MKV, AVI , VOB, FLV,WMV Playback on Blackphone 2 Tips
Postod lauralily520 » 30.04.2015 10:52
[size="4"]When Blackphone 2 fails to play MKV, AVI, WMV, MP4, VOB, M2TS videos, you may try transcode the videos to Blackphone 2 supported formats/codecs. Below guide is the best solution for you.[/size]
Source From: Convert MKV/VOB/AVI files for playback with Blackphone 2
Blackphone 2 has a 5.5-inch, 1,920x1,080-pixel screen protected by Gorilla Glass 3, a 64-bit octa-core processor and 3GB of memory. There's a non-removable quick-charging 3,060mAh battery, and expandable storage via a microSD port.However, Blackphone 2 supported video formats are limited to 3GP, AVI, ASF, MP4, MOV, WMV.
Q: ‘I have collected rich movies on my computer’s HDD with various formats like MKV, AVI, VOB, etc. what I want is to copy movies onto Blackphone 2 and then play at anytime, anywhere. I found the Blackphone can’t support all my video files, so I need Blackphone 2 video converter to convert the movies. Any good suggestions?’
In fact, this task can be easily accomplished with a qualified Blackphone 2 video converter. Along with some help from Brorsoft Video Converter, a powerful video converter, editor and player, you can effortlessly achieve your goal. It is an easy-to-use and high-efficiency program that helps you batch convert almost any video (including MKV, AVI, VOB, MTS, MPG, TiVo, MTS...) to Blackphone 2 highly compatible file type. Besides, with the built-in video editor, you can freely trim, crop, adjust effect, add (*.ass, *.ssa, *.srt) subtitles to your source video. The equivalent Mac version is Video Converter for Mac, which enables you to encode HD videos to Blackphone 2 on Mac OS X. Follow the steps below and you can play AVI, VOB, MKV on Blackphone 2 easily.
Download Blackphone 2 Video Converter:
Slika Slika (Note: Click here for OS X 10.5)
Step 1. Add video files to the program
Launch the Video Converter for Blackphone 2 and add videos in the following two ways: 1> Click Add button to choose video files from your hard drive for converting. 2> Directly drag the movies you want to convert to the left item bar.
Step 2. Decide output video format
Click "Format" bar and choose MP4 from "Common Video" as output format, which can be supported by Blackphone 2. If your source video is in 1080p and you want to keep 1080p resolution as source movie, you can choose HD Video > H.264 HD Video(*.mp4) for Blackphone 2.
Step 3. Advanced Video, Audio Settings
The default settings may not satisfy you, and you can click the settings button to change the settings by yourself including video resolution, bit rate, audio sample rate, audio channel etc. for full screen playback smoothly or select the corresponding device as the output format.
Step 4. Start Blackphone 2 video conversion
Finally click on "Convert" button to start encoding MKV/AVI/VOB to Blackphone 2 friendly MP4 video.
Once the conversion finished, transfer the converted video files to Blackphone 2 and you can have the AVI, MKV, VOB and more movies playback at ease.
Related Guides:
How to convert a MVI file to .avi, .wmv, .flv, mov…?
Rip DVD/ISO to Yoga 2 Tablet mp4 format Playback
Edit MP4 files in iMovie 11/09/08 with AIC MOV format
How to Put and Play AVI/VOB/MKV Files on Blackphone 2
Import/convert MPG to Final Cut Pro (X) on OS X Yosemite
Take MP4 clips off Sony PMW-EX1 and Edit with Final Cut Pro
Converting VOB to Apple ProRes 422 MOV for Final Cut Pro X
Converting MTS files to ProRes MOV for Editing in Final Cut Pro
Import Canon C300 mxf footage into Avid, Premiere, iMovie, FCP
Take GoPro Hero 2/Hero3 footage and import to Premiere Pro CC/CS6
Source: How to put and add MKV/AVI/VOB files to Blackphone 2
Re: MKV, AVI , VOB, FLV,WMV Playback on Blackphone 2 Tips
Postod Andyeric » 01.07.2015 10:20
Store VOB Files in NAS Server for playing on Plex
Overview: VOB, like many other formats, is just a container that houses digital video encoded with an MPEG-2 codec. This tutorial will explain how to convert your VOB files to MP4/MKV format for storing on your NAS and streaming over Plex.
Hot Search: Tivo to NAS | iMovie files to NAS | YIFY Torrents to Plex | AVI to Plex | GoPro video to Plex | MKV to Plex
"Recently our company shot some recordings encoded by VOB and for a further usage later, we need to store them in NAS server. But we fot some trouble when importing VOB files to NAS, something there always wrong with the original source as warning. So we cannot play them on Plex player and only MKV and MP4 can be accepted." While today here we would like to share some experience of converting VOB to MKV and MP4 with no quality loss in some efficient ways. (Read Plex Supported Formats)
What's the difference and usage between VOB and MP4?
VOB is the core format of files in DVD Video discs and contain the actual movie data. While MP4 is commonly used for saving files recorded by camcorder, or sharing video files on the Internet, or playing on various hardware devices like Plex player, or some other popular NLEs like iMovie, etc. Therefore sometimes people need to convert VOB to MP4 to enjoy and share VOB files with others.
How to convert VOB to MP4/MKV with no quality loss?
In order to covert VOB files to MP4 or MKV for storing in NAS and playing on Plex, we here highly recommend you the Pavtube Video Converter for Windows/Mac, which we can use to converting VOB to MP4/MKV or others with high quality preserved. Additionally, all Windows and Mac operation system can be supported well. Let's together see how it works.
Slika Slika (Privce: $35)
Step 1.Just drag and drop your VOB files from the computer to the pane of this app, or click the "Add Files..." option at the top left corner of this app's pane to choose and import the files you want to convert.
Step 2. Come to the output list by clicking the 'Format' bar on the left of the preview window. In order to preserve the high quality, we would like to suggest you to choose the 'HD Video' to select the 'H.264 HD Video (*.mp4)' or 'MKV HD Video (*.mkv)' as we mentioned above.
Step 3.Optional editing function you wanna a try? click the "Edit" button, and then you can customize your video by cropping, trimming, changing video effects, adding watermarks or a subtitle, etc.
Finally,
click "Convert" to start to change VOB to MP4. After that you can click "Open Folder" to find out where the output files are saved. If you want to set where you to save the output files, click the "Output Folder" drop-down list to set it before the conversion. Then it's time to store our VOB files in NAS and enjoy them on Plex player! (Plex Guide for Beginners)
More Tips:
Play Any Videos on Apple Devices via Plex Media Server
Convert Videos from OPO to Tablets and Smart TV for Watching
Play MKV on Roku 3/2 via USB Interface
Convert TiVo Files for Playback on Android Tablet
Convert M2TS with DTS for Playback on PS3 with AC3 5.1 Surround
Problems with VLC Player When Playing H.265 Videos
Stream 1080p/720p MKV Movies to Apple TV with with Dolby Digital 5.1
How to Convert FLV to QuickTime for Playing?
Play MPG/MPEG Files on Surface 3/Pro 3 without Issues
FLAC vs WAV vs WMA: Convert Audio Files on iOS Devices
Watch HD Videos on Samsung Galaxy Tab Series Tablets
Get Kindle Fire HDX 7 to Play all 1080p/720p MKV HD movies
Convert MXF Videos for TV Broadcasting and Vimeo Sharing
Source: http://bestvideoking.blogspot.com/2015/02/convert-vob-to-mkv-mp4-for-nas.html
