Sony FDR-X1000V Video Converter: 4K XAVC S to FCP Solutions
Postod Andyeric » 11.05.2015 6:46
Sony FDR-X1000V Video Converter: 4K XAVC S to FCP Solutions Mac
Summary: The latest high definition 4K XAVC S video format from Sony FDR-X1000V is still not supported well by FCP X so far. If you want to edit Sony X1000V 4K XAVC S files in FCP X, a wise solution is to convert X1000V 4K XAVC S files to FCP X best accepted ProRes for editing and using flawlessly.
The Sony FDR-X1000V is a true 4K Action Camcorder that is ideal for capturing fast moving action at close quarters. It is also splashproof and shockproof, with a supplied 10m underwater housing. With its Wi-Fi and GPS connectivity, you can go just about anywhere, prove you are there in glorious 4K quality and share your experiences with your online friends wherever they are in the world.
Maybe you have recorded some footages by Sony FDR-X1000V and you are wondering how to import it recorded XAVC S files to FCP X for editing natively on Mac. As we know, Sony FDR-X1000V recordings are in XAVC S or MP4 format and XAVC S codec is not well supported by Final Cut Pro X/7/6 on Mac. You may encounter importing problems, or can’t edit Sony FDR-X1000V in FCP X/7/6 smoothly, besides, it will take a long time to render.
At present XAVC S, a long GOP inter-frame codec, does not appear to be supported by Final Cut Pro. Apple does not respond on the issues and no one here knows or can say when, if ever, XAVC S will be natively supported by FCP (X). In this case, to smoothly edit FDR-X1000V 4K XAVC S files in FCP X, the easy workaround is to convert Sony X1000V XAVC S to ProRes MOV which is the best codec with best results when working with Final Cut Pro. For this purpose, considering the easy of use and lossless quality, Pavtube Video Converter for Mac is highly recommended. With it, you don’t need to render again and it saves your time.
How to edit FDR-X1000V 4K XAVC S files in FCP X?
Step 1: Download and have a quick installation. The trial version will have a watermark on your converted files. Except for that, there are no time limitation, no virus, and no unnecessary bundle apps while downloading. After that, click "Add Video" button to load your 4K XAVC S files. You can load several files at once thanks to "Add from folder" button.
Step 2: Click the "Format" bar to get the drop-down menu and you can get "Final Cut Pro>>Apple ProRes codec", including ProRes 422, ProRes 422 (HQ), ProRes 422 (LT), ProRes 422 (Proxy) and ProRes 4444. Choose the proper one you want. Here, we suggest you to choose "Apple ProRes 422 (*.mov)" as the best output format.
Tips: Apple ProRes 422 and Apple ProRes 422 (HQ) have higher qualities. Apple ProRes 422 (LT) and Apple ProRes 422 (Proxy) have smaller sizes. You can choose according to your requirement.
Conclusion: When the conversion is done, you can click "Open" to get your generated files. Now, you can edit Sony FDR-X1000V 4K XAVC S files in FCP X without any hassles. Good news for everyone! All of us can get 40% discount off before May, 1st, 2015. Come on! Why not seize the chance and take a close look at the event?
Further Reading:
[list=none][*]Convert Panasonic TM900 MTS Videos to ProRes 422 for Editing on FCP: MTS format is a high-definition video recording format used by many HD camcorders. These camcorders use MPEG-4 compression to store HD video data on SD cards or hard drives.[*]Top 3 Best XAVC/XAVC S Video Converter for Mac Review: Since the 4K movie and camera have got their momentum through all the way, but progress is so rapid in the video industry that the simple fact is 4K wasn’t covered well by existing formats.[*]Enjoy the Downloaded FLV Videos on Your Big Screen TV?: Thanks to YouTube, Vevo, Hulu and other online video sites, we can here download the FLV videos for nice enjoyment, right?
[*]How to Decode H.265 HEVC Videos to MKV, MP4, AVI, WMV, FLV on Mac
[*]How to Encode MP4, MOV, AVI, WMV, MKV to H.265 MP4 on Mac?[/list]
2015 Mother's Day is coming! What would you like to send to your mother to make this year's festival unforgettable? A bundle of flowers or a bottle of her favorite perfume as usual? What do you think of the idea of buying a tech-type gift of this year's Mother's Day? To record some precious moments we stay with mother, Pavtube Studio here offers us a big promotion! All video converters we can enjoy a coupon during the celebration!
Promotion Plan A:
On Mother's Day, May 10th, all users can enjoy 40% off discount for all video products in Pavtube Studio! Just write down 'What do you want to say to your mother' under the promotion page is okay!
Promotion Plan B (For all Facebok users):
During May 7th to May 14th, if Facebook users 'Follow' our Pavtube official account and 'Like', all of us can enjoy a big 50% off discountof the strongest tool---Pavtube HD Video Converter for Windows / Mac! With all video conversion works well, this program has a good reputation online.
Source: http://bestvideoking.blogspot.com/2015/ ... fcp-x.html
