How to get editable and deinterlaced MTS video for FCP X
Postod Andyeric » 27.04.2015 5:20
Best MTS Mac Converter--Convert MTS/AVCHD to Final Cut Pro
Summary: Can't import mts files to Final Cut Pro X? Follow the article below, you will get to know the easy way to transcode and deinterlace AVCHD footage to Prores HQ for editing in FCP X editing.
AVCHD was jointly established by Sony Corporation and Panasonic Corporation in 2006 for use in their digital tapeless camcorders. MTS files can typically be opened and edited using the software included with Sony, Panasonic and some Canon HD camcorders.
But practically speaking, importing AVCHD to FCP might be tricky, due to the version of FCP, your Mac processor (PowerPC- or older Intel-based Mac don't support AVCHD editing) , and the model of camcorder. Thus, many users report that they can't import AVCHD files into FCP using camera import.
I just downloaded a mts Video converter and I'm using it to convert MTS files into Apple HQ prores 422, yet the converted files look damaged. I attached a photo of what the results look like. I must finish this editing project by tomorrow- please advise!
As MTS recordings are not the preferred format for Final Cut Studio, if you want to edit AVCHD video with high quality on Mac with Final Cut Pro X, you can convert AVCHD to FCP compatibel Prores .MOV before editing. Here recommend you the top Pavtube MTS/M2TS Converter for Mac which can help you to convert AVCHD to Apple ProRes 422 preserving the original quality that get MTS files to edit in FCP X successfully. Plus, this Mac AVCHD converter also supports converting AVCHD MTS footage to iMovie, Adobe Premiere, Avid Media Composer, Final Cut Express and more to meet your needs. What's more, some easy-to-use editing features like trimming, cropping, adding watermark, deinterlacing, etc are combined with the convert program. Now, follow the step-by-step guide transcoding and deinterlacing MTS video to Final Cut Pro X.
Step 1: Free Download and install MTS to FCP Converter to your Mac. It's excellent AVCHD Converter which can convert nearly all Sony/Canon/Panasonic camcorder videos to any formats you need, such as Apple Prores 422 MOV, Apple InterMediate Codec MOV, QuickTime MOV, etc. Then import your AVCHD files.
Step 2: Click the format bar, and move mouse cursor to "Final Cut Pro > Apple ProRes 422(HQ) (*.mov)" as output format for editing in Final Cut Pro X.
The Apple ProRes 422 (HQ) codec offers the utmost possible quality for 4:2:2 or 4:2:0 sources (without an alpha channel) and provides the following:
  • Target data rate of approximately 220 Mbps (1920 x 1080 at 60i)
  • Higher quality than Apple ProRes 422
1.You can also select Apple ProRes 422(LT) which will give smaller file size.
2.Learn more Apple ProRes, please refer to Types of Apple ProRes Codecs
3. You can deinterlace and edit the 1080/60i mts videos in this program before converting to other formats on Mac OS. Trim, crop, add watermark or adjust effect as you want.
By the way, if you need to remove interlace for the media file, just click on "Edit", you will see a Video Editor panel where you are able to easily edit your 1080i HD video by using several powerful editing functions. Click on "Effect" tab, and check the deinterlace option.
Step 3. Click "Convert" button to start converting/deinterlacing AVCHD videos to FCP X on Mac OS.
After a shot conversion, you will be able to import/load mts videos into Final Cut Pro X for editing without rendering. With it, you can also get the mts video to recognized by FCP X. Just have a try. Good luck!
Related gudie:
Sony AVCHD MTS converter for Premiere
How to convert MTS to AVI format for editing and playing?
Sony AVCHD MTS Converter for Sony Vegas-AVCHD to Sony Vegas
How to Import iPhoto to iMovie on Mac OS X
Encode/Decode Samsung NX1 H.265 Videos to WMM
Good News! Pavtube --------Video Converter for Mac ($35, Now $21 ) (buy link) Save up to $14! End on 2015.5.1. Never miss!!!
Source: [/b]http://digitalmediasolution.altervista.org/blog/convert-deinterlace-mts-to-fcp-x/
