Import and Edit Canon XC10 4K MXF in FCP X/7/6
Postod lauralily520 » 27.04.2015 10:10
Follow this article, you can learn the best way to import Canon XC10 MXF footage into FCP 7/X on Mac by transcoding 4K MXF to ProRes for Final Cut Pro.
Canon's new XC10 instantly caught our attention, thanks to its distinctive, out-of-the-ordinary design. The XC10 can shoot 4K and 1080p video at up to 30 fps and 60 fps, respectively. Well, in this page, we aim to share some tips and tricks for Canon XC10 workflow on Mac like how to import Canon XC10 4K MXF to FCP under Mac OS X smoothly. If you met any XC100 MXF files to FCP 6/7/X importing or editing issues, go through the page to find the solution.
As we know, Canon XC10 can record 4K and 1080p high definition video using MPEG-4 AVC/H.264 compression and the footage is wrapped in an MXF container. However, MXF format can’t be natively supported by many professional video editing applications including FCP 6, FCP 7 and even the Final Cut Pro X. What’s more, it also would be a bit hard to handle 4K video with Final Cut Pro 6/7. That’s reason why there are so many guys are facing troubles when editing Canon XC10 MXF files in Final Cut Pro. Well, things can be different if you get some help from third-party software Brorsoft MXF Converter for Mac.
Overall, the program is a professional yet easy-to-use MXF Converter on Mac OS X, which can not only convert Canon XC10 1080p or 4K MXF files to ProRes for FCP editing, but also provide simple video editing functions for you. This Mac MXF Converter can also transcode MXF videos from Canon C30O0, XF100, XF105, XF305, Panasonic P2 cameras for editing in Final Cut Pro 6/7, Final Cut Pro X, Final Cut Express, iMovie, Avid Media Composer, Adobe Premiere Pro, etc on Mac OS X(Mavericks and Yosemite included). Just download it and follow the tutorial below to get the work done.
Transcoding Canon XC10 footage to ProRes for editing in Final Cut Pro
Step 1: Import MXF video files from your Canon XC10 to the MXF to FCP Converter.
Step 2: Click on the “Format” bar and get the dropdown menu, then move your pointer to choose “Final Cut Pro> Apple ProRes 422" or "Apple ProRes 422 HQ" or "Apple ProRes 4444" as the output format.
Step 3: Click “Convert” button to start converting Canon XC10 4K MXF to ProRes .mov for Final Cut Pro under Mac OS X.
More helpful features of the MXF to ProRes Converter:
1. Settings- Click “Settings” button if you’d like to customize advanced audio and video parameters like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sample rate, audio channels.
2. Editor (next to “Add” icon)- click to deinterlace, trim, crop, add effect, etc.
Once the conversion is done, you can transfer Canon XC10 MXF footage into Final Cut Pro 6/7/X for editing smoothly on Mac with ease.
Related Guides:
Edit Nikon D5500/D3300/D5300 in FCP X
How to Make VOB videos playback on LG TV
How Get iMovie work with Canon G3 X footage
Convert Sony XDCAM to Sony Vegas Pro for editing
Canon XF Plugin for Final Cut Pro (X)| FAQs & Answers
How to Import TS files to After Effects CS4/CS5/CS6/CC
How to Convert Canon MXF for Sony Vegas further editing
Fix Final Cut Pro won’t import Nikon D5500/D3300/D5300 footage
How to Transcode Canon MXF to DNxHD for Avid Media Composer
Transcode Nikon D7200/D7100/D700 MOV files to Windows Movie Maker
Source: Canon XC10 MXF files to Final Cut Pro 7/X workflow
Re: Import and Edit Canon XC10 4K MXF in FCP X/7/6
Postod Andyeric » 01.07.2015 10:17
Import Canon XF105/XF100 MXF files to iMovie on Mac
If you are a camcorder fan, you may know much about Canon XF series camcorders, they are excellent camcorders used by many professional photographers. It's great to use Canon XF105/XF100 camcorder to record videos with vivid image. Then after editing MXF recordings in Premiere Pro, FCP, or iMovie, etc, we can enjoy the movies with a nice effect, right?
Canon XF105 professional Camcorder is a compact, lightweight and fully functional camcorder that can be tailored to fit a wide range of individual needs. And Canon's XF100 HD Professional Camcorder is an amazingly compact, fully featured pro video camera that imports nearly all the features and functionality of the 3-chip XF300 into a smaller, single sensor form factor.
Taking advantage of the latest HD technology–along with Canon's robust MPEG-2 4:2:2 codec–The XF105/XF100 utilizes Canon's XF Codec-a file-based MPEG-2 compression with an MXF File Wrapper that ensures the widest compatibility with existing industry infrastructure, metadata and non-linear editing (NLE) systems.
Many Canon users will find importing issues when putting MXF recordings into iMovie. The reason is that iMovie can't handle Canon MXF files smoothly. Now here is a solution, of course, to help you transfer MXF footage to imovie. The next few steps will show you how to do with Canon MXF shootings (taken with Canon XF105 or XF100) before importing the Canon XF MXF footage to iMovie on Mac OS X.
Before processing, you're suggested to
1. Transfer mxf clips from Canon XF 105/XF100 camcorderto Mac computer.
2. Download and Install Pavtube Pavtube MXF Converter for Mac. The best Mac MXF to iMovie Converter can transcode Canon XF105/XF100 MXF files to iMovie friendly AIC MOV for smooth editing on Mac (Yosemite included). (Read also Best MXF Converter for Mac Review)
Guide: Transcode Canon MXF to Apple Intermediate Codec for iMovie editing
Step 1. Launch the Pavtube Mac MXF to AIC Converter. Click "Add" and browse to a Canon .mxf clip and the software will add it to file list. Repeat the operation to load multiple .mxf videos.
Step 2. Click on "Format" and choose "iMovie > Apple Intermediate Codec (*.mov)".
You can click "Settings" and adjust bitrate (from 1Mbps to 20Mbps) your requirement. You can also set a different video resolution (1920×1080/1440×1080/1280×720/720×480) and frame rate(24p/30p) as long as you like.
Step 3. Click "Convert" to start converting Canon XF105/XF100 MXF to AIC videos for imovie.
After conversion click "Open" to find .mov videos and import converted .mov files to imovie for editing. Now you can smoothly edit XF105/XF100 MXF files in imovie as you want, just enjoy yourself.
Tip 1: Video and audio are separate when it comes to MXF, don't drop the Audio folder when loading .mxf files to Pavtube Canon MXF Converter for Mac, as the software will detect and find audio for corresponding video clips automatically.
Tip 2: Pavtube HD Converter for Mac can convert 1080p cameras/camcorders footages to editable HD video formats for non-linear editing software like iMovie, Final Cut Express, Final Cut Pro, Final Cut Studio, Avid, Adobe Premiere etc. The HD footage can be compressed to SD video clips for storage when you wanna save storage space.
Related articles for Canon:
Wanna Extract One Stereo WAV from MXF 4 Audio Tracks?
Canon XF300 MXF to FCP 6/7/X Workflow on Yosemite
Best Multi-track MXF Converter Review on Windows
Top multi-track MXF Converter for Mac Review: Pavtube vs Tipard
Solve no audio issue when converting HVX200 P2 MXF to ProRes 422 for FCP X
Import Ikegami HDS-V10 MXF to Avid Media Composer for Editing
Work Avid DNxHD MXF Recordings with Premiere Pro CC
Convert Sony XDCAM MXF to Multi-track Apple ProRes for FCP X/6/7
How to Play MXF with VLC on Mac?
Import Sony PDZ-VX10 XDCAM MXF to FCP 6/7 without rendering
Import PanasonicP2 MXF to Avid, Sony Vegas, Pinnacle, Cyberlink, Windows Movie Maker
Import Sony A7s MP4 to Resolve 10/11
Source: http://lovecamcorder.tumblr.com/post/48244625883/easily-edit-canon-xf105-xf100-mxf-files-with-mac
