Get Sony FDR-AX30 Video Editing Tips in iMovie 11/09/08
Postod lauralily520 » 11.05.2015 9:54
Besides enjoying its Ultra HD video effect, what will you do next of these 4K XAVC S video source from Sony AX30? Obviously, most of you would like to import Sony AX30 XAVC S to iMovie or other NLEs to make a stunning masterpiece. Whereas, iMovie won’t deal with the XAVC S videos.
In order to load Sony FDR-AX30 XAVC-S clips into iMovie for smoothly editing, we need to rewrap or convert original XAVC-S files to Apple InterMediate Code (AIC), the most compatible video codec for iMovie to afford with the help of a professional third party program.
To perform the task, the easiest way is to use Brorsoft Video Converter for Mac which can help you to convert Sony XAVC-S footage to Apple InterMediate Codec(AIC) MOV files - ensuring maximum editing quality and efficiency when working with iMovie (no matter iMovie HD, iMovie 08, iMovie 09, or iMovie 11). Besides, this technical third converter offers various common video codec for editing tools, like Apple ProRes for FCP, DNxHD for Avid, MPEG for Premiere, .etc Read on to learn how to transcode Sony FDR-AX30 4K XAVC S XAVC-S videos to AIC MOV.
Download Sony FDR-AX30 XAVC S Converter Mac
Slika (Note: Click here for OS X 10.5)
How to Convert and Import Sony FDR-AX30 XAVC S videos to iMovie
Step 1: Locate the original Sony FDR-AX30 XAVC S file
Download and run Sony XAVC S Video Converter on Mac, and then click the "Add" button to import the XAVC S videos to the program. (Drag and Drop is also a convenient way to load the videos.)
Step 2: Choose iMovie friendly format
Hit the Format box to select the specially designed video codec for editing in iMovie: iMovie/FCE --> Apple InterMediate Codec(AIC) (*.mov).
Step 3: Video/Audio settings (Optional)
Adjust the video and parameters, including the Bitrate of Video and Audio, Audio, Video Size, Sample Rate, Frame Rate, Audio Channels, etc., by clicking the Settings buttion on the main interface.
Step 4: Start XAVC S to MOV conversion
Click the arrow button to start transcoding Sony AX30 XAVC S to AIC for iMovie immediately.
After the XAVC S to AIC conversion finished, you can easily transfer your 4K XAVC S footages from Sony FDR-AX30 to iMovie for further editing without any problem.
Additional Tips:
If you want to make your Sony FDR-AX30 XAVC S files editable in Final Cut Pro, FCE, Adobe Premiere, Avid Media Composer, etc. the Mac XAVC S Converter will also be a great choice for you. Choose a proper output format like “Final Cut Pro > Apple ProRes 422 (*.mov)”for FCP X/7b in the second step.
Related Guides:
Enable iMovie work with Canon XC10 4K XFAVC videos
Importing Sony PXW-FS7 XAVC into iMovie (iMovie 11)
Convert Sony HX90V XAVC S to ProRes for Final Cut Pro
Use Sony FDR-AX30 4k in Premiere Pro CC/CS6 smoothly
How to Import Sony A7S XAVC S to FCP, iMovie and FCE
Transcode Canon Vixia MTS Converter for iMovie (Yosemite)
Take MP4 clips off Sony PMW-EX1 and Edit with Final Cut Pro
Capturing with iMovie 11/09/08 and Canon Legria VIXIA HV40
Edit Panasonic G5 AVCHD video in iMovie 11/10/09 (Yosemite)
Convert MP4 to MPEG-2 for Adobe Premiere Pro CC/CS6 editing
Source:Edit Sony FDR-AX30 4K XAVC S videos in iMovie 11/09/08
Re: Get Sony FDR-AX30 Video Editing Tips in iMovie 11/09/08
Postod Andyeric » 02.07.2015 7:48
More Guides:
