Import Issues of Panasonic Lumix DMC-GF7 and iMovie
Postod Andyeric » 05.03.2015 11:16
Solve Panasonic Lumix DMC-GF7 and iMovie Incompatibility Issues
This guide is written for people who are having issues editing Panasonic Lumix DMC-GF7 AVCHD MTS/M2TS video files on Mac Yosemite through iMovie.
If you are confused with the problem that you can't edit your AVCHD MTS footages from Panasonic Lumix DMC-GF7 in iMovie, you'd better transcode your Panasonic GF7 AVCHD files first to resolve the incompatible problem.
"I have recorded many footages from Panasonic Lumix DMC-GF7 camera that in AVCHD MTS video format, now I would like to import these projects to iMovie 11 for editing. What I want is to edit AVCHD files natively in iMovie 11 on Mac, what video codec should I use? Can you recommend some software which can help me import and convert AVCHD to iMovie 11 natively?"
When it comes to iMovie, Apple claims that iMovie supports most commonly-used video codecs, including MPEG-4, DV, H.264, MPEG-2, AIC and AVCHD. However, users may find that MTS videos are grayed out when they are prepared to be linked into iMovie. The reason why you can't import Panasonic Lumix GF7 MTS files to iMovie can be various. On the one hand, iMovie cannot import raw MTS files moved from the private folder structure. On the other hand, iMovie hardly supports MTS footage recorded in 1080 50p or 60p.
As far as we know and the feedback from the Panasonic GF7 users, many nonlinear video editing software on Mac like iMovie 8/9/11, Final Cut Pro 6/7/X, Adobe Premiere Pro, Avid Media Composer, etc. can't perfectly import AVCHD .mts files from Panasonic Lumix DMC-GF7 directly. Well, if you make the recordings editable before taking to the program, the incompatible error won't happen anymore. Here you can download and apply Pavtube MTS/M2TS Converter for Mac( Win )to achieve the goal in a fast way. This best Mac AVCHD Converter displays a way of transcoding Lumix GF7 AVCHD MTS video to a Mac friendly format for working with iMovie maintaining original quality.
How to convert Panasonic Lumix DMC-GF7 AVCHD MTS footage to iMovie?
Step 1:
Download, install and run the Mac AVCHD Converter to load your AVCHD footages from Panasonic Lumix GF7 to the program by clicking "Add video" button. If you want to import several files at once, "Add from folder" button is available. Besides, drag and drop is also OK.
Step 2: Click "Format" bar and choose "iMovie and Final Cut Express>>Apple InterMediate Codec (AIC) (*.mov)" as output format. It's the best format for editing Panasonic Lumix DMC-GF7 AVCHD MTS files in iMovie 11/9/8.
Step 3: Why not take around the "Settings" button on the main interface? Here, we can adjust our video size, (just according to personal requirements), bitrates or frame rate, remember that you should set them in appropriate default or you might not get an ideal effect.
Click "Snapshot" button when previewing the video and click "Option" to set the image format of screenshots.
Click "Edit selected task", switch to "Effect" tab, you can tick off "Deinterlacing" box; switch to "Trim" tab, you can input time point in start and end box.
Step 4: When ready, click "Convert" button under the preview window to start format conversion. If you don't want to wait for the entire conversion process, you can tick off "Shut down computer after conversion" and go away to do other things.
Conclusion: Once the conversion is 100% completed, you can hit "Open" button to locate converted video files and copy the converted files to iMovie for smooth and easier editing. The transfer on How to import video files or projects to iMovie 8/9/11 on Mac can do you a big favor about the next work.
Further Reading:
Insert any Videos into WordPress Blog for Playback with Mediaelement.js: By now it's no secret how powerful videos have become in online marketing, and WordPress makes embedding videos hosted on external sites like YouTube or Vimeo extremely easy. But what about when you do not want to have a video publicly viewable, inside a membership area, or simply just want more control on how the player looks and works?
Upload iPhone 6 Plus Recordings to YouTube/Vimeo or Burn into DVD on Yosemite: Before we talk about uploading iPhone 6 Plus recordings to YouTube/Vimeo or burn into DVD on Yosemite, maybe we should make it clear that why and how to share this idea, right? Let's know more about it.
Compare Pavtube MXF, MTS, HD Video and Video Converter Software for All Video Fans: When you make the conversion happen, you can make everything happen. With Pavtube, a professional and comprehensive video conversion processor integrating backup, conversion of video sources all in one step, it's no big deal.
source : http://lovecamcorder.tumblr.com/post/11 ... -in-imovie
