How to play Sony 4K XAVC/XAVC S on QuickTime player?
Postod Andyeric » 07.02.2015 18:55
To most people, they may not familiar with the XAVC/XAVC S format, and don't know how to play XAVC videos on QuickTime smoothly, in this article you will know how to convert XAVC/XAVC S video for playing on QuickTime player easily and freely.
Model: Sony PMW-F55, F5
The camera PMW-F55, F5 which used XAVC format was recently unveiled by Sony. XAVC is a new recording format which can support 4K resolution (4096 * 2160 and 3840 * 2160) at up to 60 fps, introduced by the famous Japanese camera manufacturer Sony on October 30, 2012. However, .xavc is still not as popular as other kinds of video formats such as AVCHD and MXF, so when you deal with the XAVC/XAVC-S footages, for example, importing Sony XAVC/XAVC-S to Mac applications like QuickTime for playing, you may encounter some format compatibility or video/audio synchronization problems.
This article is written to help XAVC users to solve such kind of problems by using XAVC to QuickTime Converter ( Pavtube Video Converter). It can help users fix all kinds of XAVC problems without losing the video quality. It offers an easy way to convert XAVC to MOV for playback on Mac. With it, you will be able to import XAVC videos to your QuickTime for playback with ease. Besides, by converting XAVC to MOV, you can transfer the generated files to your iPhone, iPad, Apple TV 3, etc to play with ease. If you are a Mac user, you can turn to XAVC Video Converter for Mac, which share similar functions with the Mac Version.
How to Convert Sony XAVC/XAVC S to QuickTime .MOV on Windows
Step 1: Load XAVC footages to the XAVC Video Converter
Run Pavtube Sony XAVC to MOV Converter. Click "Add file" or "Add from folder" button, browse to the XAVC footages and load them to the converter.
Step 2. Choose QuickTime MOV as the output format
To transfer Sony XAVC/XAVC-S to QuickTime on Windows, the best way is to convert XAVC to MOV. Click on the drop-down list of "Format", and follow "Common Video" -> "MOV-QuickTime (*.mov)" or "Common Video" -> "H.264 Video (*.mp4)".
To retain the HD video quality, you can select "HD Video"> "H.264 HD Video (*.mp4)".
Tips: Click the "Settings" button and set proper video/ audio parameters. You can reset set the video size, bitrate and fame rate. If you would like to use default settings, simply skip this step.
Step 3: Start converting XAVC/XAVC S to MOV
After the options above, press the "Convert" button to launch the conversion from XAVC/XAVC-S to QuickTime mov on Windows 8.1/8. Just take a free try.
When the conversion process finished, you can get the output MOV files and then use them on your Quicktime player without any problems. Hope this XAVC to MOV converter can give you some help.
Tip: Like to edit your Sony XAVC/XAVC S video in Adobe Premiere Pro? See the following article: XAVC and Adobe workflow
See also:
Video Converter($35) + MXF MultiMixer($45) = $54.9, Save $25.1 (buy link)
Video Converter for Mac($35) + iMixMXF($45) = $54.9, Save $25.1 (buy link)
MXF MultiMixer/iMixMXF Key Features:
-Import/preserve/mix multi-track MXF in MKV/MP4/MOV formats.
-Output multi-track Apple Prores MOV for further editing in Final Cut Pro (X).
-Support DVCPRO/HDV/Avid DNxHD/AIC output
-Convert MXF to any other formats for editing, playing, or broadcasting.
-Merge/split/trim/crop MXF footages.
Video Converter for Windows/Mac Key Features:
-Convert from and to any common SD/HD video and audio format.
-Support Apple ProRes/DVCPRO/HDV/Avid DNxHD/AIC encoding.
-Output formats for Windows/Mac editing software, e.g. FCP, iMovie, FCE, Avid, Adobe Premiere, Sony Vegas Pro, etc.
-Output formats for different playback devices, hdtv, hd media players, etc.
Go ahead and click the link to get your coupon. Save up to $44.1! Never miss!!!
Source: http://pc-mac-compatibility-issues.blogspot.com/2013/05/transfer-Sony-XAVC-XAVC-S-to-QuickTime-for-playback.html
