Transcode Sony AX100 4K XAVC-S MP4 to Avid DNxHD mov for Avi
Postod Andyeric » 24.02.2015 13:26
XAVC S Avid: Can Avid MC import XAVC-S MP4 from Sony AX100
Description: As far as I know the latest 4k XAVC S video format introduced by Sony is still not supported well by Avid Media Composer so far. If you want to import Sony FDR-AX100 4K XAVC S files to Avid for editing with native Avid DNxHD format, Pavtube XAVC S Video Converter provides a brief instruction.
Now Sony has launched the first consumer camcorder to shoot 4K (Ultra HD) footage – the Sony FDR-AX100. It captures this in Sony's own XAVC-S file format. This uses an MP4 container and H.264 video, along with 2-channel PCM audio. The format is widely supported by the usual video editors, but it looks like you'll need top-end software to handle it – such as Avid Media Composer – rather than the more downmarket options.
Sony FDR-AX100's XAVC S codec video is MP4 format. The Mac editor Avid Media Composer support MP4 video importing although, the XAVC S video codec is still a new one for Avid MC.
Hi, I have Sony FDR-AX100 camera for 4K recordings. I cant AMA link to any of my footage as the format is not supported by Avid. And the AX100 which my friends planned to buy also uses this XAVC-S codec. So I'm confused by the XAVC-S/Avid AMA workflow.
Since you will have problem for importing Sony XAVC-S videos into Avid MC even with the AMA Plug-in, to make things easier, you had better to transcode Sony FDR-AX100 XAVC-S footage to a more editing-friendly format, such as Avid Media Composer's DNxHD .mov.
To convert Sony AX100 4K XAVC S MP4 to Avid DNxHD MOV on Mac OS X Yosemite, Pavtube (Sony XAVC S) Video Converter for Mac is highly recommended for its simplicity, efficiency and reliable workflow.
Just free download or buy Pavtube XAVC S Video Converter for Mac, and install on your Mac:
Note: If you're running Avid Media Composer on your Windows, pls try XAVC S Video Converter
Step 1. Import XAVC S MP4 files to the Mac XAVC S Video Converter.
Install the best Mac XAVC S Video Converter on your Mac. Hook your Sony AX100 to Mac and keep it on; click the two icons which are marked as 1 to load XAVC-S footage from Sony FDR-AX100 to Mac XAVC S Video Converter like this:
Step 2. Trim out a few clips before converting XAVC-S to Avid.
Now click the pencil-like icon (Edit) and locate the Trim icon:
Drag the small triangle icons to locate the opening and ending; or click the icons in blue to adjust frame by frame. It also supports setting "Start" and "End" point-in-time.
Step 3. Choose output video format for Avid Media Composer.
Click the drop-down list and choose "Avid Media Composer -> Avid DNxHD(*.mov)" as the most compatible format/codec for AMC editing.
You can free choose the output video quality, size, frame rate by clicking the "Settings".
4. Convert Sony AX100 XAVC S MP4 files to Avid DNxHD MOV.
Now hit "Convert" and let it running; you can easily locate the converted video by clicking "Open" at the bottom.
You may want to read How to import video file to Avid Media Composer?
Related Articles:
Importing Sony AX100 XAVC-S videos in iMovie/FCE
Convert Sony AX1 4K XAVC S to QuickTime MOV for playing
Convert AVCHD/AVCHD Lite MTS/M2TS files to QuickTime MOV
Make Sony PXW-Z100 XAVC Videos Compatible with FCP X on Mac Yosemite
Convert Apple ProRes video to M4V for streaming to Apple TV 3
Video Converter($35) + MXF MultiMixer($45) = $54.9, Save $25.1 (buy link)
Video Converter for Mac($35) + iMixMXF($45) = $54.9, Save $25.1 (buy link)
Source: http://digitalmediasolution.altervista.org/blog/import-sony-ax100-xavc-s-in-avid-mc/
