How to Rip and Convert Blu-ray to H.265 Video
Postod JeanLiu » 03.02.2015 14:20
Wanna rip your Blu-ray ISO files and get a H.265 MP4 video with high video quality and relatively smaller size? Read on this article, you will get the best solution.
Referring to backing up Blu-ray movie without quality loss, most folks would make a Blu-ray ISO image instead of copying the whole BD contents to BDMV folder. However, many have experienced Blu-ray ISO playback issues insufficient storage, here comes a solution for this situation--- ripping Blu-ray ISO image files into H.265 MP4.
In this try, more than one people suggest to rip Blu-ray ISO files to H.265/HEVC MP4 with the latest Pavtube BDMagic. It is an ideal app for you to rip Blu-ray, DVD, ISO/IFO files to H.265 MP4 video. Result is the image quality is the same, but the file size is reduced to half. Cheers! Plus, it also can help you to convert Blu-ray, DVD to almost any other common video format such as VOB, FLV, WMV, AVI, MKV as you need. Now just download it and follow the tutorial below.
Read Top 5 Best Blu-ray Ripper Review and here are proper combo for you:
Perfect solution for converting Blu-ray ISO to H.265/HEVC MP4 video on Windows
Step 1. Load Blu-ray ISO movies
Launch the Blu ray ISO to H.265 converter; click Add button to import Blu-ray ISO movies into the program.
Step 2. Choose MP4 as output format
Click Format bar to get the format list and select a proper export format. Common Video > H.265 Video(*.mp4) is the proper choice.
Step 3. Customize the output video
You can click Edit button to trim your favorite part from the video, crop video frame size, adjust visual effects, add watermarks, subtitles and more to personalize your videos. Plus, click the Settings icon, you can adjust the video size, frame rate, bitrate, etc.
Step 4. Start to convert Blu-ray ISO video
When all the settings are OK, you can click the "Convert" button on the main interface to start converting Blu-ray ISO to H.265 MP4 video.
After the conversion, click the Open button to locate the resulted videos. By means that of looking on Google, you'll realize many players support H.265 video playback. Moreover, some manufactures even market their H. 265 video devices.
Pavtube upgraded softwares can spare no efforts to produce users the simplest video expertise in accordance with the latest technology all identical.
Note: You can also convert Blu-ray and DVD to H.265 files with Pavtube BDMagic.
Source:http://bd-dvd-copying-ripping.blogspot.com/2014/12/blu-ray-iso-to-h265-solution.html
