Sony FDR-X1000V 4K to Final Cut Pro 7 Workflow
Postod lauralily520 » 24.04.2015 10:16
How to Sony FDR-X1000V 4K XAVC S files to Final Cut Pro 7? From this page, you will find the best solution to edit Sony X1000V XAVC S with FCP 7.
Sony FDR-X1000V is a versatile, splash resistant camcorder. Using the XAVC S codec, the FDR-X1000V can record UltraHD resolution 4K (3840 x 2160) at 30p with a bitrate of 100 Mb/s or 24p with a bitrate of 60 Mb/s. While most users’ confusion is, whether the Sony FDR-X1000V 4K XAVC S files can be edited in Final Cut Pro 7? How to import Sony X1000V XAVC S to FCP 7 for editing flawlessly?
At present XVAC-S, a long GOP inter-frame codec, does not appear to be supported by Final Cut Pro. Apple does not respond on the issues and no one here knows or can say when, if ever, XVAC-S will be natively supported by FCP (X). In this case, to smoothly edit FDR-X1000V 4K video in Final Cut Pro 7, the easy workaround is to convert Sony X1000V XAVC S to ProRes MOV which is the best codec with best results when working with Final Cut Pro. For this purpose, this article will guide through how to rewrap and transcode Sony X1000V 4K XAVC S to FCP 7 in details.
Converting Sony X1000V XAVC S to Apple ProRes for Final Cut Pro 7
The quick workaround is to use the easy-to-use yet professional app Brorsoft Video Converter for Mac. This Mac XAVC S converter can enable you to effortlessly transcode Sony X1000V XAVC S files to ProRes - ensuring maximum editing quality and efficiency when working with Final Cut Pro (no matter Final Cut Pro X, FCP 7 or FCP 6). What’s more, it also allows you to convert XAVC, XAVC S to iMovie, Adobe Premiere Pro, Avid Media Composer, etc with the best quality. The conversion is darn easy to be finished with only three clicks without loss of video quality.
1. Load XAVC S files to the Program
You can directly drag and drop the XAVC S files from your FDR-X1000V to the software, or click "Add" or "Add From Folder" to locate the XAVC S clips into the converter.
2. Choose Final Cut Pro as Output Format
Press "Format" option and navigate the mouse cursor to choose "Format > Final Cut Pro > Apple ProRes 422 (*.mov)" as the best codec for FCP 7 on Mac.
Tips: You can click “settings” button in the main interface to customize the output video’s parameters, such as resolution, frame rate, etc.
3. Start XAVC S to FCP conversion
Click the “Convert” icon, and the XAVC S to FCP Converter will start converting Sony X1000V XAVC S to ProRes MOV for FCP 7 on Mac OS X.
After the conversion, launch Final Cut Pro, choose File > Import > Files…, and browse to where you save the converted XAVC S clips to. Now start your project with the converted Sony FDR-X1000V 4K XAVC S videos in FCP 7.
Further reading:
Work With XAVC/XAVC S Footage in DaVinci Resolve 11
Best XDCAM files to Sony Vegas Pro 13/12/11/10 workflow
Transfer Blu-rays/DVDs to Galaxy Tab 3 Kids Edition Tablet
How to Get Avid Media Composer Work With XAVC S Clips
Can Sony X1000V XAVC S be edited in Adobe Premiere Pro?
How to Convert XAVC/XAVC S to ProRes Quickly and Easily
Migrating Projects from Final Cut Pro to Premiere Pro CC/CS6
Fix Final Cut Pro won’t import Nikon D5500/D3300/D5300 footage
Convert MTS/M2TS Video Files to MOV on Mac OS X (Yosemite included)
Transcode Nikon D7200/D7100/D700 MOV files to Windows Movie Maker
Source:Convert Sony X1000V XAVC S to ProRes for FCP 7
Re: Sony FDR-X1000V 4K to Final Cut Pro 7 Workflow
Postod Andyeric » 02.07.2015 11:09
Related:
