Best Way to Convert XAVC MXF to FCP 7 for Editing
Postod Andyeric » 13.05.2015 10:28
Summary: You may find Final Cut Pro 7 won't import XAVC MXF files smoothly. The easy workaround is to convert XAVC MXF to FCP 7 more "edit" friendly codec- Apple ProRes codec. If you are looking for a wise solution about how to import XAVC MXF to FCP 7 for editing, you may have interests about this article. Here is how.
Several questions are found in XAVC MXF to FCP forum:
"I am working with a new Sony FS7 video camera that records in XAVC codec as .mxf files - Same as the F5 or F55. I have installed the new ProApps update that is supposed to make it easy to use XAVC in Final Cut 7 which I still use and have also updated Quicktime 7. However neither Quicktime 7 nor FCP 7 will open the .mxf files. I have spent time on the FS7 discussion boards and no one can figure out why. Others are also having the same problem though."
"How do I import XAVC MXF files from my hard drive into Final Cut Pro X? Why I only got the video with no sound after importing to FCP 7?"
"I got the XAVC MXF files from my stuff without original video information. It can be played well in VLC player. However when I import them to FCP 7 for editing, there is no image. What's wrong? "
As we all know, playing and editing .mxf footage on Mac is a big problem. The users may be not so familiar with the MXF video format. And they are told that FCP 7/X can support and edit MXF videos perfectly. But things are not so simple. Owing to video codec, computer configuration and operating environment, it is difficult for FCP to recognize XAVC MXF videos. Even though the users can import the XAVC MXF videos to FCP 7/X, some video and audio problems will occur as the above users met. What's more, FCP 7/X can hardly support single XAVC MXF files without video folder. Considering the easy of use and lossless quality, Pavtube Video Converter for Mac is highly recommended here for you to solve your XAVC MXF to FCP 7 incompatible issues.
How to convert XAVC MXF to FCP 7 for editing?
Step 1: Download and have a quick installation. The trial version will have a watermark on your converted files. Except for that, there are no time limitation, no virus, and no unnecessary bundle apps while downloading. After that, click "Add Video" button to load your XAVC MXF files. You can load several files at once thanks to "Add from folder" button.
Step 2: Click the "Format" bar to get the drop-down menu and you can get "Final Cut Pro>>Apple ProRes codec", including ProRes 422, ProRes 422 (HQ), ProRes 422 (LT), ProRes 422 (Proxy) and ProRes 4444. Choose the proper one you want. Here, we suggest you to choose "Apple ProRes 422 (*.mov)" as the best output format.
Tips: Apple ProRes 422 and Apple ProRes 422 (HQ) have higher qualities. Apple ProRes 422 (LT) and Apple ProRes 422 (Proxy) have smaller sizes. You can choose according to your requirement.
Conclusion: When the conversion is done, you can click "Open" to get your generated files. Now, you can edit XAVC MXF files in FCP 7 without any hassles. Good news for everyone! All of us can get 40% discount off before May, 1st, 2015. Come on! Why not seize the chance and take a close look at the event?
Further Reading:[list=none][*]Transcode 720p MOV to ProRes and Edit Canon G12 MOV Footages on FCP: For many shutterbugs, it is a feast of your eyes that Canon updated G series with a brand new digital camera in 2010.
[*]How to Play MKV, AVI, VOB, FLV, MOV on Sony Xperia Series Tablets?: This article shows you how to convert to MKV/VOB/AVI Sony Xperia tablets playable video format for watching with the best Xperia tablet video converter.
[*]How to Import MPEG-4/H.264 Files to Premiere Pro?: Since I've had huge problems with H.264 and Premiere Pro, I'm looking for H.264 to Premiere Pro solutions to get me out of this confusion. [/list]
2015 Mother's Day is coming! What would you like to send to your mother to make this year's festival unforgettable? A bundle of flowers or a bottle of her favorite perfume as usual? What do you think of the idea of buying a tech-type gift of this year's Mother's Day? To record some precious moments we stay with mother, Pavtube Studio here offers us a big promotion! All video converters we can enjoy a coupon during the celebration!
Promotion Plan A:
On Mother's Day, May 10th, all users can enjoy 40% off discount for all video products in Pavtube Studio! Just write down 'What do you want to say to your mother' under the promotion page is okay!
Promotion Plan B (For all Facebok users):
During May 7th to May 14th, if Facebook users 'Follow' our Pavtube official account and 'Like', all of us can enjoy a big 50% off discountof the strongest tool---Pavtube HD Video Converter for Windows / Mac! With all video conversion works well, this program has a good reputation online.
Source: http://lovecamcorder.tumblr.com/post/11 ... f-to-fcp-7
