Edit Sony XDCAM files in Sony Vegas Pro 13/12/11
Postod lauralily520 » 24.04.2015 11:29
Why Sony Vegas can not read XDCAM files? Follow this tutorial to convert Sony XDCAM files to MPEG-2 for Vegas Pro to achieve your goal smoothly.
It should come as no surprise that Sony Vegas Pro supports all versions of XDCAM(XDCAM HD, XDCAM EX, XDCAM HD422) natively. However, users still encounter some problems during importing Sony XDCAM to Sony Vegas Pro for further editing:
“I have a client who gave me an XDCAM EX .mp4 file to add to his project, but Vegas Pro 12 doesn't like it.”
To bypass all issues while editing Sony XDCAM videos in Sony Vegas, first please make sure you copy all the files in the media card folder to your source footage drive, keeping the folder name and structure intact. If it still doesn’t work, the easy workaround for you is to encode Sony XDCAM MXF/MP4 to Sony Vegas most compatible MPEG-2 format so that Sony Vegas Pro can afford the videos directly without any issue.
To achieve the goal, the program Brorsoft Video Converter can give you some help. Well, this XDCAM Converter allows you to convert Sony XDCAM to MPEG-2 for Vegas Pro 13/12/11/10 with zero quality loss. Plus, it also supports transcoding Sony XDCAM, XDCAM HD, XDCAM EX to DNxHD for Avid Media Composer, MPEG-2 for Adobe Premiere Pro/After Effects, WMV for Windows Movie Maker. Below is how.
How to Encode Sony XDCAM videos for using in Sony Vegas Pro
Step 1: Load Sony XDCAM files to the program by clicking “Add” button, or drag the videos to the software directly.
Step 2: Click “Format” bar to determine output format. Follow “Adobe Premiere/Sony Vegas” and select “MPEG-2(*.mpg)” as the output format.
Tip: You can adjust video and audio parameters, including the Bitrate of Video and Audio, the Codec of Video and Audio, Video Size, Sample Rate, Frame Rate, Audio Channels, etc., in the Profile Settings.
Step 3: Click the Arrow icon under the preview window, and the program will start converting XDCAM files to MPEG-2 for Sony Vegas Pro.
After the conversion finished, you can freely import your transcoded Sony XDCAM clips into Sony Vegas Pro 13/12/11/10 with any incompatibility issues.
More topics:
Convert Sony X1000V XAVC S to ProRes for FCP 7
How to import FCP Projects to Premiere Pro CC/CS6
Converting MTS/M2TS to MOV with zero quality loss
Import Sony XDCAM/XDCAM HD/XDCAM EX to FCP
Transfer Blu-rays/DVDs to Galaxy Tab 3 Kids Edition Tablet
Can DaVinci Resolve handle the 4K XAVC/XAVC S playback
Can Sony X1000V XAVC S be edited in Adobe Premiere Pro?
Converting Sony XDCAM footage to QuickTime MOV on Mac
Fix Final Cut Pro won’t import Nikon D5500/D3300/D5300 footage
Importing Sony XDCAM, XDCAM HD, XDCAM EX to After Effects
Transcode Nikon D7200/D7100/D700 MOV files to Windows Movie Maker
Source: Best XDCAM files to Sony Vegas Pro 13/12/11/10 workflow
Re: Edit Sony XDCAM files in Sony Vegas Pro 13/12/11
Postod Andyeric » 02.07.2015 11:08
Store VOB Files in NAS Server for playing on Plex
Overview: VOB, like many other formats, is just a container that houses digital video encoded with an MPEG-2 codec. This tutorial will explain how to convert your VOB files to MP4/MKV format for storing on your NAS and streaming over Plex.
Hot Search: Tivo to NAS | iMovie files to NAS | YIFY Torrents to Plex | AVI to Plex | GoPro video to Plex | MKV to Plex
"Recently our company shot some recordings encoded by VOB and for a further usage later, we need to store them in NAS server. But we fot some trouble when importing VOB files to NAS, something there always wrong with the original source as warning. So we cannot play them on Plex player and only MKV and MP4 can be accepted." While today here we would like to share some experience of converting VOB to MKV and MP4 with no quality loss in some efficient ways. (Read Plex Supported Formats)
What's the difference and usage between VOB and MP4?
VOB is the core format of files in DVD Video discs and contain the actual movie data. While MP4 is commonly used for saving files recorded by camcorder, or sharing video files on the Internet, or playing on various hardware devices like Plex player, or some other popular NLEs like iMovie, etc. Therefore sometimes people need to convert VOB to MP4 to enjoy and share VOB files with others.
How to convert VOB to MP4/MKV with no quality loss?
In order to covert VOB files to MP4 or MKV for storing in NAS and playing on Plex, we here highly recommend you the Pavtube Video Converter for Windows/Mac, which we can use to converting VOB to MP4/MKV or others with high quality preserved. Additionally, all Windows and Mac operation system can be supported well. Let's together see how it works.
Slika Slika (Privce: $35)
Step 1.Just drag and drop your VOB files from the computer to the pane of this app, or click the "Add Files..." option at the top left corner of this app's pane to choose and import the files you want to convert.
Step 2. Come to the output list by clicking the 'Format' bar on the left of the preview window. In order to preserve the high quality, we would like to suggest you to choose the 'HD Video' to select the 'H.264 HD Video (*.mp4)' or 'MKV HD Video (*.mkv)' as we mentioned above.
Step 3.Optional editing function you wanna a try? click the "Edit" button, and then you can customize your video by cropping, trimming, changing video effects, adding watermarks or a subtitle, etc.
Finally,
click "Convert" to start to change VOB to MP4. After that you can click "Open Folder" to find out where the output files are saved. If you want to set where you to save the output files, click the "Output Folder" drop-down list to set it before the conversion. Then it's time to store our VOB files in NAS and enjoy them on Plex player! (Plex Guide for Beginners)
More Tips:
Play Any Videos on Apple Devices via Plex Media Server
Convert Videos from OPO to Tablets and Smart TV for Watching
Play MKV on Roku 3/2 via USB Interface
Convert TiVo Files for Playback on Android Tablet
Convert M2TS with DTS for Playback on PS3 with AC3 5.1 Surround
Problems with VLC Player When Playing H.265 Videos
Stream 1080p/720p MKV Movies to Apple TV with with Dolby Digital 5.1
How to Convert FLV to QuickTime for Playing?
Play MPG/MPEG Files on Surface 3/Pro 3 without Issues
FLAC vs WAV vs WMA: Convert Audio Files on iOS Devices
Watch HD Videos on Samsung Galaxy Tab Series Tablets
Get Kindle Fire HDX 7 to Play all 1080p/720p MKV HD movies
Convert MXF Videos for TV Broadcasting and Vimeo Sharing
Source: http://bestvideoking.blogspot.com/2015/02/convert-vob-to-mkv-mp4-for-nas.html
