Import iPhone MP4/MOV files to Pinnacle Studio editing
Postod lauralily520 » 14.05.2015 9:35
After reading the following pages, you can import video and audio you've taken with your iPhone, iPad, or iPod touch into Pinnacle Studio for editing.
Source From: How to get Pinnacle Studio 17 Recognize iPhone Video files
"I am new to Pinnacle Studio 17(new to video actually), and iPhones as well, and was wondering if there is a detailed procedure on editing iPhone 6 video in Pinnacle. Do I just attach the phone to the computer like any movie camera?"
Hey, actually, the native record format that the iPhone uses isn’t a codec that plays well together with Pinnacle Studio supporte. Codecs are a complicated subject, and FCP tries to be helpful by automatically changing the sequence settings to match the clip. Not only for the H.264 codec videos from iPhone, but also for others like XAVC or H.265.
Pinnacle Studio 17 supports video formats:
MVC, AVCHD?, MPEG-1/-2/-4, DivX?, DV, HDV, AVI, Flash, 3GP (MPEG-4, H.263), WMV, QuickTime? (DV, MJPEG, MPEG-4, H.264), non-encrypted DVD titles (incl. DVD-VR/+VR), DivX Plus? MKV
So,what’s the common practice for iPhone videos to Pinnacle workflow? Well, in order to convert the iPhone H.264 MP4, MOV videos to MPEG-2 for Pinnacle Studio, Brorsoft Video Converter could do this job well. With it, you can convert iPhone h.264 MP4/MOV to Pinnacle Studio and many other programs like Windows Movie Maker, Sony Vegas, Adobe Premiere Pro and more. What's more, all these will be done in three simple steps. No extra codec is needed. This MOV to Pinnacle converter will do all for you. Download the program and read on to see how it works.
Download iPhone Video to Pinnacle Studio converter:
How to convert and import H.264 MOV/MP4 files from iPhone to Pinnacle Studio 17
Step 1: Add iPhone video files
Install and launch the iPhone video to Pinnacle Converter and load source clips to it.
Step 2: Choose output format
Click “Format” bar and choose "Adobe Premiere/Sony Vegas > MPEG-2 (*.mpg)” as output format on the drop-down menu. Of course, you can also choose AVI, WMV from “Common Video” as the output format.
Tip: Click the Settings icon to adjust video and audio parameters on the Profile Setting as you need to get the best quality video.
Step 3: Start iPhone video conversion
Hit the convert button under the preview window, the converter will start encoding iPhone video for importing to Pinnacle Studio immediately. Soon after the conversion is finished, just click "Open" button to get the generated files for edit in Pinnacle Studio 14/15/16/17 perfectly.
More Topics:
How to Rip, Convert and Copy Furious 7 Blu-ray
How to Get Pinnacle Studio Recognize MOV files
Open/edit AVI files in Premiere Pro CC/CS6/CS5/CS4
Rip DVD to H.264 MP4 for Chromebook for Playback
How to Fix MOV and PowerDirector Importing Issues
Convert iPhone MP4/MOV videos in Final Cut Pro 7/X
Convert H.265/HEVC videos with Handbrake Alternative
How to Import MP4 Video to Adobe Premiere Pro CC/CS6
Convert Sony 3D AVCHD MTS to side-by-side 3D MP4 or MKV
Import Blackmagic DNxHD MXF files to Final Cut Pro 7/X Editing
Best way to Play Blu-ray movies on Surface Hub Windows 10 Tablet
Convert and copy Blu-ray, DVD , ISO movies to Windows 10 Tablets
Enables you to rip and convert DVD on Windows 10 easily and quickly
Source:Import H.264 MOV/MP4 files from iPhone to Pinnacle Studio 17
Re: Import iPhone MP4/MOV files to Pinnacle Studio editing
Postod Andyeric » 22.05.2015 4:10
Edit FDR-AXP33 4K XAVC in Sony Vegas Pro 13 with Original Quality
I was troubled by the issue- Sony Vegas Pro 13 not seeing 4K XAVC codec. Do you have such experience likewise? If you have got some 4K XAVC files from Sony FDR-AX33, you would probably come across the problem. Let’s look at the XAVC to Sony Vegas Pro 13 importing issues in detail.
"I placed an order on the website for Sony FDR-AX33. I learnt that this camcorder could record videos at 4K with XAVC codec. Although I have not received my camcorder, I am wondering does Sony Vegas Pro 13 support 4K XAVC videos."
"Is there anyone having an issue getting Sony Vegas Pro 13 to accept the 4K XAVC clips from Sony FDR-AX33? Why do the Sony camera divisions and SCS not work together to ensure that their own NLE can accept their own camera footage when a camera is released. It's crazy."
Although Sony states that the Vegas 13/12 supports native XAVC editing, we find it's not easy to edit XAVC in Sony Vegas Pro 13/12/11. To ingest 4K XAVC to Sony Vegas Pro 13 perfectly, Pavtube Video Converter is highly recommended to convert 4K XAVC to Sony Vegas Pro 13 native format-MPG. It’s a best 4K XAVC Converter on Windows 8.1/8 and does a good job in converting 4K XAVC files to Sony Vegas Pro 13 most compatible format with least quality loss. Plus, it supports encoding camera shootings in different formats to video editing software compatible file types to meet your different needs.
Tips: For Mac users, you can get the Pavtube Video Converter for Mac.
Encoding FDR-AX33 4K XAVC to Sony Vegas Pro 13:
Step 1: Run the best 4K XAVC to Sony Vegas Pro 13 Converter, and click the "Add video" button to load 4K XAVC videos from Sony FDR-AX33. If you want to load several files at one time, "Add from folder" button is available.
Step 2: Click "Format" bar to determine output format. Follow "Adobe Premiere/Sony Vegas" and select "MPEG-2(*.mpg)" as the output format. Besides, you can also choose WMV (VC-1) (*.wmv) if you want to get a relatively smaller output file.
Step 3: Adjust video and audio parameters, including the bit rate of video and audio, the codec of video and audio, video size, sample rate, frame rate, audio channels, etc., in the Profile Settings by hitting "Settings" button.
Step 4: Click "Convert" button to start encoding Sony FDR-AX33 4K XAVC files to MPG for importing to Sony Vegas Pro 13.
Conclusion: When the conversion task is finished, click "Open" button to get the exported files and then import the converted AX33 footage into Sony Vegas Pro 13 to do further editing without hassle. In addition, money saving bundles and deals is good news for you! Enjoy!
Further Reading:
Top 3 Best XAVC/XAVC S Video Converter for Mac: XAVC is pretty much new while the existing NLE may not handle it very well. Some XAVC/XAVC S video converters can help us get rid of these troubles.
H.265 vs XAVC vs H.264 high profile output: For many person who just touch the electronic world, the thing which makes them very confused is that the difference, the advantages and disadvantages among those codecs.
How to Store and Stream Movies with Plex for Beginners?: Plex organizes all of your personal media so you can enjoy it no matter where you are. Here are several important steps to store and stream videos, music, movies with Plex in your home.
Best Free Online Programs to Convert MOV to MP4
Upload Canon XC10 4K MXF to YouTube/Vimeo/Facebook on Mac
