Slove 2k/4k XAVC to Pinnacle/Vegas Pro/Windows Movie Maker i
Postod Andyeric » 04.02.2015 8:40
In this article, you will know details about XAVC format, and the best way to edit Sony 2K/4K XAVC on Windows editors like Pinnacle, Avid MC, Adobe Premiere, Sony Vegas, Windows Movie Maker, Cyberlink, Sorenson Squeeze, etc.
XAVC format
XAVC is a brand new recording format introduced by the famous Japanese camera manufacturer Sony on October 30, 2012. XAVC is usually a video format that was introduced by Sony and extensively exist in Sony PMW-F55 and Sony PMW-F5. XAVC will be used by more and more popular HD camcorders with features of level 5.2 of H.264/MPEG-4 AVC which is the highest level supported by that video standard. XAVC can support 4K resolution (4096 × 2160 and 3840 × 2160) at up to 60 frames per second (fps).
XAVC to Windows Editor Solution
Since XAVC is quite new a format that most of the editing application and programs such as Pinnacle, Cyberlink, Sorenson Squeeze, Windows Movie Maker, and more, cannot run such footages. In this case, you need to transcode the the unfriendly 2K or 4K XAVC footages to other kind of popular video formats like MPEG-2, WMV, AVI, MOV, etc. for better compatibility by using the best XAVC Video Converter.
Pavtube XAVC Video Converer(Pavtube Video Converter) is particularly designed with future-proof technology to solve all the format compatibility issues of the new Sony XAVC files. It can help all Windows users losslessly convert the 2K/4K XAVC footages to most popular video formats as well as importing XAVC to Pinnacle Studio 17, Sony Vegas Pro 13/12/11, Avid Media Composer, Adobe Premiere, Cyberlink, Sorenson Squeeze, Windows Movie Maker, etc. for editing freely. Besides, this smart XAVC video converting program also provides users with useful editing functions and new features such as converting 2K/4K XAVC videos and other SD/HD videos to H.265/HEVC MP4, 3D MKV/AVI/MOV/MP4 and various HD or Common video and audio formats on Windows (Windows 8.1 included).
How to encode 2K/4K XAVC files for editing in Pinnacle, Vegas Pro, Avid, Premiere, Cyberlink, Windows Movie Maker freely?
To use XAVC footages on Windows Editing Software smoothly, the best way is to transcode Sony XAVC to Windows PC best supported codec. Now you can follow the easy steps below to convert XAVC to MPEG-2, WMV, AVI, MOV for All Windows Editor.
Step 1. Download Pavtube Windwos 8.1 XAVC Video Converter, follow the prompts to install the program. Click "Add" to load XAVC video files or directly drag the files into file list.
Step 2. Click "Format" bar to determine output format. This software has many presets for editing software, you just need to choose in the profile column.
For editing with Pinnacle, Cyberlink, Sorenson Squeeze and Windows Movie Maker, you can choose "WMV (VC-1) (*.wmv)" , "MPEG-2 HD Video (*.mpg)" or "MOV(AVC) (*.mov)" from "Adobe Premiere/Sony Vegas" option and more.
Step 3. If you would like to customize the video and audio parameters, you can click "settings", adjust the parameters as you want, like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels.
Step 4. Click "Convert" to start to convert XAVC to Windows editing software.
With this XAVC Video Converter, it becomes easy for you to convert Sony 2K/4K XAVC videos to Windows editing software compatible file formats for editing in Pinnacle, Sony Vegas Pro, Avid MC, Adobe Premiere, Cyberlink, Sorenson Squeeze and Windows Movie Maker, so you are recommended to take a try.
For Mac software, like FCP, iMovie, FCE[/url], etc., you can convert 2K/4K XAVC footage to Apple ProRes/AIC MOV for editing with the professional Mac XAVC Converter.
See also:
Source: http://pc-mac-compatibility-issues.blogspot.com/2013/08/pavtube-ultimate-xavc-video-converter-user-guide-for-windows.html
