How to transfer XAVC/XAVC S to DaVinci Resolve 11
Postod lauralily520 » 22.04.2015 10:19
Find out the best way to import and edit XAVC, XAVC S footage in DaVinci Resolve. To convert Sony XAVC/XAVC S to DaVinci Resolve more compatible video like DNxHD.
There are always issues to play and edit XAVC, XAVC S files in DaVinic Resolve, although it claims Resolve can support XAVC file type. Has anyone imported the XAVC/XAVC S footage into Resolve? When I tried, it doesn't seem to find the audio track. Says 0 audio tracks and plays no sound. The video track works, though. After a long time research, I finally find a simple method that can solve the problem.
Got some clues from related forum, some guys mentioned that Resolve and many other programs can only handle PCM audio, like WAV files. Not LPCM audio. There are totally different formats. And basically, XACV/XAVC S is not ideal format for NEL. To import XAVC/XAVC S to DaVinci Resolve 11/12 without any issue, a good suggestion is to transcode XAVC/XAVC S to Resolve most compatible format like DNxHD or ProRes. Brorsoft Video Converter for Mac is the solid tool to help users make the XAVC/XAVC S to DaVinci Resolve conversion on Mac OS X.
With it, you effortlessly convert 4K XAVC, XAVC S footage shot from Sony F5, Sony F55, PXW-X70, PXW-FS7, Sony AX100, AX1, A7s to DaVinci Resolve highly compatible DNxHD, ProRes, or QuickTime format, which can ensure maximum editing quality and efficiency. Besides, its also allows you to convert kinds of videos to seamlessly fit iMovie, Final Cut Pro, Adobe Premiere, Avid Media Composer, etc. If you are Windows users, turn to Brorsoft Video Converter. Below are the steps on converting XAVC, XAVC S clips to DaVinci Resolve.
Transcoding XAVC/XAVC S for Editing in DaVinci Resolve
1. Install the program on Mac and run it. Drag the XAVC or XAVC S files to the software. Or you can also click "Add" button on the top of the main interface to import video to the program. It supports batch conversion and joining multiple video clips into one file.
2. Choose DaVinic Resolve preferred format. Click Format bar, you can choose Avid Media Composer > Avid DNxHD(*.mov) as output format. It is an ideal editing format for Resolve. Of course, you can also click "Common Video" > "MOV - QuickTime (*.MOV)" as the target format.
Tips: Adjust video, audio settings
Click the "Settings" button and customize proper video/audio parameters including Video size, bitrate and fame rate and more.
3. After all necessary settings, hit the convert button to start the XAVC/XAVC S video to DNxHD conversion for DaVinci Resolve on Mac OS X. Once the conversion process shows in 100%, click Open to get the output videos. Create a project and start editing XAVC/XAVC S in DaVinci Resolve 9/10/11/12 with light speed.
Read more:
Transferring DVD files to Samsung Gear VR
How to import XAVC S to Avid Media Composer
MTS footage won’t work in DaVinci Resolve(Lite)
How to Upload XAVC/XAVC S Files to YouTube
How to Import XAVC Files to Adobe Premiere Pro
Convert DVD to Samsung Gear VR friendly format
How to import FCP Projects to Premiere Pro CC/CS6
Converting MTS/M2TS to MOV with zero quality loss
Solution- No Audio from .MTS files in DaVinci Resolve
Make Sony HDR-PJ810 AVCHD editable in Adobe Premiere CC
How to rip Blu-ray and DVD movies to Nokia N1 Tablet in clicks
Source:Can DaVinci Resolve handle the 4K XAVC/XAVC S playback
Re: How to transfer XAVC/XAVC S to DaVinci Resolve 11
Postod Andyeric » 02.07.2015 11:15
Related:
