How to Backup Rented Blu-ray from RedBox, NetFlix, Amazon?
Postod JeanLiu » 09.02.2015 12:02
Summary: This guide is about how to rip and copy rental Blu-rays from Netflix, Redbox, Amazon to Hard Drive with copyright scheme using the best Blu-ray rental copy software for your needs.
Whether you are heading to trendy online Blu-ray rentals or settle for going down the street for stereotyped movie rental stores, one thing is for sure: you attempt to borrow Blu-ray as a rental at a relatively low price. However, an overwhelming trend now is to rip and copy rental Blu-ray for permanent keeping or mobile watching since every borrowed Blu-ray has a rental period.
As a response to the uprising demands for Blu-ray followers, we reveal the detailed guide on how to make a backup of Blu-ray rented from RedBox, NetFlix, Amazon for watching without time limitation.
Through a google search on the internet, I find Pavtube Blu-ray copying program- Pavtube BDMagic which can give you the best approach to bypass copy protection or remove region code restriction from Netflix, Redbox, Amazon borrowed Blu-ray. With it, you can 1:1 copy and convert rental Blu-ray to virtually any regular formats MP4, MOV, MKV, FLV... to play anywhere with original quality. The mac version is BDMagic for Mac. Moneysaving boundles: BDMagic($49) + ChewTune($29) = Only $49.9, Save $28.1
Review: Top 5 Best Selling Windows/Mac Blu-ray Rippers
Backup Rental Blu-ray Discs to Mac for Playback at Any Time
Rip, Convert and Backup Blu-ray Rentals Effortlessly
Step 1: Load Rental Blu-ray movies into the program
Once you run the Rental Blu-ray Ripper, click BD disc button to load Rented Blu-ray from RedBox, NetFlix, Amazon up into the Blu ray ripping program.
Step 2. Decide Blu-ray Copy Mode
A. Full Disc Copy Mode: Copy Rental Blu-ray Disc to a full Blu-ray folder containing all the content in original BD.
B. Directly Copy Mode: Backup Rental Blu-ray Disc to a file with M2TS as filename extension. This mode enables copy movie only from Blu-ray discs, compared with former mode, save time in copying protected Blu-ray Disc and space to store the output M2TS file to make reasonable and practical use.
Step 3: Choose an output video format
If you wanna rip Rental Blu-ray to your needed file types, you need specify a format as output format. Click on the dropdown menu of "Format", and then choose your needed one from the multiple output format presets. You can rip Blu-ray to MKV, MP4, MOV, WMV, or rip Blu-ray for playback on iPad, iPhone, PS Vita, Nook HD, Galaxy Tab and more other portable devices you can think of.
Tip: Click "Settings" button, then you are able to adjust all the settings in the following window to customize the output file quality, including codec, size, bit rate, frame rate, sample rate and audio channel.
Step 4: Rip and copy Rented Blu-ray from RedBox, NetFlix, Amazon
Once the above mentioned steps are finished, you can click "Convert" button to copy Rental Blu-ray movie to either the hard drive of your PC, or to your portable devices for enjoying on the go.
When the copying/ripping task is completed, you can click "Open" button to get the ripped files of Rental Blu-ray movie. Then, you can play, share Rental Blu-ray with your families anywhere you want.
If you have rental DVD discs, learn how to copy Rented DVD from RedBox, NetFlix, Amazon, watch rental DVDs on iPad/iPhone/iPod or get them playback on HDTV.
Source:http://video-tips.jimdo.com/2014/12/10/rental-blu-ray-copy/
