Convert P2 MXF Files to Avid Media Composer Mac
Postod Andyeric » 13.05.2015 10:36
Import P2 MXF Files to Avid Media Composer 8 for Editing on Mac
Avid Media Composer is a popular video editing software on Windows and Mac, many people use it as a mainly software to edit camcorder or camera recorded videos. But, different cameras record videos in different video formats, such as H.264 MOV, MTS, M2TS, MXF and etc. Today, we’ll talk about how to import P2 MXF files to Avid Media Composer 8 for editing on Mac.
As we know, P2 media is recorded in MXF format, and it offers a variety of formats to choose from (DV, DVCPRO, DVCPRO 50, DVCPRO HD, and AVC-Intra 50 and AVC-Intra 100), differing in bit depth (8 or 10 bits), scanning mode (Progressive or Interlaced) and also frame rate. No matter which P2 camcorder you are now having like AJ-HPX2100, AJ-HPX2700, AJ-HPX3000, and AJ-HPX3700, etc you probably would like to edit the recorded P2 MXF footage with an editing program, for example Avid Media Composer 8. While different problems occurred:
"I had no idea that MC8 currently doesn’t support P2 or XDCAM with AMA – Best I can tell Sony or Panasonic has not released updated drivers that support MC8 – My drivers for MC5.5 worked just fine with MC5.5 – but when I visit the update page – no drivers for MC8 are found."
"I have a problem importing .mxf files into my Avid Media Composer 8. Now with MC 8 I only have the import option, and any attempt to just import the files end up with an error message saying that I cannot import the file into a bin, and that I should check documentation."
Problems as you see, the main reason is that MXF is not a natively supported format for Avid Media Composer. It will bring more difficulty to play and edit these files in Avid MC 8 on Mac. So, the best choice is to convert P2 MXF files to Avid MC best accepted format, which ensures maximum editing quality and efficiency when working with Avid Media Composer. Considering the easy of use and lossless quality, Pavtube MXF Converter for Mac is highly recommended.
Step-by-step on how to import P2 MXF files to Avid Media Composer 8 for editing on Mac:
Step 1: Click "Add video" button to load your original P2 MXF files or directly drag the files into file list. By default, the files are selected. You can delete files which you don’t want to import to.
Step 2: Select "Avid DNxHD (*.mov)" as output video format compatible with Avid Media Composer. Click the drop-down list in the format line to get the format box. Then choose "Avid Media Composer>>Avid DNxHD (*.mov)" as output format.
Step 4: You can preview to check the final result. Once you are happy with it, click the "Convert" button to start converting P2 MXF files to Avid DNxHD MOV format. It will take you a little while. When it is finished, you can edit P2 MXF files in Avid Media Composer 8 smoothly on Mac with no format limitation to worry about.
Conclusion: When the conversion is done, you can click "Open" to get your generated files. Now, you can edit P2 MXF files in Avid MC 8 on Mac without any hassles. Good news for everyone! All of us can get 30% discount off before May, 6th, 2015. Come on!
Further Reading:[list=none][*]Import AG-HPX600 P2 MXF to FCP X without Rendering on Mac: When you tried to import some Panasonic P2 MXF files to Final Cut Pro X, you just find that this may be hard work, especially on Mavericks or Yosemite.[*]Convert Panasonic P2 MXF Video to AVI/MP4 Format for Playback: Many people got a camcorder to record vivid videos when they travel or spend weekends, these camcorders may be home used camcorder or high-end camcorder like Panasonic P2 series.[*]XAVC .mxf to Avid Media Composer Solutions on Windows/Mac—How?: Still puzzled with the questions on how to smoothly import your XAVC .mxf files to Avid Media Composer for editing? Here is the right place you come![/list]
2015 Mother's Day is coming! What would you like to send to your mother to make this year's festival unforgettable? A bundle of flowers or a bottle of her favorite perfume as usual? What do you think of the idea of buying a tech-type gift of this year's Mother's Day? To record some precious moments we stay with mother, Pavtube Studio here offers us a big promotion! All video converters we can enjoy a coupon during the celebration!
Promotion Plan A:
On Mother's Day, May 10th, all users can enjoy 40% off discount for all video products in Pavtube Studio! Just write down 'What do you want to say to your mother' under the promotion page is okay!
Promotion Plan B (For all Facebok users):
During May 7th to May 14th, if Facebook users 'Follow' our Pavtube official account and 'Like', all of us can enjoy a big 50% off discountof the strongest tool---Pavtube HD Video Converter for Windows / Mac! With all video conversion works well, this program has a good reputation online.
source: http://digitalmediasolution.altervista.org/blog/edit-p2-mxf-files-in-avid-mc-8-on-mac/
