Transcode TS files to Avid DNxHD mov for Avid Media Composer
Postod Andyeric » 10.04.2015 7:47
Transcode .TS files to Avid DNxHD mov for Avid Media Composer
Summary: The article explains how to get Avid Media Composer to work perfectly with AVCHD footage in .TS format by transcoding to DNxHD MOV files.
TS, short for Transport Stream, is a communications protocol for audio, video, and data. But TS is not a Avid-compatible format. So you must convert TS to Avid supported formats like DNxHD .mov. TS to a Avid Converter brings you the easiest, affordable way to import .ts movies into Avid accepted video.
Hot Search: Video_TS to VLC | TS to FCP X | TS to QuickTime | TS to DVD | TS to iTunes | TS to HD MKV
With a professional TS files to Avid converter is necessary, Pavtube HD Video Converter for Mac is highly recommended to you, It would be quite simple and easy for you to convert TS files to Avid Media Composer compatible-format on Mac. (If you're running a PC, pls get its Windows version.)
The article is a step by step guide, showing you how to convert TS to Avid DNxHD MOV with excellent quality for Avid Media Composer on Mac.
Official Download: http://download.pavtube.com/hd-video-co ... _setup.dmg
App Store Download: https://itunes.apple.com/de/app/pavtube ... 2488?mt=12
Amazon Store Download: http://www.amazon.com/Pavtube-Video-Con ... B00QI9GNZS
Cnet Download: http://download.cnet.com/Pavtube-HD-Vid ... 77786.html
Official Buy: http://www.pavtube.com/hd-video-converter-mac/purchase/
Simple steps to convert TS to Avid DNxHD .mov for editing .TS in Avid Media Composer on Mac
1. Add TS files to the program
With the Mac TS converter, you can directly drag & drop the TS files to the converter, or click "Add video" or "Add from folder" icon to locate the TS files you want to load.
2. Choose DHxHD MOV as output format
Select "Avid DHxHD (*.mov)" as target format under "Avid Media Composer" option. This optimal format would guarantee a great performance when editing in Avid MC.
3. TS to Avid Media Composer conversion on Mac OS X
Hit "Convert" button and let this professional TS to Avid Converter do the rest for you!
After the TS files to Avid Media Composer, you can freely use your TS files on Avid Media Composer, The converter also works on MacBook, MacBook Pro, MacBook Air, iMac.
More features of TS Video Converter for Mac
1. By ticking off the checkbox before "Merge into one file" option, you can combine all the checked Panasonic MTS/M2TS clips into one file.
2. If you wanna customize the video and audio parameters, you can click "Settings" button to enter "Profile Settings" panel to modify video and audio settings like video resolution, bit rate, frame rate, sample rate, and audio channel.
3. The TS to Avid Converter provides customers with several simple editing functions, including cropping, trimming, deinterlacing, watermarking, adding special effects, and audio replacing, which help you do a fast and necessary editing on your .ts footage before importing them to Avid Media Composer.
4. Pavtube HD Video Converter for Mac Useful Guides:
Source: http://1080p-video-tool.blogspot.com/2013/04/Import-.TS-Transport-Stream-files-with-Avid-MC.html
