Editing XAVC S files from Sony AX30 in Final Cut Pro
Postod lauralily520 » 08.05.2015 11:12
Sony FDR-AX30 64GB Internal Flash Memory 4K Camcorder Features
*XAVC S 50Mbps High Bitrate captures details of complex scenes with clarity
*Exmor R CMOS Sensor produces superb image quality even in low light conditions
*Balanced Optical SteadyShot image stabilization produces ultra-high-quality images without blurring
*Wi-Fi and NFC allows remote operation and content transfer to smartphones via PlayMemories Mobile
*4K sampling Full HD playback lets users watch 4K footage as high-quality movies on a Full HD TV
*More compact & lightweight
Sony FDR-AX30, the most compact 4K Handycam camcorder. While, the users would get frustrated when import Sony AX30 XAVC S to FCP 7/X for further editing. This article is mainly to solve the Sony FDR-AX30 to Final Cut Pro importing problems.
In fact, XVAC S as a new codec does not appear to be supported by FCP 7, FCP X. Then how to import Sony FDR-AX30 videos to Final Cut Pro for editing without any issue? Well, if you make the XAVC S recordings editable before taking to the Final Cut Pro program, the incompatible error won't happen any more.
Since Apple ProRes is the best format for FCP, here we highly recommend to transcode Sony FDR-AX30 XAVC S to ProRes with Brorsoft Video Converter for Mac. This Mac XAVC S converter is the solid tool to help users transcode Sony XAVC S footage on Mac OS X(Mavericks, Yosemite included). It offers the optimal preset profiles for Final Cut Pro and iMovie, Avid Media Composer, Adobe Premiere Pro, FCE and more. And there is no need to worry about the quality loss. Download the software and follow the detailed guide.
Slika (Note: Click here for OS X 10.5)
Convert XAVC S from Sony FDR-AX30 for editing in Final Cut Pro X/7
Step 1: Load XAVC S footages
Install the XAVC S to ProRes Converter program on Mac and run it. Drag the XAVC S files to the software. Or you can also click “Add” button on the top of the main interface to import video to the program.
Step 2: Choose a proper output format
Click the “Format” bar and select Final Cut Pro> Apple PreRes 422(*.mov) as output format. This format is specially designed for FCP, so that you can edit your original Sony AX33 video in Final Cut Pro perfectly.
Tip: You can click “Settings” to set video frame rate, video size and Video Bitrate as you want.
Step 3: Start converting Sony FDR-AX30 footage
Click the “Convert” icon under the preview window, and the Mac video converter will start converting Sony AX30 XAVC S to Prores MOV for FCP(X) on Mac.
After the conversion, launch Final Cut Pro, choose File > Import > Files…, and browse to where you save the converted XAVC S clips to. Now you can start fun away with editing Sony FDR-AX30 video in Final Cut Pro X or FCP 7/6 easily.
Related Guides:
How to import Sony a77II XAVC S to FCP 7/X
How to Import Sony AS200V/W XAVC S to FCP 7/X
Open/edit AVI files in Premiere Pro CC/CS6/CS5/CS4
Enable iMovie work with Canon XC10 4K XFAVC videos
Use Sony FDR-AX30 4k in Premiere Pro CC/CS6 smoothly
How to open and edit Sony A77 II footage in Adobe Premiere
Transcode iPhone H.264 MOV video to MPEG-2 for Pinnacle
How to Convert XAVC/XAVC S to ProRes Quickly and Easily
How to Import & Edit Sony FDR-AX1 4K XAVC S files in Final
Sony FDR-AX30 Video Converting/Editing Tips in iMovie 11/09/08
Converting Sony NEX-FS700 60p/50p AVCHD to Apple ProRes MOV
Edit Canon C500 MXF files in Final Cut Pro 6/7/X (Yosemite & Mavericks)
Source:Convert Sony FDR-AX30 XAVC S to FCP X, Final Cut Pro 7/X
Re: Editing XAVC S files from Sony AX30 in Final Cut Pro
Postod Andyeric » 02.07.2015 7:49
More Guides:
