-in video editor allows you to easily get desired video part and effects. If you're using a Mac, please turn to Brorsoft MTS/M2TS Converter Mac, which enables you to convert 3D AVCHD to 3D videos on Mac OS X (including Mavericks and Yosemite). Now download the right version and check out the guide below.
Free download the Sony 3D MTS Converter Mac:
Slika (Note: Click here for OS X 10.5)
How to convert Sony 3D MTS to SBS 3D MP4, MKV with ease
Step 1: Launch Converter on Mac, and then click the "Add" button to load the 3D .mts videos. You can also use the drag-and-drop method to load the 3D .mts files to the application UI.
Tip: If you want to merge multiple MTS files into one for easy editing, please tick the box "Merge into one file" to merge all the imported clips.
2. Choose output profile
Click "Format" to select an output profile. Here you can follow the path "MP4 Side-by-Side 3D Video (*.mp4)" for convert 3D mts to side-by-side 3D MP4 video.
Or Follow the path "3D Video > MKV Side-by-Side 3D Video (*.mkv)" for transferring 3D AVCHD to side-by-side 3D MKV video.
3: Edit your 3D Files (Optional)
If necessary, click option under "Edit" icon to start video editing with your 3D files. The supporting editing functions include the cropping frame size, trimming the length, adding watermark, and so on.
4: Start converting 3D MTS files
Click the convert button, the 3D AVCHD converter will start encoding the 3D AVCHD .mts/m2ts files immediately. After the files are converted, tap the Open button to loctae the converted files and bring them into your video editor, edit, export or share.
Related guides:
How to Merge multiple MTS clips
How to Ingest MTS to Pinnacle Studio
How to Import .mts files to Final Cut Pro
Ripping 3D Blu-ray to SBS 3D MP4 Videos
Convert 3D Blu-ray to SBS 3D MKV Videos
Convert iPhone MP4/MOV videos in Final Cut Pro 7/X
Convert H.265/HEVC videos with Handbrake Alternative
Import H.264 MOV/MP4 files from iPhone to Pinnacle Studio 17
Import Blackmagic DNxHD MXF files to Final Cut Pro 7/X Editing
Best way to Play Blu-ray movies on Surface Hub Windows 10 Tablet
Convert and copy Blu-ray, DVD , ISO movies to Windows 10 Tablets
Source: Convert Sony 3D AVCHD MTS to side-by-side 3D MP4 or MKV
Re: Convert Sony 3D MTS to SBS 3D MP4/MKV Playback
Postod Andyeric » 22.05.2015 4:24
Edit FDR-AXP33 4K XAVC in Sony Vegas Pro 13 with Original Quality
I was troubled by the issue- Sony Vegas Pro 13 not seeing 4K XAVC codec. Do you have such experience likewise? If you have got some 4K XAVC files from Sony FDR-AX33, you would probably come across the problem. Let’s look at the XAVC to Sony Vegas Pro 13 importing issues in detail.
"I placed an order on the website for Sony FDR-AX33. I learnt that this camcorder could record videos at 4K with XAVC codec. Although I have not received my camcorder, I am wondering does Sony Vegas Pro 13 support 4K XAVC videos."
"Is there anyone having an issue getting Sony Vegas Pro 13 to accept the 4K XAVC clips from Sony FDR-AX33? Why do the Sony camera divisions and SCS not work together to ensure that their own NLE can accept their own camera footage when a camera is released. It's crazy."
Although Sony states that the Vegas 13/12 supports native XAVC editing, we find it's not easy to edit XAVC in Sony Vegas Pro 13/12/11. To ingest 4K XAVC to Sony Vegas Pro 13 perfectly, Pavtube Video Converter is highly recommended to convert 4K XAVC to Sony Vegas Pro 13 native format-MPG. It’s a best 4K XAVC Converter on Windows 8.1/8 and does a good job in converting 4K XAVC files to Sony Vegas Pro 13 most compatible format with least quality loss. Plus, it supports encoding camera shootings in different formats to video editing software compatible file types to meet your different needs.
Tips: For Mac users, you can get the Pavtube Video Converter for Mac.
Encoding FDR-AX33 4K XAVC to Sony Vegas Pro 13:
Step 1: Run the best 4K XAVC to Sony Vegas Pro 13 Converter, and click the "Add video" button to load 4K XAVC videos from Sony FDR-AX33. If you want to load several files at one time, "Add from folder" button is available.
Step 2: Click "Format" bar to determine output format. Follow "Adobe Premiere/Sony Vegas" and select "MPEG-2(*.mpg)" as the output format. Besides, you can also choose WMV (VC-1) (*.wmv) if you want to get a relatively smaller output file.
Step 3: Adjust video and audio parameters, including the bit rate of video and audio, the codec of video and audio, video size, sample rate, frame rate, audio channels, etc., in the Profile Settings by hitting "Settings" button.
Step 4: Click "Convert" button to start encoding Sony FDR-AX33 4K XAVC files to MPG for importing to Sony Vegas Pro 13.
Conclusion: When the conversion task is finished, click "Open" button to get the exported files and then import the converted AX33 footage into Sony Vegas Pro 13 to do further editing without hassle. In addition, money saving bundles and deals is good news for you! Enjoy!
Further Reading:
Top 3 Best XAVC/XAVC S Video Converter for Mac: XAVC is pretty much new while the existing NLE may not handle it very well. Some XAVC/XAVC S video converters can help us get rid of these troubles.
H.265 vs XAVC vs H.264 high profile output: For many person who just touch the electronic world, the thing which makes them very confused is that the difference, the advantages and disadvantages among those codecs.
How to Store and Stream Movies with Plex for Beginners?: Plex organizes all of your personal media so you can enjoy it no matter where you are. Here are several important steps to store and stream videos, music, movies with Plex in your home.
Best Free Online Programs to Convert MOV to MP4
Upload Canon XC10 4K MXF to YouTube/Vimeo/Facebook on Mac
