Convert 4k MXF for Uploading to YouTube, Vimeo, Facebook
Postod Andyeric » 16.04.2015 7:33
Upload Canon XC10 XF-AVC 4K/HD MXF to YouTube, Vimeo, Facebook
Overview
What's the best workflow between Canon XC10 4K/Full HD MXF Video and YouTube, Vimeo, Facebook? The article displays an easy and direct way of uploading Canon XC10 MXF Video to YouTube or other video websites with optimum performance.
Hot Search: MXF to VLC/WMP | MXF to iMovie | MXF to FCP | MXF to Avid MC | MXF to Premiere Pro | MXF to multi-track MOV
Introduction:
Canon has recently announced the development of XF-AVC, a new proprietary video format for the efficient recording of high-image-quality 4K, 2K and HD video footage. XF-AVC is mainly targeting professional-use 4K video camcorders, such as the most recent Canon XC10 4K Camcorder, which delivers enhanced workflows across various stages of the production process, from shooting to editing.
Canon XC10 uses XF-AVC movie recording format, employs the MPEG-4 AVC/H.264 video compression format, and stores shootings in an MXF wrapper. MXF is a "container" or "wrapper" format which supports a number of different streams of coded "essence", encoded with any of a variety of codecs, together with a metadata wrapper which describes the material contained within the MXF file. MXF has been designed to address a number of problems with non-professional formats.
Since YouTube/Vimeo/Facebook has their best supported video formats, why can't we convert all the video formats to those suitable ones for YouTube/Vimeo/Facebook. Powerful converting assistant Pavtube MXF Converter for Mac is highly recommended here. If you are running on Windows, you can refer to the equivalent version MXF Converter. As well as encoding the edited video back to normal files for sharing with friends, it can adjust our output videos with our own favorite settings.
Other Download Sources:
Apple Store: https://itunes.apple.com/us/app/pavtube ... 7634?mt=12
Amazon Store: http://www.amazon.com/Pavtube-MXF-Conve ... B00QID8K28
Cnet: http://download.cnet.com/Pavtube-MXF-Co ... 77789.html
How to convert and upload Canon XC10 XF-AVC 4K MXF to YouTube/Vimeo/Facebook?
Step 1: Backup your MXF files from Canon XC10 to hard drive. Install and launch MXF Converter for Mac. Drag and drop MXF files to the software. You can import multiple files at once thanks to "Add from folder" button.
Step 2: Click the "Format" bar and come to the output list, here we should select the different output items there. For example, choose the "Flash Video -> FLV H.264 (*.flv)" for YouTube. Or "HD Video" -> "H.264 HD Video (*.mp4)" or "AVI HD Video(*.avi)" individually for Vimeo and Facebook.
Step 4: You can preview to check the final result. Once you are satisfied with it, click the "Convert" button to start converting Canon XC10 XF-AVC 4K MXF to YouTube/Vimeo/Facebook supported formats for uploading. It will take you a little while.
Conclusion: From Canon XC10 XF-AVC 4K MXF to supported videos for YouTube/Vimeo/Facebook, such the easy operation job you can do well. Just have fun for sharing wonderful XF-AVC 4K MXF videos captured by Canon XC10 on YouTube, Vimeo and Facebook with your family and friends!
Learn more about Pavtube MXF Converter for Mac articles:
Source: http://bestvideoking.blogspot.com/2015/04/upload-4k-mxf-to-youtube-vimeo-facebook.html
