Transcode MPG/MPEG to iMovie on Mac Mavericks/Yosemite
Postod Andyeric » 13.04.2015 11:32
How to Import MPG/MPEG Files to iMovie on Mac
Summary: Have problem with importing MPG to iMovie? If you temporarily have no idea about what to do, take the MPG/MPEG to iMovie Mac conversion into consideration.
It's joyful to editing your MPG videos from your camera with iMovie on Mac Mavericks/Yosemite. However, the MPEG standard files may use different codes and cause failure in importing to iMovie. If you comes across this situation, the best solution is to get aids from MPG/MPEG to iMovie converter for Mac, which can help you to convert MPEG group files to iMovie compatible video format and then files can be easily imported for editing job. And here you would find a step by step guide of the MPG/MPEG to iMovie on Mac conversion on Mavericks/Yosemite. By the way, you should know the best supported video formats for iMovie firstly.
To do such a MPEG to iMovie Mac task, you'd better install a professional Video Converter for Mac to preserve your video quality. Here Pavtube HD Video Converter for Mac is highly recommended. It's a professional and powerful high-quality Mac video converter and editor. Just can do what it does what I need it to do.
With it, you can effortlessly transcode MPG/MPEG files to AIC encoded MOV for iMovie on Mac Mavericks/Yosemite. Meanwhile, the Mac Video Conversion tool can aslo convert your mpg recordings to be compatible with various non-linear editing systems like Avid, iMovie, FCP X, and Adobe Premiere (Pro) etc. A powerful hd video converting program with a reasonable price. The conversion is darn easy to be finished with only three clicks without loss of video quality.
Just download it and follow the tutorials below to transfer and import MPG/MPEG footage to for smoothly editing in iMovie on Mac Mavericks/Yosemite.
How to Convert MPG/MPEG to iMovie for Mac Mavericks/Yosemite
Step 1. Download, install and run the Mac MPG/MPEG to AIC Converter, click "Add" or "Add From Folder" to load your MPG/MPEG footage.
Step 2. Click the Format bar, and move mouse cursor to "iMovie and Final Cut Express > Apple InterMediate Codec(*.mov) as natively supported format for iMovie on Mac Mavericks/Yosemite.
Some more helpful features of the app:
Step 3. Click "Convert" button to start MPG/MPEG to AIC MOV conversion.
As soon as the encoding process finished, you can get the final output aic .mov files via clicking "Open" button effortlessly. The transcoded files now are ready for importing and editing in iMovie on Mac Mavericks/Yosemite.
Additional Tips:
If you want to edit GoPro video in Final Cut Pro X or FCP 7/6, you just need to choose the "Final Cut Pro > Apple ProRes 422 (*.mov)" as output format in the second step; For Avid Media Composer, choose "Avid Media Composer > Avid DNxHD(*.mov)" as output; For Adobe Premiere Pro, choose Adobe Premiere/Sony Vegas> MPEG-2(*.mpg) as output.
Also learn how to get XAVC video and AVCHD footage for iMovie editing and read how to Flip Video in iMovie and find iMovie alternative editors.
Related articles:
iMovie/FCE supported video formats
Import Sony FDR-AXP33 XAVC to iMovie/FCE for Processing
WMV to iMovie: Solve WMV to iMovie Issues on Mac OS X 10.10 Yosemite
VOB to iMovie---Convert VOB for Editing in iMovie Nicely
Source: http://video-tips.jimdo.com/2014/11/09/convert-mpg-mpeg-to-imovie-on-mac/
Korisnici koji su trenutno na forumu: Nema registrovanih korisnika i 12 gostiju
